We have a Panasonic projector PT-L595. In the last few weeks a purple line on the left of the screeen, and a green line on the right has appeared. There is also ghosting and the picture is getting blurrier. We tried al the different picture settings, and have gone back to the default setting. Any ideas?
  • rina799 Apr 15, 2008
    Hi Issy,
    Thanks for your reply. We bought the projector 2nd hand from Primary Industries, so there is no warranty. According to the onscreen information, the lamp (same as filament?) has used about 600 hours - the book says it should be replaced after 2000 hours. It didn't have these problems when we first got it.
    Master:
    Sergeant:
  • 462 Answers
Does it still cover in warranty?
Posted on Apr 15, 2008
  • Mohamed Ismail
    Mohamed Ismail Apr 15, 2008
    And also can you specify how many hours has the projector has been used. Because the filament of a projector has a limited life, which has to be replaced after roughly 6000 hours or so varies for different models.
  • Mohamed Ismail
    Mohamed Ismail Apr 18, 2008
    Good to hear from you..
    Hoping a good rating from you.
    Have a nice day...!!!
Patch of purple "scribble" lines on corner of screen
This is a common problem on a faulty Mainboard of a Projector.
Not much you can do about it except repair or replace the Mainboard
Aug 01, 2008 | Sony VPL HS10 Multimedia Projector
Image is bright but there is a slight issue - on the left hand side a purple line displays vertically. Anybody knows why is this fault appeared and how could it be solved.
There is three LCD in the projector red, green and blue. If green LCD make any fault mean line or dot or dots then screen show these line or dot in purple color:
If line is very straight and sharp edges then green LCD is faulty and need to be replaced.
If line is not straight and faded edges then some thing in LCD block so your projector need service
Feb 22, 2011 | Sony VPL PX40 Multimedia Projector
I own a panasonic pt-ae900e i have notice a thin uneven green transpairant line in the middle of the screen lamp time 1987 hrs
Experience:
There is three LCD (liquid crystal display) in your projector when one LCD faulty he display a line some time flickering line one or two lines. Due to other two LCD is working well so this line is looking transparent. If BLUE LCD faulty than the line color is very light green or yellow.
Second option is this that your projector lamp life is near to end and after 2000 hours projector is very dirty inside and need service.
(service of LCDs and other parts of projector is a very technical job and I don't know you can do it or not)
Jan 16, 2011 | Panasonic PT-AE900U Multimedia Projector
It has a purple and green haze around the edges....
Problem: due to dusty LCDs the light is not pass on equally. so you get a unequal color background in your image. your projector is just need service and service of LCDs and inside parts are a purely technical job.
Dec 29, 2010 | Panasonic PT-LB50SU 2000 Lumen SVGA...
Convergence on lower half of the screen is off, green arc appears
Your TV most likely has a Convergence Chip Failure ( common problem )
Here are some of the most common symptoms and example photos of a convergence problem
  • Screen looks 3D
  • Colors don't line up
  • One or more colors can't be adjusted when using the convergence menu.
  • Screen is bowed or warped.
2c07611.pngSolution #1
You need to replace the convergence chips and convergence resistors. Check the site www.TvRepairKits.com. They have put together convergence repair kits for most models.
The kits include a photo instruction guide, original OEM Sanyo STK chips, convergence resistors, pico fuses, thermal paste, etc. Everything you will need to do the repair yourself.
Apr 05, 2009 | Panasonic PT-51HX41 51" Rear Projection...
Spots on picture
I had the same problem. Panasonic is kind of a pain about the whole thing. You have to find out who your local Panasonic repair place is, tell them there is a service bulletin and they will get on it. You must be diligent! Do not take no for an answer! If it comes down to it, and the repair shop won't do it for you, then call Panasonic and endure a loooooong wait time. Trust me though...this is the issue. Once the eeprom gets fixed/updated/whatever, the picture looks amazing! Good luck.
Aug 16, 2008 | Panasonic PT-61LCX65 61" Rear Projection...
Panasonic PT 47WX53 CinemaVision TV
http://cmpalmer.blogspot.com/2006/11/fixing-my-own-tv-part-ii.html
Mar 21, 2008 | Panasonic PT-47WX53 47" Rear Projection...
Green....purple....colors
If you are technically savvy and you can solder.....requires
chassis pull...replacement of convergence IC's...mounted on large heatsinks on board to the right looking in from rear....If
you want help........Let me know................T.
Dec 27, 2007 | Panasonic PT-53WX53 53" Rear Projection...
Convergence
covergence amp ic"S need to be replaced.
Aug 16, 2007 | Panasonic PT-53WX54 53" Rear Projection...
Televison & Video Logo
64 people viewed this question
Top Televison & Video Experts
