Can not establish internet connection through my modem
    Problem Solver:
  • 15 Answers
Check with your provider the modem is compatible, try a different modem, to check if its the modem or just your internet!!!
Posted on Apr 15, 2008
I keep losing my internet connection though my modem stays connected
go to internet connections delete connections then search and establish new connection
Sep 03, 2012 | Arris...
My motorola SURFboard SB5101 has a on power light, a blinking recieve light, and an on PC/Activity light, with the other lights off. what is wrong with it?
The light pattern you have described indicates that the modem can not establish a connection to your internet service provider (ISP). This is typically do to a signal related issue. To trouble shoot the problem you will need to connect the modem directly to the main cable line where it first enters into the home. You will know when the modem establishes a connection by the top 4 lights becoming green. If at any point all 4 top green lights start to blink in sequence than you will need to contact your internet service provider to "unwall the modem". Remember most internet service providers require you to register your modem on there network. So if you have not all ready completed that process you will most likely not have access.
I hope that information above has helped is some way.
If possible please rate this solution.
Sep 01, 2010 | Arris SURFboard SB5101 Cable Modem
When i reset my modem it goes through the normal start up process but when it is trying to connect online the lights start flashing.(receive &send ) lights flash.
The light pattern you have described shows that the modem can not establish a connection to your internet service provider (ISP). This is typically do to a signal related issue. To trouble shoot the problem you will need to connect the modem directly to the main cable line where it first enters into the home. You will know when the modem establishes a connection by the top 4 lights becoming solid green. If at any point all 4 top green lights start to blink in sequence than you will need to contact your internet service provider to "unwall the modem". Remember most internet service providers require you to register new modems on there network. So if you have not all ready completed that process you will most likely not have access. If you can not get a connection from the main line than there is a issue with either the modem or the signal coming into the home and you will need to contact your internet service provider.
Aug 31, 2010 | Arris SURFboard SB5101U DOCSIS 2.0 Cable...
My motorola SB5101 cable modem is connected properly. The power light is green but the receive light is keep on blinking other lights was turn off (send, etc.). Does my modem has a problem?
This light pattern indacates that the modem can not establish a connection to your internet service provider (ISP). This is typically do to a signal related issue. To trouble shoot the problem you will need to connect the modem directly to the main cable line where it first enters into the home. You will know when the modem establishes a connection by the top 4 lights becoming solid green. If at any point all 4 top green lights start to blink in sequence than you will need to contact your internet service provider to "unwall the modem". Remember most internet service providers require you to register new modems on there network. So if you have not all ready completed that process you will most likely not have access. If you can not get a connection from the main line than there is a issue with either the modem or the signal coming into the home and you will need to contact your internet service provider.
Aug 29, 2010 | Arris SURFboard® SB5101 Cable Modem
Motorola modem light wont go past send
Aug 19, 2010 | Arris SURFboard SB5101 Cable Modem
HOW TO CONFIGURE MODEM OF PARADYNE(ADSL 2+)
Basically if your Internet service is DSL or cable it's just a plug and play. Just plug the computer to the modem once the Internet access has been activated by your ISP and your computer should automatically get connection from the modem.
Aug 16, 2009 | Paradyne (6211-A2-200) Router
Pvs connection
I had AT&T internet service with the 2-Wire wireless router (combined modem and router). You probably might have been given an installation CD but that often does not work well. You should be able to interface directly with the modem or router with your web browser possibly (http://gateway.2wire.net), and see the status of the connection, although to talk to these devices you must put in a username (usually "admin") and a password to enter the interface.
Your best bet is to actually call the technical support for the Internet service. Look on the AT&T paperwork you go with the modem or modem+router or any billing statement that show the possibly 877 number for HighSpeed Internet technical support. They will walk you through step-by-step until you get your connection; listen carefully to the often heavily accented voice. It usually never fails.
Nov 08, 2008 | 2wire 1800HG Router (RG1800HG00)
THE internet is coming up internet explorer can not be connected, when it's wireless. we can plug it in and then the internet comes up.
you have to configure your wireless modem (wep/wpa) so that your laptop can connect to the internet. the reason why you cannot connect in the internet thru wireless is that the connection between the modem and the laptop has not been established. so, try to establish the connection between your laptop and the modem.
Apr 01, 2008 | Computers & Internet
Zoom ADSL X6 Modem "Link" Light Suddenly Blinks Continuously
the modem may have gone faulty so if your isp provided it ask them to replace it if the modem is in warranty period and if your isp provides internet connection through the phone line then first please try plugging the modem on main socket in with an adsl filter plugged in and if this is not the case then problem is definately the line through which the broadband signal come to your place which is suppose to be sorted out by your isp.
Mar 12, 2008 | Zoom X6 (5590) DSL Modem (55900003)
Internet connection
I think your modem needs to be configure by your ISP.
I change my modem here in my house with other brand and did'nt work, so i put the original modem i used and it works again..
Nov 13, 2007 | Siemens SpeedStream Modem (4100) (SS4100)
Computers & Internet Logo
98 people viewed this question
David Payne
David Payne
