Question about HP PSC 2210 All-In-One InkJet Printer
No booting Hi, i have asus p4s800 mx,windows xp professional service pack 2 and hard drive 80gb western digital, computer was working fine but now there is no display. I have another system hp d530 cmt,windows xp professiona service pack 2 with 40 gb hard drive(working fine) .i want to use my 80gb hdd from my asus p4s800 mx to other system hp d530 cmt, but when i took 40gb hdd out from hp d530 cmt and replaced with my 80gb hdd from asus p4s800 mx, computer did not boot, it goes to post and then monitor screen grey with blinking cursar. jumper setting on 80gb hdd were 'cable select'. i tried the jumper settings to master but still the same problem, computer goes to screen showing boot keys and set up keys and then monitor screen goes grey and blinking cursar. Please help so i can boot from my 80 gb hdd. i appreciate your very busy time.
    Genius:
  • 1,027 Answers
The problem is Operating systems are co-dependent on hardware.
If the motherboards, processors, ram, video adapters, etc don't match you would not be able to swap hard drives and expect to boot.
You could try pressing F8 on boot and try to access safemode.
If it does boot into safemode immediately it will want to reactivate windows.(because of all the hardware changes.
If it still can't boot, you may want to put the 80 gig in as slave to the 40gig and ghost the 40 gg hard drive over to the 80.
If you don't want to lose your data on the 80 gig then reboot with an xppro cd and reinstall windows in the same partition overlaying the installation on top of existing windows directory.
the new windows will have to be activated but all data will still be there.
Posted on Apr 15, 2008
DRIVER NEEDED: ASUS p4s800-mx (Windows XP Professional) [Archive]...
Hello download the driver here at asus:
http://www.asus.com/Motherboards/Intel_Socket_478/P4S800MX/#download
First select your windows system
Select audio and hit global for download
Please unzip the file before installation
Good luck
Dec 19, 2010 | ASUS P4S800-MX Motherboard
Asus P5KPL SE & Sata, Bios "Not Detected Problem"..
The Asus bios won't show SATA devices.
However if you are using Windows XP with Service Pack 2 (or newer operating system then the devices should be detected. If this is not happening then enter the bios -- Storage Configuration -- Configuration Enhanced and set the IDE devices to compatible. This allows all drives to be "seen" and you should then be able to load an OS.
Jan 22, 2010 | ASUS Computers & Internet
WD drive won't work as master when Seagate 80GB drive connected as slave.
The jumpers on the Seagate must be set to slave.
otherwise they are conflicting for the Active partion and bootloader.
Regards
Richard.
Apr 26, 2009 | Western Digital Caviar WD200BB 20 GB Hard...
Recently installed windows xp3 service pack have to rebooth desktop with asus p4s800-mx se motherboard on emachine 21o desktop, how can do normal boot up can i remove the service pack
when start your computer press the f8 button its show the safemode click the safemode and open the windows in a safemode when your computer start then open start>all program files>accessory>system tools> system restore> open it and choose the date when your windows is working with sp2 after that click next and finish it your pc take a reboot then its restore your sp3 will be remove from your pc
thanks
rate me if solve
Oct 01, 2008 | ASUS Computers & Internet
Bios update problems P4S800-MX
An .exe file isn't a .rom file. You downloaded the flash program (the program used to flash new data to the ROM), you didn't download the flash data. Look on the site again, or look to see if there's another file - P4S800MX.ROM - to extract.
Sep 10, 2008 | ASUS P4S800-MX Motherboard
I purchased a western digital 160G external storage device. My computers tell me that it will be slow without a high speed USB port. However, I get a prompt to install software or to insert a disk into...
use windows xp service pack 2 professional
all the ports are then usb 2 .
if this doe not solve the problem change the circuitry of the ext drive on which you mount the hdd
Jul 09, 2008 | Western Digital Passport WDXML800UE...
Cd rom message "no emulation" when booting the windows xp installer
when i install my windows xp professional i get a message prompting BOOT TO ATAPI CD-ROM: "NO EMULATION".... how can i fix this?Pls help me on this
Jun 07, 2008 | ASUS P4SP-MX Motherboard
Installing XP on a PCI SATA Card
hey change ur boot order in bios.....
put dvd/cd drive 1st...
May 30, 2008 | ASUS P4S800-MX Motherboard
Second Hard drive
it seems like it is not recognizing the hard drive, the error is coming from the cdrom/dvdrom. make sure that the hard drive is jumpered to slave,and the cd/dvdrom is put on the other ribbon cable set at master drive
Apr 09, 2008 | ASUS M2N-MX Motherboard
Computer not booting
Unfortunately it sounds like the processor fried. These are very prone to heat degradation.
Link to computer gate
Link2
Link 2 is to Geeks.com
Link 3 Take your pick
Your board supports Northwood/Williamette processors with HT
in 400/533/800 Front Side Bus
Apr 05, 2008 | ASUS P4S800-MX Motherboard
HP PSC 2210 All-In-One InkJet Printer Logo
96 people viewed this question
Ben Johnson
