Question about JVC Handycam GR-DX77 Mini DV Digital Camcorder
Not working in windows vista
Jvc GR-DX77AS is not working when connected to a laptop with windows vista. Is there is any solution for this
  • Anonymous Jun 14, 2008
    preciso do drive para passar as imagens para o pc
  • Anonymous Feb 08, 2009
    I lost my CD for the product
Posted on Jul 12, 2008
Sir, I am unable to connect my JVC GR-D725E digital Camcorder to my new laptop?
Hi there, Make sure the software of your JVC installed in your new laptop. This will make them can communicate smoothly. Then Connect your JVC to new laptops and see the instruction on your laptop screen. If it is not works, find / explore your JVC directory manually. Good luck
Nov 21, 2010 | JVC GR-D290 Mini DV Digital Camcorder
Connect JVC GR-D240ek to vista laptop
Hi and welcome to FixYa,
A firewire to USB will not work. It has to be firewire to firewire. A JVC GR-D240ek uses 4-pin, IEEE 1394 compliant Digital Video Connector [DV OUT] to connect a 1394 cable (also known as a FireWire or i.Link cable) to a laptop equipped with an equivalent IEEE 1394 port. Please note that some laptops firewire port could either be 4 pins or 6 pins.
Soon as that connection as shown above is established, you can use Windows Import Video to capture / download the videos.
Other notes (from the same Windows Help link above) :
  • You can also open Windows Import Video by using Windows Movie Maker. After you connect ... your DV camera, and your computer, start Windows Movie Maker, turn on your DV camera, put it into playback mode, and Windows Import Video should open automatically.
  • You can also open Windows Import Video by using Windows Photo Gallery. After you connect ...your DV camera, and your computer, start Windows Photo Gallery, turn on your DV camera, and put it into playback mode. In Windows Photo Gallery, click File, click Import from Camera or Scanner, click your DV camera in the list of devices, click Import, and then follow the instructions.
  • You can also open Windows Import Video by using Windows Live Photo Gallery. (This options requires you to install Windows Live on your computer.) After you connect your...your DV camera, and your computer, start Windows Live Photo Gallery, turn on your DV camera, and put it into playback mode. In Windows Live Photo Gallery, click File, click Import from a camera or scanner, click your DV camera in the list of devices, click Import, and then follow the instructions.
Verify that the laptop's firewire port is 100% up to specs and totally compliant to IEEE 1394.
God luck and thank you for using FixYa.
Jun 18, 2009 | JVC GR-D240 Mini DV Digital Camcorder
I HAVE JVC GR-DX307 AS - how to save the video on my laptop or how to save it on dvd
To save the video on a computer, a firewire connections must first be established from the JVC GR-DX307 AS to the appropriate firewire port of the laptop (assuming it has one or through a PCMCIA firewire adapter card if required). In the camera, the FireWire/DV port is located beneath the mode dial on the left side of the JVC GR-DX307’s body. To access the FireWire/DV port, the LCD monitor must be first opened.
Soon as that connection is established, you can use Windows Import Video (Vista) to capture / download the videos.
Alternately, the A / V port of the camera maybe used to connect to a DVD Recorder for direct, realtime copying & burning. For the disc to be playable in another machine, it must be finalized.
Good luck and thank yu for using FixYa.
Jun 24, 2009 | JVC GR-D370 Mini DV Digital Camcorder
Will the jvc gr-d73e work with windows vista?
providing Vista correctly detects AVC-compliant firewire devices, /any/ camcorder which is compliant with this specification (hence has iLink/i400 connection) should work with it.
Jun 16, 2009 | JVC GR-D73E Mini DV Digital Camcorder
I am having the same problem PLEASE help!!!
ditch the usb cable and use the firewire. If Vista correctly detects AVC-compliant devices (pretty much EVERY firewire-equipped camcorder on the market!) it should "just work"
Jun 16, 2009 | JVC GR-D290 Mini DV Digital Camcorder
I need jvc gr-da30u camcorder software for windows vista
iF IT IS NOT ON THE JVC WEB SITE, i MAY HAVE MY OLD CD. (Sorry Baby hit key) I will look in a bit. send me your email.
Dec 31, 2008 | Sony DCR-HC19E Mini DV Digital Camcorder
I NEED A JVC DRIVER MODEL GR-D850AA
I found a Fix for vista with my GR-D850 jvc the Startech.com (3 port IEEE-1394 firewire PCI Card) works on vista when installed the pci card I was able to down lowed to windows movie maker with no problems.
I hope this helps
Aug 27, 2008 | JVC GR-D850 Mini DV Camcorder
Driver for GR-D70 for OS Vista
I can't find the drivers for JVC GR-D70 for windows vista .pls help me
Jun 07, 2008 | JVC Cybercam GR-D70 Mini DV Digital...
Gr-d73ag in Windows vista
did you go to conrol panel on comp under other hardware to see if it seeing hook up if not show it to
Feb 15, 2008 | JVC GR-D73AG Mini DV Digital Camcorder
JVC GR-DVL310 VISTA DRIVER
Your JVC is a MiniDV camcorder, which uses a Firewire connection for capture. Firewire drivers are standard for all DV camcorders, and built-in on every version of Windows since about Windows 98SE (well, they didn't work very well until Windows 2000).
You still need a capture application to complete the transfer. Most (maybe all) versions of Windows comes with Windows Movie Maker, which is a very basic program, but it can do this.
Normally, a DV camcoder can't be detected by Windows until you have it connected via Firewire, and have it the appropriate mode. On some cameras, this can be play or record (the latter would tranfer live video, or allow recording TO the camera), on others, you need to set the camera to a "link to PC" mode. I currently own Sony and Canon camcorders that both work in the former way, but my first DV camcorder was a JVC, and it did have to put in a "link to PC" mode to be detected by the computer. If you can't find the setting, you might want to check your user manual.
For still photos, it looks like you use a USB connection. I haven't found all the details on this camcorder, but this is likely to be a normal USB "storage class" connection. If so, your camcorder would show up like a disc drive, and you can drag photos over. Vista will support this by default, too.
The other way some older camcorders send photos is to appear to the system as a USB scanner type device. You would need a device driver for this, from JVC.
The user manual would be helpful here. You can get one via download if you don't have it:
http://books.jvcservice.com/booklist.asp?Model=GR-DVL310U
http://books.jvcservice.com/booklist.asp?Model=GR-DVL310UM
Jan 20, 2008 | JVC GR-DVL310 Mini DV Digital Camcorder
JVC Handycam GR-DX77 Mini DV Digital Camcorder Logo
323 people viewed this question
Top JVC Video Cameras Experts
Larry Stiles
Larry Stiles
Are you a JVC Video Camera Expert? Answer questions, earn points and help others
