Question about E-Machines etower 400i3 PC Desktop
Motherboard 62-314E-041999-0010111-071599-440LX-FLORIDA C
I NEED A SCEMATIC DIAGRAM FOR JUMPERS AND CON** . I HAVE UPGRADED(FRONT USB,HDD,CPU FAN,POWER SUPPLY AND DVD ROM)AND LOST TRACK OF WHAT PLUGGED IN WHERE =( PLZ SAVE ME
sandrew
  • 2961 Answers
SOURCE: T2893 Motherboard Layout - Where do the power jumpers go?
go to this link for the information you need http://www.intel.com/design/motherbd/sr/sr_con.htm#IC
Posted on May 06, 2007
LadyTech99
  • 141 Answers
SOURCE: Emachine flashing yellow lights, fans power up when P8 is unplugged
Did some research and found this site which will tell you which pins to test. It is possible also that its not powerful enough for the devices you have. I would try again only giving power to the motherboard pins, of coarse and the hard drive. If works then plug one device at a time.
Good luck
http://articles.techrepublic.com.com/5100-10878_11-1046822.html
Posted on Jul 05, 2008
tbirdfan1
  • 3051 Answers
SOURCE: Gateway 3310
are u having any beeps at all if not unplug the power supply cord and look at the wires that go from the power supply to the mother board and plug the powercord back into the powersupply and try to start the pc if the powersupply still does not start the fusible link in the power supply probably has blown depending on what kind of power supply you have some of these fuses are replaceable as long as they are not soldered i just replaced the one for my dell saved about 130 bucks please keep me posted on this if you get anywhere ok best regards mike
Posted on Aug 12, 2008
  • 233 Answers
SOURCE: Emachine W2047 No BIOS Start Screen
You can test the power button. Remove the wires from the power on pins on the motherboard. Momentarily jump the two pins with a small screwdriver. If the computer starts the power button is bad. If it still doesn't start then something else is wrong. Did you test the memory? Also do all of the fans work, especially the CPU fan? It can't hurt to test with the other PSU. You know the HDD is good. Test one piece of hardware at a time and hopefully you will find the problem.
Posted on Jan 07, 2009
mojeda92
  • 24 Answers
SOURCE: Need wiring diagram for eMachine 20030812 motherboard!!!
You should be able to see the words/letters that go with the jumpers on the motherboard itself. look around the jumper settings area for power, pwr etc. and match them up with your jumpers which should have what the go to on them.
Posted on Apr 10, 2009
I have bought a few new computers from electronic discount sales off ebay and i have had off the wall issues with them from post errors telling me tuning has been reduced on hdd to not booting off usb that...
Marvelous description, but you can only fit parts that have the same socket on them. As long as you remember that, you will be okay. For CPU and motherboard information (compatibility) try CPU upgrade website and for CPU spec and sockets try CPU world (both run by the same people) very well designed sites and informative. The other stuff comes with experience, although you could try a book such as computers for dummies or buy a magazine such as Micro mart (weekly) as it reviews new and old kit and has a very good help section.
Oct 02, 2013 | Intel D865GLC Motherboard
I don't know how to plug in the wires for the ASUS a8n sli deluxe motherboard
Here is the manual for your motherboard (since describing a diagram probably isn't very useful...)
http://dlcdnet.asus.com/pub/ASUS/mb/socket939/A8N-SLI/e2024_a8n-sli.pdf
You want to look at pages 27-35, they describe what you need to plug into the motherboard. Basically make sure you have connected:
1) 24-pin power cable (from power supply)
2) 4-pin power cable (for CPU from power supply)
3) Any case fans with 3/4 pin connectors.
3) hard drives (SATA or IDE)
4) USB front panel ports
5) Audio front panel ports
6) Case plugs (power LED, hdd LED, power switch, and reset switch).
