Question about Wewa WMP-2000 MP3 Player
Win Virtual Driver
After Installing the driver to my PC, I was asked to install driver. I put the installation disk for it to search. "Win virtual Driver not found" appears.
Do my driver needs to be upgraded ? Was WEwa 2000 MP3 too old for Windows XP ?
Please advise ?
My email address is ; stkkchan@gmail.com
Thanks
    Master:
    Sergeant:
  • 462 Answers
You need to manually install the driver from the installation cd. This is the only sution to the problem.
Thankyou
Posted on Apr 15, 2008
What setting do i put my webcam on for a virtual book?
1st You download Webcam Driver.
After this install the Webcam driver in the system.
Installation of Webcam Driver
Go to the control panel
Click on the System Icon
Click on the Hardware Tab
Click on the Device Manager s
Select the Unknown Device or printer device where yellow Question Marks sign on it.
Right click on it and uninstall it.
After this go to the top of the device manager and click on scan for hardware changes.
Driver installation Wizard start.
Brows Your Driver from the Hard Disk and click on next.
Driver will be install.
Dec 29, 2012 | Logitech C170 Webcam
Hi, I need driver for windows 7 I try install for xp and run like in xp but it is not working if you have any tip I will be thankfull
Hi marec2009
Unfortunately , you don't tell us what device is concerned with this compatibility problem .
If nothing works , uncluding troubleshooting in compatibility XP , the only way to get out of the issue is a workaround : installing a virtual version of XP on your machine but you can do it only under restricted conditions :
You are running Windows 7 Ultimate , or Professional or Entreprise :
you can download and install a free virtual version of Win XP from : http://www.microsoft.com/windows/virtual-pc/download.aspx
Other versions :
.If you have the W XP install disc , you can install a virtual version of W XP on your machine from http://www.vmware.com/products/player/
If you still have the install disc , you can also partition your primary and install W XP on the new partition from http://download.cnet.com/Partition-Wizard-Home-Edition/3000-2094_4-10962200.html.Back up your data first.
Best regards .
fanaudi
Apr 28, 2011 | Computers & Internet
Hi , i cant install canon pc1230d in windows 7 computer. Thanks
There is no driver for your unit under Windows 7
Workaround :
If you are under Win 7 Ultimate or Pro or Enterprise , you can download and install a free virtual version of Win XP from : http://www.microsoft.com/windows/virtual-pc/download.aspx
This is the ultimate solution to ANY compatibility problem. You just use XP mode to do operate your device then go back to Win 7 in one clic where your modern processing software is.
Under other versions of Windows 7 , you need to have the XP install disc to install a virtual version with a third party software such as WmWare Player from
http://download.cnet.com/VMware-Player/3000-2094_4-10470784.html
Apr 04, 2011 | Office Equipment & Supplies
I want work with dv500 pinacle in a windows 7 instal . Its possible?
Pinnacle DV500 is supported by drivers up to windows XP only. You can download the driver at this link :http://www.pinnaclesys.com/PublicSite/us/Products/Consumer+Products/Advanced+Video/DV500+series/DV500+Series+Support/Download+Area/Drivers+-+Updates/DV500_45_webinstaller_zip.htm?mode=documents&Display=1
You can try installing the Win XP driver and see if this will run on Windows 7. If not, then your other choice is to run it using Windows XP mode on Windows Virtual PC.
The link below explains what Virtual PC and XP mode is. You can also download the installers there.
Mar 15, 2011 | Pinnacle DV500 DVD Video Capture Graphic...
I have a microtek i320 scanner I used with win XP Since upgrading to Win 7 it no longer works. How can I upgrade my driver? Can I buy the proper driver without buying a whole new scanner?
This scanner should work with the XP 32-bit driver. The driver is here: http://support.microtek.com/knowledgebase_1/kbdtl.phtml?request=KB-00106SW . See the link for other scanners. Unplug the data cable, uninstall the scanner if it has a yellow triangle with an exclamation point, then install the driver. After installation, connect the data cable.
The support site for this scanner is here: http://support.microtek.com/product_dtl_2.phtml?prod_id=34 . This information is given in the Knowledge Base section if the other link doesn't work.
