Question about Sendo X Handheld
CHARGING PROBLEM I charge my phone direct from the charging point, what i will do is i will charge it with a desktop charger first before i can now charge it with the phone charging point. please help me. thanks
    President:
  • 3,130 Answers
Please explain what you need to do and what is happening. I do not understand what you are telling me.
Posted on Apr 15, 2008
Not charge batery bi its own charger
1.Check you charger firstly.
2.Use another charger
3.If it get charging by another then change your charger.
4.If still problem occur then you charging point on you handset will be damaged
5.Repair you charging point
Aug 04, 2011 | Nokia X3 Cell Phone
Tip
Why your phone won't charge
<span>Hello,<br /><br />there are three or more reason why your your phone won't charge;<br /><br />1. The charger might be defective.<br />2. The charging port of the phone might be defective.<br />3. The battery cell might be very weak or the battery might be defective.<br /><br />Charger<br /><br />A defective charge can cause a phone not to charge. To actually find out if your charger is defective or not, borrow a charger from a family or friend that has the type of your phone, use the borrowed charger to on your phone. If the the phone charges, then obviously, your charger is defective and need to be replaced. It is also good to test your charger on another phone to confirm the status of the charger.<br /><br />Make sure you run the above test, before buying another charger so that you don't waste your money. Sometimes, charger might be working and phone won't charge due to some other reasons that would be discussed below. So confirm first before buying another charge. Don't buy another charged based on assumptions........<br /><br />Battery<br /><br />A battery that is very flat, I mean a battery that its cell is very weak, won't charge with a phone charger. You might have to leave the battery in the phone with the charge plugged in for some minutes or hours before the battery will begin to charge and other times, it might not charge at all.<br /><br />What make batteries to be in this kind of condition is; <br /><br />1. If you use you phone to the point when it says "low battery" and you still don't charge the battery and the phone turns off by itself. This can run down a battery cell.<br />2. If you leave a battery in the phone idle for a days or months, the battery cell will become weak. Or if you leave a battery used for days or months.<br />3. If you don't use the correct/right charger for your phone, this can drain the battery instead of charging it.<br /><br />Batteries in such condition will have to be fast charged with a desktop charger. The desktop charger will be connected directly to the battery and the battery will definitely pick up within 1 hour. Thereafter, you can continue charging it with your phone charger and it will charge immediately.<br /><br />But if the battery is defective, it won't charge at all. Even if you use a desktop charger. Such batteries needs to be replaced. Also, it is good to test the phone with another battery, and charge it to confirm before buying another battery.<br /><br />Below is a picture of what a desktop charger looks like;<br /><br /><img src="walesarumi_4.jpg" /><img src="walesarumi_3.jpg" /><br /><br />Charging port<br /><br />If non of the above seems to be the reason why your phone won't charger, then it means the charging port is defective. <br /><br />Most times defective charging port confuses people. They think the charger is the reason why their phone won't charge and after using another charger on their phone they still find out that the does still does not charge.<br /><br />Once your phone doesn't charge, the first this you test is the charger and second, the battery. But if the battery and charger seems not to be the cause of the problem, then it is the charging port that is cause the problem.<br /><br />Your charging port might not be defective, maybe it loosed contact with the phone phone or it shifted from it's position. Sometimes, the way we forcefully insert our charger into the phone can make the charging port loose contact.<br /><br />At this point, you will have to disassemble your phone. But if you feel it is a task you cannot perform yourself, then take the phone to a repairman to help you out. But if you feel you can do it yourself (DIY), read further.<br /><br />Turn off the phone. Remove the battery. After that, get a phone screw driver, unscrew all the phone screws, remove the phone cover in order to gain access to the phone panel and get to the charging port. <br /><br />Check if the charging port actually loosed contact. If it didn't loose contact, then you will have to replace the charging port. <br /><br />Note that some charging port are soldered to the phone board and some are not. So if yours is not soldered, simply remove the charging port and make a replacement. But if is soldered, you will be needing a rework station. Rework station is what you will use to remove the charging port.<br /><br />Below is a picture of what the rework station looks like;<br /><br /><img src="walesarumi_5.jpg" /> <img src="walesarumi_6.jpg" /><br /><br />I hope the above makes sense to you.......<br /><br />Good luck.<br /></span>
on Mar 23, 2011 | Cell Phones
Nokia e71 is not charging even if it plug in. it does not start with power switch and before it was switching off automatically
The charging point have faulty but depending when you will get it fixed you can always use a universal charger(desktop charger)
Feb 11, 2011 | Nokia E71 Smartphone
The charging point is spoilt
Charging port are not repairable, you will need to replace or change the charging port on your phone to solve the problem.
Take the phone to any local phone repairer to help you replace the charging port on your phone, the cost of replacing the charging port is very cheap. This the solution to your phone not charging.
Take care.
Aug 09, 2010 | Nokia 2330 Cell Phone
My motorola l6 was not functioning the charging port....so right now i used a desktop charger? plz help
Have you tried carefully cleaning out the charging port with a soft toothbrush? If you attempt this please be very careful because the contacts in the charging port are easily damaged. Sometimes fluff and gunk can build up inside the charging port and the charger cannot make a good connection. If you do not want to attempt this you should take your phone to a reputable phone engineer or Nokia service point for repair.
May 20, 2010 | Motorola Mobility L6 Cellular Phone
My sony erricson K750i wont charge?
try your charger with another phone to be or try your phone with another charger to be sure the charger is good.
If the charger is good, then the next thing to check is your phone's charging port. Some times, the charging port for K750i is usually dirty, have dust, or may be rust and won't contact the charger well because of this, thereby, not making the phone charge.
Get a metal and use it to scratch all the areas of the charging port, then fix in your charger to see if it will charge.
If it still does not charge, then it means, you have to get another charging port.
You also have an option of using a desktop charger to charge your phone.
Good luck.
Apr 20, 2010 | Sony Ericsson K750
Not charging
firstly, test the phone with another charger, to be sure the charger is not the cause of the problem.
Once you have confirmed that the charger is not the cause of the problem, then you will need to change your phone's charging port.
There are basically to reasons for your phone not to charge. Its either the charger of the phone's charging port as stated above.
You also have an option of using a desktop charger to charge your battery, in case you are not ready to change the charging port yet.
Good luck.
Apr 20, 2010 | Nokia 6300 Cellular Phone
Not charging
The faults might fall into the following,
1.The charger may be bad
2. The battery may be bad
3. The charging ic may be bad
Solutions
1. First of all, check your battery if it is still good, you can do this by inserting it into another phone, if it does not charge, then the battery is bad and you have to get a new one. But if it charge in the other phone, then it's either the phone charger or the charging i.c that is bad.
2. Try testing you phone with another charger, if it charges the you initial charger is bad and if the new charger does not charge the phone, the charge port or charging ic is bad. It means you have to change the charging i.c
3. Alternatively, i will advice you to get a universal or desktop charger to charge your battery should incase the charging i.c is bad.
Jan 08, 2010 | Cell Phones
N70 not charging
try replacing the charger or the charging point.
Nov 17, 2009 | Nokia N70 Cellular Phone
Charging
seems like ur phone's charging point is broken or else ur charger isnt working .. try a different charger if it works den ur charger is at fault or else the point is broken
Nov 22, 2008 | Nokia 1100
Sendo X Handheld Logo
Top Sendo Computers & Internet Experts
David Payne
David Payne
Are you a Sendo Computer and Internet Expert? Answer questions, earn points and help others