Apr 19, 2011 | ASUS A8N-SLI Deluxe Motherboard
Motherboard won't boot up cpu fan comes on hdd
Just after that there was NO correct answer to fix this problem causes the problem not solved even if it is marked as solved. Me too I have this problem, I was fix it by setting jumpers to default 60 Hz AC power because I won`t have 50Hz AC power or some AC power converter before PSU, I mean this is voltage errors, it`s need to be set to default +5V(60Hz) PSU not +5VSB(50Hz) PSU, (Step1) like might be set to USBPW12 to pin 3 both USB to right side inserted jumper it`s in left side of, near ATX 12v advanced CPU power cable connection socket. Next (step 2) is set up front USB jumpers to +5V or system won`t start up, it`s on motherboard about between PCI1 and PCI2 on right side it must be set to USBPW56 and don`t set it to USBPW78(5+VBS) because system won`t start up, the jumper must be set to right side I mean it`s last jumpers to right side need to be set up, because it`s +5V(60Hz) PSU supply. The USB wake-up feature requires a power supply that can provide at least 500mA on the +5VSB lead when these jumpers are set to +5VSB otherwise the system won`t power up. Next step if it still not starts up its BIOS fault, it`s easy to repair, just (Step3) turn off PC remove BIOS battery (it`s down to IDE cables), start it up wait a bit, then turn it off and turn it again on wait a bit again, turn it off place BIOS battery in to socket to be able save BIOS settings i mean battery is need to save them otherwise settings won`t be saved and Chassis will be broken. (Step 4) Turn PC on press del key after BIOS is load in open Power\Hardware monitoring\Chassis Intruder set to Disable, save settings exit. (Step5) If BIOS (PC won`t power up) it`s Chassis1 jumper fault, it`s need set to Default (Chassis signal, and GND(Ground)), it`s between SATA 2 and SATA1(Serial ATA connectors 7-pin it`s near and down to BIOS battery, the jumpers might be set to right side, after it`s completed repeat Step3 and Step4. CMOS is BIOS battery. If that all doesn't works Take BIOS clearing jumper in it`s clear state, near BIOS chip. Turn on PC with CMOS clear jumper turned on its work. Take beck jumper in its default state after that take bios chip out and CMOS battery out both them an two times restart PC after insert all beck if PC will be working all keyboard flashes once, after its in AC power.
May 07, 2010 | ASUS P4P800-VM Motherboard
Hi all i have a asusp4p800 motherboard that was on and working till i shut it off to add more mem,and new video card,now when it boots up it wil stop at the asus bios screen unless i unplug the hard drive...
hallo friend
you should remove hdd ID cabals and after that hard disk jumper chak first jumper Hdd master and sacud jumper cd-rom jumper slave
so please chake hear
Aug 15, 2009 | ASUS Computers & Internet
ECS P4IBMS Motherboard CPU Voltage Jumper Settings
I don't believe that there is a P4 motherboard that needs jumper setting to specify the CPU voltage. This used to be common for Pentium & Pentium II motherboards, & some Pentium III motherboards. But I have never seen a Pentium 4 motherboard that require this kind of setting.
Besides, I checked the motherboard's manual & I saw that there is a sub-menu in BIOS labelled "Frequency/Voltage Control". This should be the place where the CPU voltage should be set, & on most motherboards, CPU voltage & frequency are automatically detected.
Jun 20, 2009 | EliteGroup ECS P4IBMS Socket 478pins...
Apr 10, 2009 | E-Machines eMachines Refurbished EMA...
No start-up...
first install your graphic card drivers for sure and second check the jumpers settings on mobo after you let me know again please... and dont forget to use a non usb/wireless keyboard to get in the bios with, sometimes that does it ...?
Oct 21, 2008 | MSI K8N NEO2-Platinum (MS7025) Motherboard
Gigabyte Slot 1 GA-6BXC Start Up UnStable
I recommend that you formatt your HDD to a FAT32 system probably by using another pc then you should also ensure that your bios is setup for the appropriate operating system. maybe just download the appropriate bios files off the gigabyte web site.
May 27, 2008 | Gigabyte Slot 1 GA-6BXC Motherboard
Soltek SL-86SPE-L CPU upgrade issues
Maximum you may go upto 2.4 GHZ. [p4]. Not dula core etc.
Best Regards
Rafique
Feb 17, 2008 | Soltek SL-86SPE2 Motherboard
E-Machines etower 400i3 PC Desktop Logo
70 people viewed this question
Top E-Machines Computers & Internet Experts
Alun Cox
Are you an E-Machines Computer and Internet Expert? Answer questions, earn points and help others
