Question about RIM BlackBerry Pearl 8100
The screen on my TX has "blind" spots which are particularly evident if playing Scrabble. I have trieed soft and hard resets but the problem persists.
  • 100 Answers
Check your guarranty. It usually covers up to a certain nomber of dead pixels.
Otherwise you can find a replacement LCD screen in this link:
http://www.piezas.biz/epages/wwwpiezasbiz.sf/en_GB/?ObjectPath=/Shops/demo132390
You will have to provide your brand and model.
Posted on Apr 20, 2008
I cannot get my Palm TX to sync. I did a soft reset and a hard reset and it still won't sync. Help!!
I recently had about the same problem with mine. I am sending you a link to go to the Palm support for the TX. At the bottom of the page is a link for free chat support. I had the best experience with palm and hopefully you will too. Let me know if you need any other help. Best wishes.
http://kb.palm.com/wps/portal/kb/na/tungsten/tx/unlocked/supportservices/page_en.html
Aug 20, 2009 | Palm TX Handheld
When trying to sync, error message reads (sys 0505)(0,841).What can I do? For Palm TX handheld
Try to perform a System Reset (see article linked below). If it works to break the loop, you should then be able to delete the offending "My Palm" software and perform a Hotsync to backup your data to your desktop.
If that doesn't break the loop, you'll have to perform another Hard Reset. Sometimes, a Hard Reset takes a couple of tries to get it right, since it's easier to do it wrong than to do it right.
This article discusses the various types of Reset for different Palm devices:
http://tinyurl.com/zlwza
Until you break the TX out of its loop, you won't be able to get the data from it.
To see the Palm OS version running on your TX, enter the Menu, select Info, then Version.
To Get Out Of A Loop:
  1. Perform a SYSTEM RESET by doing the following:
a) Press the UP Button
b) And THEN press and release the RESET Button
c) When you see the second Logo (Palm Powered) release the UP Button
d) Now check if your SYSTEM RESET worked by going to Beam Receive. If it goes back to Off even after you put it to On it means you were successful
2. Now Perform A SOFT RESET by pressing and releasing the button in the back once
  1. After a soft reset, a logo screen appears, followed shortly by a Preferences screen asking you to set time and date.
  1. If a soft reset does not break it out of the loop, you may need to try one of the other resets below.
  1. Do an INCOMPLETE HARD RESET by holding down the power (on/off) button on your device.
  1. While holding down the power button, Press and release the reset button on the back of your handheld device
  1. Keep the power button pressed and release it when the “Palm Powered” logo appears.
  1. A message will now appear warning that you are about to “Erase All Data”. And this will happen if you press UP or DOWN.
  1. Instead you press left or right to begin a soft reset, leaving your data intact.
  1. Your device will then take you through a series of screens to calibrate the digitizer and verify the time and date.
Sorry this was so long, I tried to put everything down that might help you.
Aug 03, 2009 | Palm TX Handheld
After a soft reset, my Palm TX becomes stuck on the "Palm Powered" screen. I have tried all of the resets, including the hard reset. The PDA does not respond to any of the resets. I can not turn the PDA...
You need to perform full reset which will erase all personal data and set everything to factory default. You need to press reset and power button to perform full reset.It will give you confirmation once you choose yes it will perform hard reset If issue persist you may disconnect and reconnect to internal battery
Aug 02, 2009 | Palm TX Handheld
BOTTOM OF SCREEN NOT WORKING,
This happens a lot with Palm digitizers. The only permanent solution is replace the plastic digitizer with an upgraded glass type. Before considering that, see if removing screen protector helps. (yeah, didn't think so. Worth a try!) Try Powerdigi, a better calibration program. Get it from http://www.palmpowerups.com
It worked for me.
Jul 03, 2009 | Palm TX Handheld
I just received a used palm tx. I am trying to connect to internet. Screen is titled Scan for Wi-Fi networks ...Would you like to turn the radio on now? I tap "yes" unit seems to turn off or maybe tries...
Do a hard reset, since you probably have someone elses data on it. This will clear it and set everything back to default.
Soft Reset
A soft reset tells your handheld to stop what it's doing and start over again. All records and entries stored in your handheld are retained with a soft reset. After a soft reset, the Welcome screen appears, followed by the General Preferences screen.
Use the reset tip tool (see below), or the tip of an unfolded paper clip (or similar object without a sharp tip), to gently press the reset button inside the hole on the back panel of your handheld.
Reset Tip Tool: On most PalmOS handhelds, the stylus that comes with your handheld has a reset tip inside. To use it, unscrew the barrel from the stylus quill.
Hard Reset
To perform a hard reset:
  1. Hold down the power button on the top of the handheld.
  2. While holding down the power button, use the reset tip tool (or similar object without a sharp tip), to gently press the reset button inside the hole on the back panel of your handheld.
  3. Release the reset button.
  4. When the logo screen appears on the screen, release the power button.
  5. When the message appears on the handheld screen warning that you are about to erase all the data stored on your handheld, press the upper half of the scroll button on the front panel of the handheld to complete the hard reset and display the Digitizer screen.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
May 03, 2009 | Palm TX Handheld
Hard reset for palm centro
Here is a tutorial on how to perform a soft and hard reset on the Centro:
http://www.hardreset.eu/palm_centro_hard_reset_soft_reset_en.html
Click on this link or copy and paste the complete link into your browser.
Thanks, Joe
Mar 13, 2009 | Palm TX Handheld
Replaced Screen, LCD, Digitizer & Battery, BUT
If you can back it up and reload the software. Recalibrate the touch screen that way. Could be some old data in there preventing it from happening.
Dec 10, 2008 | Palm Tungsten E2 Handheld
The palm powered icon
To do a hard reset, hold down the power button, press the little reset button, release it, then release the power button.
Make sure you back up your TX first.
Jan 29, 2008 | Palm TX Handheld
XDA Orbit Help
you need to hard reset your PDA and need to reinstall the OS..this will help you
all the best
Jan 06, 2008 | O2 Xda Orbit Smartphone
Palm TX handheld turns automatically on and off.
If you tried a hard reset, and it is still happening... then it may be a hardware problem. Is it still under warranty? You may want to exchange it for a new unit.
Dec 16, 2007 | Palm TX Handheld
RIM BlackBerry  Pearl  8100 Logo
18 people viewed this question
Top RIM Computers & Internet Experts
Jax Planet
Jax Planet
William
Justin
Justin
Are you a RIM Computer and Internet Expert? Answer questions, earn points and help others
