Best secret codes sony ericsson
<span><b><span><span>1.</span> S</span>ony Ericsson Secret <a>Menu</a>:<span> <span>-> * <- <- * <- *</span></span> (-> means <a>press</a> joystick, arrow keys or jogdial to the right and <- means left.) You'll see phone model, software info, IMEI, <a>configuration</a>
info, sim lock status, REAL time clock, total call time and text
labels. You can also test your phones services and hardware from this
menu (main display, camera, LED/illumination, Flash LED, keyboard,
earphone, speaker, microphone, radio and ******** tests) </b></span><br /><br /><span><b>2. IMEI Number:<span> <span>*#06#</span></span> -For checking the International Mobile Equipment Identity.</b></span><br /><span></span><br /><span><b>3. Lockstatus: <span><- * * <-</span> -SIM lock - Do not lock your phone if you don't know the <a>unlock</a> code. This is another good check before you buy any phone, especially <a>second</a> hand ones. If phone is SIM locked, you may not be able to switch to other GSM operators.</b></span><br /><br /><span></span><span><b>4. Shortcut to last dialed numbers: <span>0# </span></b></span><br /><span></span><br /><span><b>5. Shortcut to sim numbers: <span>On main menu type a number and press # </span></b></span><br /><br /><span><b>6.
If you change the language from default to any other language, then it
may be difficult to switch to default language. The shortcut is very
simple. Just press <0000>. <> stands for right arrow button
or joystick.</b></span>
