Question about Dell Dimension 4600 PC Desktop
Windows media player
Hi I have just formated my pc & reinstalled xp home. Using windows media player I tried to play a film I downloaded but it only plays the sound how do I find out what codex I need to play film, (avi)
thanks graham
    Scholar:
  • 106 Answers
To Update Your Windows Media player download the K-Lite codex which will come with its own player and its better than VLC player, the only advantage VLC has is that one can easily integrate subtitles of all formats, other than that K-Lite is better. Hope it helps, Goodluck =)
Posted on Oct 29, 2011
    Master:
    Sergeant:
  • 460 Answers
Please download the player named VLC from www.download.com as it is a freeware and plays all codecs. Mind it, this is not a codec for Media Player.
Hoping a good rating from you.
Thankyou
Posted on Apr 15, 2008
Windows media player won't work
Which operating system ? Which version of Media player ?
Though designed with Windows 7 in mind, Windows Media Player 11 (WMP 11) is fully compatible with Windows XP.
The trick is knowing which version of WMP 11 to download.
Different versions of the software exist not only for Windows 7, Vista, and XP, but also for both 32-bit and 64-bit Windows XP.
Additionally, WMP 11 is only compatible with XP if it is using Service Pack 2 or Service Pack 3. Before downloading the appropriate installation file, you will need to verify which version your system requires.
Open the "Start" menu.
Open "My Computer."
Click "Help", then select "About Windows."
This will display a window with system information.
Find the listing that specifies your Service Pack. If you are operating without Service Pack 2 or 3, you will need to install one (see Resources).
Open the "Start" menu and click "Run." Within the text field, type "winmsd.exe."
Click "OK." Select "System Summary."
Find the heading labeled "Item."
Under this heading should be the word "Processor."
The value associated with "Processor" will determine which version of Windows XP you are running.
If the value begins with "x86," you are running a 32-bit version.
If it begins with "ia64" or "AMD64," then you are running a 64-bit version.
Download the Windows Media Player installation file that matches your version of Windows (see Below).
http://windows.microsoft.com/en-US/windows/downloads/windows-media-player
Open the file once it has finished downloading.
This will launch the installation wizard.
Follow the onscreen instructions to install WMP 11.
The program should now run normally.
How to Fix Windows Media Center
Windows Media Center is the home entertainment hub on a Windows computer.
With Media Center, you can play live television, songs, DVDs and slideshows.
It is preinstalled on Windows XP Media Center Edition, Windows Vista Home Premium/Ultimate Edition and Windows 7 Home Premium, Professional, Enterprise and Ultimate editions.
From time to time, users run into issues trying to play audio or video files, or with an extender connected to Media Center.
Extenders are devices that allow you to "extend" the Media Center onto a TV screen or larger display.
The Xbox 360 gaming console is an example of an extender.
Launch Windows Media Center from your computer's Start menu.
Scroll down to "Music" on the Media Center home screen.
Select "Music library."
If you find an empty folder under "Music Library," navigate to the folder on your hard drive that stores your music file and add it to Media Center's library.
If the problem isn't an empty folder, look at the file extension on the music file that won't play. Media Center can't play files with unknown or incompatible extensions.
If you find a questionable extension, skip that file. Click once on another file with a different extension, one you know is compatible with Media Center, and then click "Open" to test if you can play that one.
Media Center will play MP3, CDA, WAV and other music file formats.
Open Windows Media Player from the Start menu if you receive a codec error while trying to play either audio or video files.
If you open the file in Media Player, the codec will download automatically.
You should then be able to play the file in Media Center.
Troubleshoot your firewall settings if a Media Center extender doesn't work.
You'll have a problem using an extender if Windows Firewall blocks it.
Go to "Control Panel" from the Start menu and double-click on "Windows Firewall."
Click on "Allow a program or feature through Windows Firewall."
Click to check "Media Center Extenders."
Click on "Apply."
Check external speaker cables to make sure they're connected if you can't hear any sound. Check the computer's volume settings by clicking on the "VOL+" icon at the bottom right corner of the main Media Center screen to make sure the volume is not turned off or down too low.
You may need to reconfigure your speakers if you're having volume or sound issues.
