Question about Gateway FPD2275W LCD Monitor
Hp 1730 - black screen .. or almost black
Hi, I've got the same problem where the screen is switched on but it is almost completely black. I can see something is going on, but its too dark to even read anything on the scree. It sounds like you had the same problem.
Please let me know if you were able to fix it and what you did.
Thanks, et
  • mungloria Jul 11, 2008
    I have a TFT/LCD samsung syncMaster 153v monitor. It is powered and the LED is on but is not blinking and the screen is completely black
    steps taken:
    I changed data/VGA cables but to no avail.
  • 472 Answers
Your problem is in the inverter circuit. But the problem with these is normally easy to fix. It's the capacitors in the power supply board that need to be replaced rather then a direct repair to the inverter circuit.
If you have good electical knowledge then you will already know how to do this repair.
If not, then its best left to someone who does like your local TV repairman. The voltages inside LCD's go far above what you have comming from your power outlets in the house.
It should not cost a lot to have taken care of though by a professional. Call around and get a few rough quotes.
Posted on Apr 16, 2008
Hp pavilion zx5000 power up but black screen
My suggestion would be to unplug the cord from the connection on the
computer, then remove the battery. After you've done that, press and hold the
On/Off switch for about 60 seconds, then, after you've done that connect
everything back together, and see if it will reboot. If not, check the hard
drive, and the ram and make sure they are all connected tightly.
Oct 17, 2012 | HP Pavilion zd7000 zx5000 zv5000 presario...
Cant display
There might be a problem with the resolution. Check the cover or box of your monitor and find the resolution.
With me the screen goes black when i start any game of higher or lower supported resolution
Sep 23, 2012 | HP 17" 1730 DVI LCD Monitor w/Speakers...
HP 1730 driver windows 7
what i know is that monitors don't need drivers. if your monitor is new then i believe it is already windows 7 ready.
what you need to do is check the VGA cable if it is damaged. try replacing a new one. Hope this helps.
Jun 21, 2012 | HP 1730 LCD Monitor
I have a (HP L1730) flat panel monitor that im trying to use with my HP Compaq 6910p Laptop. When I power on the monitor,there is a quick 1 second flash of my desktop on the screen,then it goes to a black...
Does it do the same when it is hooked up to desk top PC?<br /> <span style="FONT-SIZE: 10pt; FONT-FAMILY: Arial"><a href="http://s807.photobucket.com/home/budm/allalbums">http://s807.photobucket.com/home/budm/allalbums</a></span><br /> <span style="FONT-SIZE: 10pt; FONT-FAMILY: Arial; mso-fareast-font-family: 'Times New Roman'; mso-ansi-language: EN-US; mso-fareast-language: EN-US; mso-bidi-language: AR-SA"><a href="http://en.wikipedia.org/wiki/Capacitor_plague">http://en.wikipedia.org/wiki/Capacitor_plague</a></span>
Aug 24, 2010 | HP 1730 LCD Monitor
Hp 1730 monitor went black
if after few seconds of display and then the while display turn black, this is the indication of failed capacitor on the LCD circuit board...
you will need to have some technical skill to replace the capacitor.
Jun 21, 2010 | HP 1730 LCD Monitor
My hp 1730 lcd screen is making a humming sound which seems to get lower when i turn down its brightness but doesnt go away any suggestions?
That sounds like the inverter that powers the back-light. Unless it's really annoying I would just live with it. It's probably more expensive to repair than to buy a new similar sized screen.
Oct 08, 2009 | HP 1730 LCD Monitor
Gateway monitor FPD 1730: We have had it since
If the screen is black (ie there isn't any backlight) then the fault maybe the inverter board that supplies high voltage to the CCFL lamp ot the CCFL lamp is faulty.
For service, parts and DIY info. check out LCD Parts - use this link to their WEB site.
www.lcdparts.net
Sep 28, 2009 | Computers & Internet
Monitor comes on momentarilly, then screen turns black. when power is turned off and back on again, screen comes on for a second, then goes black again. Is this a bad monitor?
The only problem that causes the power on and off is a bad power supply. Go onto http://www.ebay.com and search for the monitor (power supply). My dad's old LCD screen had a bad power supply, but I found my old printer power cable (HP PSC 750 All-in-One Printer), and the monitor turned on successfully. It's not a bad monitor, unless the PSU hookup is like the PC ATX/Baby-AT PSU cable, then it might be the issue. Monitors before 2004 or 2005 have the ones, like the HP PSC 750 uses. The monitor is either defective, or the power supply is dead.
p.s.: check the voltage, amp usage, etc. on the PSU for the monitor for better results.
Aug 28, 2009 | Gateway FPD 1730 17 in. Flat Panel LCD...
My hp 1730 monitor remains black. I can faintly see the display, close-up, but it is close to black. I just tried it on my other computer and it still does not work
The screen finely went out and it cant display any more. is it old? do you leave it on alot?
The screen probably burnt out. Or you just have the contrast or brightness turned all the way down.
Check these
Dec 04, 2008 | HP Computers & Internet
Gateway FPD2275W LCD Monitor Logo
209 people viewed this question
Top Gateway Computers & Internet Experts
Prashant M
Prashant M
Matthew Spark
Matthew Spark
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
