Hello i have a 1980s technics suv9 amp when its playing it some times makes a static crackley sound and when i use any of the buttons they mke a cackley noise
Hi Green
You can fix that by spraying the controls and switches with CRC 2-26 (contact lubricant)You need to take the lid off to get at the internals of the controls, flood them with CRC using the straw that comes with the can. Do the same to any switches that are noisy also. It will be good as once again :)
regards
Graeme
Posted on Apr 15, 2008
Technics su-g75 amp goes to loud static after a few minutes
Hi Aawpharmd,
system control error.
please go for repair shop.
regards,
nuwan
Jan 13, 2014 | Technics SU-G75 Amplifier
I have a Technics RS-TR373. Yesterday, during tape playing back, he sound suddenly stopped. The db level meter shows no sound being pickup. I switch to tape 2, it was the same. Tape was played (I can...
hi rich,
i had this problem it was touching the buttons that lost the sound to the speakers, do you have a re-set button if so press it if not press A or B to get your sound back if thats does nothing then try head cleaning tape as you might have some static thats transfered from your tape to your heads an anti- static head cleaning tape will do the job, you should use these cleaning tapes every week as the heads pick up a lot of dust particles and static that cause very poor reproduction and qulity such as crackling and muffled repro,
hope this helps
Jan 22, 2011 | Technics RS-TR373 Single Cassette Deck
Tape players wont play the tapes. THey are turning but no sound is coming out. checked all connections and can't figure out whats' happening. Technics model RSTR72. Is it worth fixing or should I get...
you have two buttons B+C USE B to get sound to your speakers if no joy try a simple tape cleaner or anti static tape cleaner this is usually the problem.
Dec 19, 2010 | Technics RS-TR272 Single Cassette Deck
Technics SL1200MK2 - audio issue with ''s'' sounds only
Try some anti-static record cleaner. You can also get an anti-static matt to put the records on.
Jul 27, 2010 | Technics SL-1200MK2 Turntable
Protect mode
Protection circuit.
Checek the wiring of the amp and speakers, don' forget to look for shorts at the speakers. Make sure no wires are touching each other
Apr 30, 2010 | Volfenhag 1600 WATT CHROME AMP AMPLIFIER 2...
Car radio/cd player cuts off radio will not play cd will not play ,hit the power button and will come back on some times it wil not. its seems like there is static sound when the music does not play on the...
Hello pinkperry,
It sounds like the wiring between the cdplayer and the dash has come loose. When the wires are not making proper connections some of the speakers or functions of the radio cut on and off.
This is just my first thought and the easiest thing to fix. You will have to remove the cd player from the dash. After which you will want to check the wiring. Chances are your cd player has a harness if it's an aftermarket cd player installed in your car. If it does there will be two sets of wires to double check.
Just make sure all the wires are securely twisted together (the sets of wires) and taped up with electrical tape.
Try that and post back if you have any further questions. Thank you for choosing Fixya!
Aug 25, 2009 | Car Audio & Video
CASIO PX575R 1 year old off warranty. Randomly, keyboard will lock up. The keys will stop triggering any sound, but the rhythm machine keeps on playing. And all the controls are locked, not a single button...
This may be a hard one to analyze, however my educated guess is that a static discharge is putting the internal processor in a program loop it shouldn't be in.
It is my experience that you MAY not even feel a discharge even.
Suggest you make sure to not wear static producing clothing as a test. Sliding across a piano bench might even create the discharge.
The unit SHOULD not be sensitive to this, but the designers don't always do things right.
ALSO make sure the unit is plugged into a grounded receptacle.
Use of external things like amps and headphones can WORSEN the problem of static. External amps MUST be fed from the same receptacle.
Aug 07, 2009 | Casio Music
Technics SL-L3 turntable no sound until warm up
either the cartridge is bad in the phonograph tone arm.  Or the pre-amp in the stereo is bad...remember that the turntable is the only accessory that uses the pre-amp input on the stereo.  I'm betting the pre-amp is bad.
Mar 10, 2009 | Technics SL-1210 Turntable
Amp not working properly.............
Mke sure that the tape monitor switch is turned off.
Dan
Apr 09, 2008 | Audio Players & Recorders
Technics SUV500 Amplifier
check volume balance between right and left-then change inter connection between sound source and amplifier with new cabel(i prefer gold plated type connectors)(see radio shack).
after that if the problem excit your fault in output transistors or output stereo ic depend on circuit design.
Feb 17, 2008 | Technics SUV500 2-Channel Amplifier
96 people viewed this question
 Grubhead
Grubhead
