Question about Car Audio & Video
Hooked up my ipod to my Kenwood KDC 8534 and it is trying to load and then gives error 60. This ipod had been working fine with this head unit.
    Genius:
  • 1,142 Answers
Give me the model and the year when purchased
Posted on Apr 15, 2008
  • Maanita Chadha
    Maanita Chadha Apr 15, 2008
    Try to de-attach the stereo from the car and leave it unplugged from the power source for an hour then reconnect it the bios will be reset and the error will not popup.
    Please let me know the result and if fixed dont forget to rate fixya
Kenwood KDC-BT558u drains 640 constantly from the Battery even when the unit is off!
check the wire harness connections, sounds like you have KOER power hooked to KOEO. Or in other words, you have power to the radio with the key off that should connected to key on power
Jan 06, 2015 | Kenwood Car Audio & Video
I purchased a Kenwood KDC- MP345U and my Ipod touch version 4.0.2 used to work fine in the stereo. Now it only reads and then gives me an IPOD error. I have tried other Ipod products and they work fine. I...
i had a similar issue only mine read the song title and everything but just gave no sound. i called up kenwood and the solution for me was take the ipod (5th gen nano) turn it on, flip the hold switch on then off, then press and hold both the menu and center button of the scroll wheel until the apple logo showed up and release them. wait for it to go back to the menu and plug it in. fixed my problem. they said it was something w/ the ipod not connecting properly or something. hope this helps a bit
Oct 01, 2010 | Kenwood KDC-MP342U Car CD Player
I want to hard wire (not using any kind of wireless gadget) my ipod in to my car to the Kenwood KDC 334 CD player which is installed. I have pulled the Kenwood unit out and there is no obvious connection,...
The KDC 334 doesn't have any audio input, so there's nowhere to hardwire an iPod or other mp3 player into the unit.
I'm sorry, but the only way to get iPod sound to come through this head unit is with a wireless gadget like the iTip FM adaptor.
Feb 18, 2010 | Kenwood KDC-334SA CD Player
Kenwood kdc-mp532u Auxiliary?
http://inform3.kenwoodusa.com/manuals/KDCX590.pdf - Manual
iPod Adapter Compatible: Using the KCA-iP500 iPod Control Interface, you can connect your Apple iPod digital music player to this receiver. The interface (item # 113IP500) plugs into the receiver's 13-pin CD changer input and controls the iPod through the receiver's controls, as well as displays the iPod's text information right on the receiver's display.
Dec 30, 2008 | Kenwood KDC-MP532U
Usb signal error on kdc x-991
I had the same problem. Unfortunately with the IPOD Unless you can give it extra USB power, it is unfortunately not enuff from the Kenwood's deck. I had ran a 100gb HDD in an enclosure...I thought great its working...worked fine for.....20-25 mins....
And started getting the USB Read Error...or something to that extent...I forget now. So I tried about 2 or 3 different enclosure that did not need extra power (or should not need extra power to run the drive, and no luck. So anyway I went to fry's and picked up a USB to Cigarette adapter and now all is well...The adapter cost me $10...
I have 3 external drives that now work. The only other thing that you might look at for the IPOD, is getting a cable that has 3 heads....
One going to the USB Port on the Kenwood, and then there's two more heads that split off the other tip one for the ipod and then it y's off to another usb, plug that into the USB power adapter from fry's and that might give you the extra power you need...( I can't guarantee this as I dont own an IPOD and probably never will unless someone gives me one for free.)
Dec 26, 2008 | Kenwood KDC-X991 CD Player
Can't eject cd magazine - E-99 error message
I had the same problem. I opened up the unit and found out that there is a plastic gear that moves the loader. When worn the loader can not load tha magazines nor change cd's. I replaced the gear and the cd autochanger worked fine.
Gerald,
Kenya.
Dec 01, 2008 | Kenwood KDC-C717 10-Disc CD Changer
Ipod
On the Kenwood models that are within about 6 or 7 years old or newer, there is an iPod adapter for the head units that plugs into the CD Changer port on the back of the radio. Kenwood makes an adapter (KCA-IP500) that gives direct control and charging through the radio and several companies make aux input adapters for Kenwood radios that will connect to the iPod's headphone jack.
Sep 21, 2008 | Kenwood KDC-3024 CD Player
Ipod nano
IT does not support Nano yet get ipod classic 80gb play all music and videos. I have been told in two three months KW will come up with softwerar update for Nano.
Nov 13, 2007 | Kenwood DNX7100 Car Video Player
IPod Interface not working
That happened to me and the PFD Manual online said it means it's a communication error between the ipod adapter and the ipod. The ipod in my case was totally froze and I had to reset it using the hold on off then holding in menu and select for 10 seconds and it rebooted.
Sep 24, 2007 | Kenwood DPX-501 CD Player
Error message E-60
First, run a chkdsk (or scandisk) to your Ipod from your computer (like any other hard disk drive on your computer)since it is probable that the Ipod's hard disk drive may contain errors. Then, follow these steps: 1.) Disconnect the Ipod from the KCA-IP500(the Ipod interface) 2.) Press and hold the middle button and the top button at the same time. 3.) The Apple Logo should appear. 4.) Reconnect your Ipod to the KCA-IP500 5.) The head unit should display loading and then respond to the IPOD interface.
Nov 08, 2006 | Kenwood KDC-MP232 CD Player
Car Audio & Video Logo
88 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
