TV Repair faults tips
VERTICAL LINE FAULT chassis number TNP4G347
  • GRAZER93 Oct 29, 2008
    TV JUST TURNS OFF, PLUS HORIZONTAL LINES ON SCREEN
Verticle line
Posted on May 21, 2008
Samsung plasma TV repair
Sounds like COF fault. If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience.
http://electro-medical.blogspot.com/
Line faults & possible causes to LCD & Plasma screen are given with illustrations. You can get an idea about the fault to an extent. Line faults to all LCD screen are similar, irrespective of its brand and screen size.
Feb 06, 2016 | Samsung Televison & Video
Vertical lines on Vizio tv how to fix it
If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Line, faults & possible causes to LCD screen are given with illustrations. You can get an idea about the fault to an extent.
Oct 04, 2015 | Vizio E552VLE 55-inch Widescreen Smart TV...
My bush tv is 2 years old and has 2,sometimes 3 vertical lines running down middle of screen.what could be the problem please.x
Hi Roberta.
its the horizontal circuit fault in the Tv. Look back from the Yoke socket and from the two red and blue terminals and you you will get into the horizontal circuit
uusually its components starts with the number 4 at the Tv chassis
resold the components there good and this problem will be fixed
as its a solding loss or track cut at the tv chassis
you need to be familiar with tv repair to do this or get technician to fo thid for you
May 06, 2015 | Bush Televison & Video
TV has a great picture but wont "hold it". Keeps going to a single flat horizontal line across the middle of the screen. Tapping on side of TV used to bring it back but now, nothing. Just a line.
Vertical scan output section circuit fault. Absence of vertical scan causes the single horizontal line on screen. Horizontal scan output section is OK. Contact any service technician to troubleshoot the vertical scan output section circuit. If you wish to get some details; check the site linked here. Pull up older posts.Surf the site with patience.http://electronicshelponline.blogspot.com/
Horizontal line fault to CRT based TVs are given.
Oct 06, 2014 | Televison & Video
How do I repair vertical lines in samsung tv
Sep 02, 2014 | Televison & Video
My sony tv model no. kv-ha21m80 is on standby mode & its LED is blinking four times that means it has some problem in vertical section.But when I tried to check voltages of its vertical IC AN5522
Disconnect Vertical supply and so that your Horizontal system run check all voltages before connecting vertical again ...should the protection come in again when vertical connected ...replace Vertical Ic and safety resistor in line
Apr 21, 2012 | Televison & Video
Ive got a line down the left hand side of the screen when the tv is turned on the model number is panasonic viera tx-p42v20b
HI,
IF YOU HAVE A SOLID BLACK LINE RUNNING VERTICALLY THEN YOU HAVE A FAULTY MATRIX INVERTER. IF CENTRAL THE MAIN VERTICAL INVERTER NEEDS CHANGED. LEFT = LEFT VERTICAL INVERTER RIGHT=RIGHT.........
ANOTHER WAY TO GET THIS FAULT IS WORN OR DAMAGED RIBBON/PLASTIC GOING FROM THE SCREEN MATRIX TO THE INVERTER
GOOD LUCK IN RECTIFYING THE FAULT, THANKS
May 13, 2011 | Panasonic Televison & Video
DEAWOO TV Model no DTC 2975 vertical line i want to know that vertical ic number b,cos of that ic is burn & blast,i can't fine out.
If you have a bright vertical line down the screen you have an "S" correction fault. Usually there is a small choke that gets a dry joint under it.
Check for dry joints.
Jan 04, 2011 | Televison & Video
My tv is all blackexcept a wihite line through it and no sound
If the line is going across the TV the vertical deflection circuit needs repair. If its going from top to bottom the horizontal circuits are needing repair. Please post your model number and I will be better equiped to let you know which part is likely at fault.
Apr 27, 2008 | Televison & Video
Missing vertical deflection on philips TV
TDA 8362B IC which have vertical freq.output is at pin no.43. (vert.osc) caution for fixing this problem minimise brightness to avoid crt burn. proceed as follows 1 if you are getting sawtooth at output of ic tda 8362 pin 43 then check 1 supply at vertical output ic from eht. 2 yoke connector loose . 3 check vertical output ic parts. 4 finally vertical ic. please check for normal output from power supply even though fault gets rectified just for protection. good luck.
Sep 22, 2007 | RCA 13R400TD 13" TV
Televison & Video Logo
939 people viewed this question
Top Televison & Video Experts