Scroll down to "Tasks" in the Media Center home screen and select "Settings."
Click on "General" and select "Windows Media Center Setup."
Click on "Set Up Your Speakers."
Follow the on-screen prompts to reconfigure your speakers.
Dec 01, 2013 | Gateway ONE GZ7108 All-in-One Desktop PC
My media player want play dvd's
Maybe your screen resolution needs to be higher? What type of error message are you getting? Are these dvd's that you were able to play before?
Most computers will have problems playing dvd's that someone made for you on their computer. Try a store purchased dvd and see if it plays.
You can always reinstall windows media player at Microsoft's site below.
You can also try the VLC Player. It comes with drivers and codec. I've seen it solve a lot of issues that Media Player could not fix.
Try using VLC as your player. Go to www.google.com and in the search box type "download vlc" (without the quotes). Look for the Video Lan download from site www.videolan.org/vlc Download and install it. It downloads and installs in 3 minutes or so. It's a very fast player, smooth and it can play just about any type of dvd formats and media. It's totally FREE.
May 11, 2012 | Everex eXplora RS2800 PC Desktop
My dvd wont play in my media player
hi, make sure your play vedio cd.
if still can't, upgrade your media player or reinstall then install klite 5.
Dec 31, 2011 | Microsoft Windows XP Home Edition English...
I can't open short films from a USB stick, which were downloaded from my camera.
if you are using windows media player you are most likley tryinh to play a unsupported format. VLC media player plays just about every video format download and install that. then play your files with vlc media player by opening vlc then click the media tab the open media then locate your video and double click it
Apr 02, 2011 | Samsung R540 Laptop
Does not work for video files. AVI in Windows Media - player Vista 32
To play the avi files. you can try to options.
1. You can download a different media player which is VLC media player. It plays almost all kinds of video format.
2. Download K-lite codec and run it and you should be able to play .avi files in media player.
Hope it helps :-)
Feb 10, 2010 | Microsoft Windows Vista Home Premium for...
DVD plays video but no sound on Windows XP
download the codecs from the web link given below and install it and issue will be resolved
http://www.free-codecs.com/download_soft.php?d=4875&s=95
Dec 13, 2008 | Microsoft Windows XP Home Edition
My Acer Aspire 5315 does not play DVD films.
to play dvd films, ensure your laptop has a media-player installed. i.e windows media player 9-10-11 et,c. also you could check in My computer/control Panel/system/device manager to see if there any yellow exclamation marks, next to any devices. if there are. you,ll need to re-install drivers for the device.
if this solves your problem, please rate as fixya.
thankyou for using the forum.
Mike @ compurepair.
Nov 16, 2008 | Acer Aspire 5500 5570-2609 Laptop
Watching films,videos on my pc
Which format are the films in. I've used vlc and had problems and I have a duo core 1.6ghz 1024mb ram 100gighd 32mb vid
Even AVS video player hangs a bit, DivX works OK plays everything but DVD.
Apr 22, 2008 | Computers & Internet
DVD/CD RW
Hi there
Is this problem with windows media player only or with rest players also.
You try to repair your media player using your XP installation CD and then install a good codec pack such as XP codec pack or K-Lite codec pack.These are available for free .
Hope this works for you.
Waiting for your thanks.
Feb 14, 2008 | Microsoft Windows XP Professional With...
Not playing music
No Music Files Problem solved
Plug the MP3 player to PC
In Windows XP open Windows Explorer and navigate to one of the music files
Try to play the file in Windows
If it fails, unplug player and once the player switches off carry out a reset
Reconnect player to PC and repeat the process described above
You may need to repeat this several times until the music file plays in Windows.
After this format the player using Windows XP
Select the removable hard drive, right click and select format
Choose Fat32, enter a volume label (for example GMP33005) and select quick format
If formatting fails try several times
Once format is succesfull reload your music files using the software that came with the player
Be careful not to exceed 2.5 or 2.6 GB (leave some free space as this might be needed for the player to work)
The player should now play the music files correctly
Sep 22, 2007 | Audio Players & Recorders
Dell Dimension 4600 PC Desktop Logo
151 people viewed this question
Alun Cox
