posted by _s_t_e_v_e_ on Apr 15, 2008
ok when i turn my motorola l6 on it says searching for network and it does not find a network. i have tried being on the roof but still nop reception! is there anyway i can fix?
2 Other Users Have The Same Problem
Comment by vishesh120, posted on May 16, 2008
Comment by LIL Reggie, posted on Apr 25, 2008
i need your help
Best Solution
posted on May 14, 2008
Guest
Rank:
Apprentice
Rating: 0%, 0 votes
Rating: 0%, 0 votes
bang it against the wall...it works sometimes but makes it worse at other times
Rating Locked! (?) _s_t_e_v_e_ has rated this solution as Thanks for Trying
Solution #2
posted on May 13, 2008
As far as I am aware... The Motorola L6 uses the metal back plate as the aerial. Check the contacts to this plate and on the plate itself.
Hope this helps
Mowcius
Hope this helps
Mowcius
Was this solution helpful? Show your Appreciation by rating it:
Solution #3
posted on May 12, 2008
have you tried manually setting the network.
menu
settings
network
band - change it from auto to manual
if that does not help then takle the phone and have the antenna on the main-board service or replace
menu
settings
network
Suggest a new solution for this problem
Post a New problem for Motorola L6 Cellular Phone
Email this problem
Email this problem
Can you Help with these Cellular Phones problems?
NO MULTIMEDIA CONTROLLER
There is no sound on my laptop-... Answer This...
Repair Service
Find Cellular Phone Repairman Near You:
