Question about GPS
Requier manual for Triton 300 - GPS
  • 515 Answers
  • E61N
    E61N Apr 15, 2008
    Please remember to rate.
    Thanks...
Magellan gps Triton 300 series Jamed up; Reads when turned on ; Internal Error Your Triton has encountered an unexpected error and must shut down. Please wait while your data is saved.
The problem with your magellan triton is that there is a file missing in the support file that allows the triton come on properly hereby leading it to jam.
The solution is for you to get your triton connected to a computer, then you back up the software on the computer, format the triton then you restore the software and maps on the triton. Then your triton will be in good condition once again.
Hope this information helped.
Jan 03, 2011 | Magellan Triton 300 Handheld GPS Receiver
Magellan Triton 300 giving Fatal Application Error!
This is a problem with the internal memory files. They have been corrupted It is too complicated to fix yourself. If the is out of warranty, the Jungle Ghost at http://www.jungleghost.com/repair_service.shtml has a repair service.
Jan 20, 2010 | Magellan Triton 300 Handheld GPS Receiver
I also have a Magellan Triton 300 and I can not change it to my time zone.. how can I change it?
From the user manual at http://www.magellangps.com/assets/manuals/MagellanTriton_300_400_500_UserManual.pdf
it says:
Setting the Time Zone
The time and date information will be computed from information from the GPS satellites so there is
no requirement for you to input any time or date information. However, to make the time accurate
for your location you must select the correct time zone.
1. From the Map screen press MENU.
2. Select View.
3. Select Settings.
4. Scroll down and select Date & Time.
5. Select the Time Zone field.
Press button
momentarily
Fundamentals
5
6. From the drop-down menu, select your current time zone. (Time zones are not changed
automatically when travelling. If you travel to an area with a different time zone, you will
need to change it here for accurate time information.)
7. Repeat the process for the Daylight Savings field.
8. Press ESC when done.
Jan 02, 2010 | Magellan Triton 300 Handheld GPS Receiver
I cannot connect my magellan triton 300 to my computer, it always say "usb device not recognize
It sounds like you do not have the drivers install for your Triton, to install the drivers you will need to install the Vantage Point software that can with your unit or you can download the newest version of Vantage Point from the following link; http://www.magellangps.com/products/map.asp?tab=0&PRODID=1903
I hope this helps!
Nov 06, 2009 | Magellan Triton 300 Handheld GPS Receiver
I need help changing the time zone on my magellan triton 300... I need help even getting to where you can change the time zone
Assuming that you have the latest firmware installed ..then do a MENU>>VIEW>>SETTINGS .. no scroll using your down arrow so the screen shows you the HIDDEN settings and you will see date and time. The rest is easy.
Aug 07, 2009 | Magellan Triton 300 Handheld GPS Receiver
Magellan Triton 300 instruction manual
The site has pdf files of the manual, Can also be found at a couple of other places on the web.
Apr 29, 2009 | Magellan Triton 300 Handheld GPS Receiver
Magellan Triton 300 GPS handheld
This problem is caused by two possible problems. First go the MENU>>VIEW>>SETTINGS>>MEMORY and CLEAR YOUR MEMORY. If does not work and the unit is NOT seeing any satellites in the satellite screen, then you most likely have a defective GPS+ANT. Unfortunately, this is a part of the motherboard and cannot be repaired.
Mar 19, 2009 | Magellan Triton 300 Handheld GPS Receiver
Frozen gps magellan triton 300
The problem is being caused by a corrupt file in the internal memory. This requires a service repair to find and remove the file. Try the Jungle Ghost at jungleghost.com. They do repairs.
Jan 02, 2009 | Magellan Triton 300 Handheld GPS Receiver
GPS Logo
59 people viewed this question
Top GPS Experts
Will Halftowaite
Are you a GPS Expert? Answer questions, earn points and help others
