Question about Samsung SF-560 Plain Paper Laser Fax
Samsung SF560 Message reads "toner empty". Replaced new toner cartidges and still get same message. have change toner in fax but getting message (jam 1) or toner empty it seems pretty common problem as others users have the same!
  • Anonymous Mar 31, 2014
    Had a compatible toner already in machine, replaced with another compatible one, after 2 days red warning light with warning "Not compatible toner cartridge". have tried original samsung and getting same message
  • 4 Answers
Check to make sure the Toner Cartridge is not for a SF-560R. They look the same but the fuse that lets it know it has been replaced is in a different location.
Posted on Feb 17, 2009
  • 97 Answers
Turn off the Machine for safety.
- Try to double check if the toner cartridge is properly installed
- Clean it also if dusty
- Make sure he sensor have no paper or dust.
Posted on Sep 23, 2008
Paper jam 2 but no paper is stuck
Most printers/faxes need more than one or two sheets of paper in the hopper in order for printing to commence. If it's not that, take out all paper. Turn off the printer/fax. Wait five minutes and turn printer/fax back on. With some printers/faxes, that almost acts like a re-boot. Good luck!
Mar 28, 2012 | Samsung SF-5100 Plain Paper Laser Fax
Samsung CLP 315 invalid toner message
the best thing to do is buy the original toner. how ever if u really can't then try changing the blue colored one
Jul 29, 2017 | Samsung CLP-315 Laser Printer
Fax machine Samsung Inkjet Fax SF-360. Ink was finished so ordered the correct ink cartridge and replaced it now on the screen it tells us to install ink cartridge. I have tried severeal times and i know...
If the Toner Low/Empty message does not automatically clear when a new cartridge is installed, use the following to clear the message manually:
1.Press MENU # 1 9 3 4. The machine should display TECH.
2.Press MENU, and ENTER. The machine should display TECH Mode.
3.Press the left arrow < once. The machine will show NEW CARTRIDGE.
4.Press ENTER, the machine will show YES.
5.Press ENTER, there should not be any Toner Low/Empty message.
6.Exit TECH MODE, press MENU # 1 9 3 4. The machine will no longer display TECH.
If Toner Low/Empty message continues, there may be a problem with the toner cartridge or the machine.
Jul 21, 2010 | Samsung SF-5100 Plain Paper Laser Fax
SCX-4521F All-In-One Laser Printer: toner empty after replacing new toner of samsung s...
Clear/reset the settings on the printer. Press in this order w/o pausing:
menu
193
start
If you do it correctly, the LED will say "Select Country, US", then you press "OK", then it will clear the settings and the error message should go away unless you have a dirty sensor or your toner is installed incorrectly.
Good luck-
May 18, 2010 | Samsung SCX 4521F All-In-One Laser Printer
Can't receive fax but can send fax
I have a feeling that it is a re-manufactured or compatible cartridge??
There is a fuse that needs to be replaced on this unit. it blows when the cartridge is installed to reset the machine. If the fuse has not been replaced or is defective the machine will not recognize the new unit.
Feb 12, 2009 | Samsung SF-5100 Plain Paper Laser Fax
Samsung MFC-SF560 fax not printing complete page
If you have already try another image unit, you should try to make a copy or print a report. If the prints came out ok, the problem could be the telephone line. GOOD LUCK.
Nov 21, 2008 | Samsung SF-560 Plain Paper Laser Fax
Samsung SF560 Laser Fax
in the box with the new toner cartridge was there a credit type card to use when changing the toner to reset the toner counter?
read the instructions in the box :p
May 23, 2008 | Samsung SF-560 Plain Paper Laser Fax
Samsung SF560 error message door open & jam, no toner.
I have put a new toner in and it says "[jam 1] or no cartridge" please help this is an office fax and desperately needs to be working.
Many thanks,
Adrian.
Apr 15, 2008 | Samsung SF-560 Plain Paper Laser Fax
TONER EMPTY MSG
1-remove power from fax.
2-clean contact points in toner cartidge and the contact in fax which it make contact together.
3-knock above toner cartidge many times.
4-move it in horizontal direction from left to right many times.
Feb 25, 2008 | Samsung SF-5100 Plain Paper Laser Fax
Samsung SF560.
Check if there is a fuse in place (usually fitted to the front edge of the cartridge) and always replace when refilling.
Aug 31, 2007 | Samsung SF-560 Plain Paper Laser Fax
Samsung SF-560 Plain Paper Laser Fax Logo
898 people viewed this question
Top Samsung Office Equipment & Supplies Experts
mukhtar21 shaikh
mukhtar21 shaikh
HEMANT GROVER
Victorman
Victorman
Are you a Samsung Office Equipment and Supply Expert? Answer questions, earn points and help others