I know this will work with Win7 32-bit. I'm not sure about the 64-bit version. If the 64-bit version doesn't work with the above driver, you can either replace the scanner, use it with another computer with an older version of Windows, run a dual boot system with an older version of Windows and install the scanner only on that system, or run a virtual computer with an older version of Windows.
If you have Win7 Pro or Ultimate, you can do the virtual computer for free. Download and install Microsoft's Virtual PC and XP mode. Install the scanner in XP mode as you would on any XP computer. The only restriction is that the files may need to be saved to external media to share them between the two computers.
All other options will require a licensed version of the older Windows OS. (Virtual computer packages include VMWare and Parallels in addition to Virtual PC.)
I hope this helps.
(I have an older scanner that runs nicely with Win7 32-bit.)
Jan 18, 2011 | Microtek ScanMaker i320 Flatbed Scanner
I have lost my software for Epson Perfection 1260 Scanner. I need to install in my new computer with windows 7. How?
go onto epsons website and download the driver or the installation file/ folder then process with any insruction enjoy
Dec 18, 2010 | Computers & Internet
Drakan order of the flame engine crashes when i start a new game. i have windows 7 but im running as admin and in compatability mode for win xp sp2. what else can i try?
You could try installing the DirectX version the game uses. (probably on disk)
You can also try to download this Windows Virtual PC.
Windows Virtual PC emulates Windows XP on your Windows 7 PC, so that you can run older applications that won't run on Windows 7 otherwise.
You will however need a processor capable of virtualisation.
Virtualisation check and download here: http://www.microsoft.com/windows/virtual-pc/download.aspx
After installing Windows XP Mode you will need to install the game again in this XP emulator, but after that it should run fine.
I hope this helps,
Yannick.
Dec 08, 2009 | Activision Drakan: Order of the Flame for...
I just want my money back. Because it asks me to uninstall a program I want to keep, Mcafee
Since McAfee is asking you to uninstall it, I am sure the program would have come in the spyware/adware list. They may have analysed that the software might create problems in your computer.
Do this.
install Microsoft virtual pc 2007, install xp on a virtual machine using this software.
Log into the virutal machin win xp , and instlal your software. If you connect to internet using that software, you can also install the internet device drivers.
YOu happy, Mcafee happy! atlast your systemis safe.
More info on Virutal pc
http://en.wikipedia.org/wiki/Microsoft_Virtual_PC
Virtual pc
Aug 19, 2009 | Computers & Internet
Can i run vista and xp on my comp
install the two OS in separate drives (e.g. XP in C drive and vista in D drive) either have two hard disk drives or 2 partitions.
then you choose which one to run in the start up.
May 11, 2009 | HP FK784AA Pavilion Slimline s3650f...
Logitech to Mac
I had a search and found these Q&A's, so see if these can sort out your problem. Q. Can I talk/see to Windows users? A. Yes, there are video conferencing standards in existence, and if these are adhered to and implemented properly it should mean that Mac applications could connect to Windows applications - or even dedicated hardware solutions. However, at the moment, the simplest way is to use iChat on the Mac, and AIM on the Windows system. The results are nowhere near as good as an iChat to iChat link, but it works. Also, consider iVisit, Yahoo Messenger, SquidCam or ohPhoneX. Q. Can I use Virtual PC on the Mac to use MSN Messenger, and so talk to Windows users that way? A. In theory it might work, in practice I've not got it to work using Virtual PC 7 and a USB Logitech webcam. (Virtual PC will definitely NOT support the FireWire iSight camera). The USB camera required drivers to work on the Virtual PC, and installing them caused my iMac G5 to crash. Even if it did work, Virtual PC is NOT fast at this kind of thing and would probably not work very well at all with video conferencing. If you really need MSN Messenger to work quickly with video, it's almost better picking up a cheap PC.
Feb 07, 2007 | Logitech QuickCam Express Web Camera
Wewa WMP-2000 MP3 Player Logo
98 people viewed this question
Top Wewa Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Wewa Audio Player and Recorder Expert? Answer questions, earn points and help others
