Dreamweaver Corruption When I start up Dreamweaver 8 I get the following error message. It only just started to happen and hasn't been solved by using Windows restore. The following JavaScript error(s) occurred: At line 56 of file "C:Program FilesMacromediaDreamweaver 8ConfigurationSharedCommonScriptsdwscriptsExtData.js:ReferenceError: dwscripts is not defined
    Problem Solver:
  • 13 Answers
You can recreate your configuration folder
C:\Documents and Settings\<username>\Application Data\Macromedia\dreamweaver 8
rename the configguration folder to "configuration old"
Note: "USER" is your Windows username. If you are unable to see the “Local Settings” folder, it may be possible that you don’t have explorer set to view hidden files and folders. In explorer, click on Tools > Folder Options, click on the View tab and enable “Show Hidden Files and Folders”. Click ok.
Posted on Mar 03, 2009
Tip
How to change filetype associations in Windows Vista, XP, 2000 and 98 fast and...
For Windows Vista There are two ways:Method #1 (on the fly):
  1. Right-click a file of the type you want to change, and select Properties.
  2. In the General tab, click the Change button.
  3. Choose a program from the list, or click Browse to select an .EXE file on your hard disk.
Method #2 (view a list of file types):
  1. Open Control Panel.
  2. In Control Panel Home, click Programs, and then click Make a file type always open in a specific program.Or, in the Classic View, open Default Programs and then click Associate a file type or protocol with a program.
  3. Highlight a file type in the list and click Change Program.
For Windows 2000 and Windows XP For Windows 2000 and Windows XP, the following steps are required to set Dreamweaver 8 as a default editor in Internet Explorer:
  1. Launch Windows Explorer (typically, you can launch this by choosing Start > Programs > Accessories > Windows Explorer).
  2. Select Tools > Folder Options...
  3. Select the File Types tab.
  4. Scroll to the HTM extension in the Registered File Types list.
  5. Click the Advanced button. You may have to restore the file association before you see the Advanced button.
  6. Select Edit from the actions list (not Edit within Dreamweaver), then click the Edit button.
  7. Browse to the Dreamweaver 8 executable. The default location for the Dreamweaver.exe file is: C:\Program Files\Macromedia\Dreamweaver8\
  8. Click OK until you are back at the File Types list.
  9. Select the HTML extension and repeat steps 5 to 8.
  10. Click OK.
  11. Restart your system.
  12. Open the Internet Options tool from the Windows Control Panel (Start > Settings > Control Panel).
  13. Select the Programs tab.
  14. Select Dreamweaver8 from the drop-down menu in the HTML Editor category.
  15. Click OK.
For Windows 98 For Windows 98, the following steps are required to set Dreamweaver 8 as a default editor in Internet Explorer:
  1. Open Windows Explorer (Start > Programs > Windows Explorer).
  2. Select Tools > Folder Options or View > Folder Options (both will open the same window).
  4. Scroll to the Microsoft HTML Document listing in the Registered File Types list.
  6. Select Edit from the actions list (not Edit with Dreamweaver), then click the Edit button.
  8. Click OK until you have closed all windows.
  9. Restart your system.
  10. Open the Internet Options tool from the Windows Control Panel (Start > Settings > Control Panel).
  11. Select the Programs tab.
  12. Select Dreamweaver8 from the drop-down menu in the HTML Editor category.
  13. Click OK.
please vote if this tip from is really helpful to u .. -shailendra
on Oct 03, 2010 | Computers & Internet
What is entry point in macromedia dreamweaver 8
If you mean, what skills are necessary to start using Dreamweaver 8?
You need basic html and css skills.
A great place to learn and where I learnt myself many years ago, is here:- http://www.w3schools.com/
Mar 01, 2014 | Macromedia Dreamweaver MX 2004 for PC, Mac
PoweReadACValue error
Probably it is cause due to power management system corruption
Try following steps
Perform a Clean Boot
If your computer is not starting normally, or if you receive errors when you start your computer that you cannot identify, you could consider performing a "clean boot." This operation starts the computer by using a minimal set of drivers and startup programs. This can help you troubleshoot the problem.
Method :Perform a Clean Boot
Step 1: Start the System Configuration Utility
1. Click Start, click Run, type msconfig, and then click OK.
2. The System Configuration Utility dialog box is displayed.
Step 2: Configure selective startup options
1. In the System Configuration Utility dialog box, click the General tab, and then click Selective Startup.
2. Click to clear the Process SYSTEM.INI File check box.
3. Click to clear the Process WIN.INI File check box.
4. Click to clear the Load Startup Items check box. Verify that Load System Services and Use Original BOOT.INI are checked. 5. Click the Services tab.
6. Click to select the Hide All Microsoft Services check box.
7. Click Disable All, and then click OK.
8. When you are prompted, click Restart to restart the computer.
Step 3: Log on to Windows
1. If you are prompted, log on to Windows.
2. When you receive the following message, click to select the Don't show this message or launch the System Configuration Utility when Windows start check box, and then click OK.
Note: Start Windows in Normal State
Steps to configure Windows to use a Normal startup state
After you used the clean boot to resolve your problem, you can follow these steps to configure Windows to start normally.
1. Click Start, and then click Run.
2. Type msconfig, and then click OK.
3. Click the General tab, click Normal Startup - load all device drivers and services, and then click OK.
4. When you are prompted, click Restart to restart the computer.
Sep 04, 2010 | HP Pavilion dv7-1130us laptop
How to download free macromedia dreamweaver in my computer?
Just jo the following link and download full version of Macromedia Dreamweaver 8.0 with serial for free.
No Cost.
100% Free.
http://freepaksoft.blogspot.com/2009/08/macromedia-dreamweaver-8.html
Jun 12, 2009 | Macromedia Dreamweaver MX 2004
How to download free dreamweaver in my machine?
use frontpage software coming along with MS office..
Apr 03, 2009 | Microsoft Windows XP Home Edition
Dreamweaver FTP Error
i would suggest that your server ip address has possibly changed. I would contact the people who support your server and ask them if anything has changed.
the fact that your website is up and running does not mean that the FTP should work. Very often your FTP server is physically separate to your web server
please rate this answer if it has been useful
thanks
trev
Feb 16, 2009 | Macromedia Dreamweaver MX 2004
Dreamweaver 2004 MX crashes
I think your Win is the source of the problem.
At first renistall your DW,
If your problem continue
Reinstall your OS
of course i suggest you to use some Optimize softwares, maybe they can help you
Nov 19, 2007 | Macromedia Dreamweaver MX 2004
How to make up a design using the dreamweaver?
Macromedia Dreamweaver for the first time, or on a new site for the first time, you need to define the Web site so that Dreamweaver can work with it. This process includes naming the site, placing the local files on a directory on your hard drive, and showing Dreamweaver where those files will be published on the Web. Follow these easy instructions to define a new Web site for Dreamweaver .
First, you should go to the "Site" menu and choose "Manage Sites".
As you can see from the image below, this will open a dialog window. Choose "New Site" from the "New" button.
Open Dreamweaver and Start the Site Definition Wizard
Name Your Site
Using Server Technologies on Your Dreamweaver Site
Where Should You Edit Your Dreamweaver Site Files
Defining Access to Your Dreamweaver Site
Always Test Your Connection
Site Check-out and Check-in with Dreamweaver
Review Your Site Definition
Your Site Now Appears in the Manage Sites Window
Start Editing Your Files in Dreamweaver
Oct 11, 2007 | Macromedia Dreamweaver MX 2004
Computers & Internet Logo
112 people viewed this question
David Payne
David Payne
