Question about Harman Kardon AVR 7000
Receiver no longer connects to surround speakers
My speaker systrems now only works for the front speakers. I have previosuly rectified the problem via the remote control set up. The problem is still occuring and I am at a loss as to how to fix the problem.
  • pixelboi Feb 01, 2009
    I have an HK AVR 7000.... The receiver only operates in "surround off" mode. It will not operate in any digital mode and I have the optical cables in properly and even the coax as well. When I set the receiver for any digital mode I get white noise. Any help would be appreciated...
    New Friend:
  • 101 Answers
There is a issue with the 10uf capicitors on the dsp.i had to replace abiut 30 of them.
Posted on Jun 04, 2008
Denon receiver not working surround output
If everything is connected correct, the only thing I can think of, is you don't put in a surround signal. If you only feed 2 way stereo, only two speaker will work. Also if you switch to stereo, the other channels will stop working. Check the cables, the settings and the input.
Jun 15, 2014 | Pioneer VSX-D511 Receiver
Front Speakers stopped working
turn on your video and start something playing, press the speakers button repeatedly until the sound comes back. this should bring back your front speakers, if it doesn't, double check your speaker connections and sound field program.
the speakers button should cycle through all available front speaker options.
Nov 16, 2007 | Yamaha HTR-6030 Receiver
Awia speaker ok for home thaeter
Just about any speaker will work for home theater. As long as it makes sound.
Of course, you will need some type of surround sound processor (like a surround receiver) and other speakers to connect to the front left, center, front right and surround connections.
Some speakers will work better than others.
I will not get into any specifics because there is WAAAAY to much information to get into. Do a little research on home theater systems and how to design, hook up etc.
May 02, 2014 | Aiwa Audio Players & Recorders
Marantz NR1402 AV receiver Going to standby Mode
There could be a short in one (or more) of the speaker connections. Try disconnecting all speakers and turning on the receiver. If it still switches to standby, there may be an internal problem.
Mar 03, 2014 | Marantz Nr1402 Av Receiver
Problem for Pioneer VSX-818V-K 5.1 Channels Receiver Surround sound doesn't work, display reads 2CH IN,surround speakers are enabled,automatic test will find surrand speakers
Test with an surround sound media ie. Blu-ray or DVD)_. Disconnect the front and all other speakers that are working to see if sound from the missing speakers are heard. If this doesn't work then start by tracing and checking all the wires from the receiver to the speakers for bad/shorted/open connections.
PLEASE VOTE IF THIS WAS HELPFUL. THANKS & GOOD LUCK.
Oct 23, 2009 | Pioneer VSX-818V-K Receiver
Only the front speakers work none of the surround speakers
If you are still covered by the warrenty, then you may be able to get it fixed at no cost.
Otherwise get a qualified technician (I say this to cover my but rather than suggesting that you open it up yourself) to open it up and check the fuses inside.
Aug 17, 2009 | Onkyo TX-SR705 Receiver
Looking to connect 4 speakers to the surround back
Series the speakers, they may not get as much power as you would like, but your receiver will last longer.
Aug 16, 2009 | Pioneer VSX-518-K Receiver
Sound only some out of 2 speakers at a time. I need all 4.
Here you go buddy:
http://www.docs.sony.com/release/STRDE685.pdf
May 19, 2009 | Sony STR-DE685 Receiver
Surround sound from Sky +
To upmix 2-channel sound (such as that in a TV broadcast) into 5.1 sound, press AMP and then SUR. DECODE until "PL II Movie" is displayed. This will give you "cinema-like" surround sound from a 2-channel source.
You can also assign this to one of your "Scenes" by following the procedure for scene assignment on page 26 of your manual.
Dec 30, 2007 | Audio Players & Recorders
NO surround sound coming from our harmon/kardon speakers when set up to our onkyo tx-sr601 receiver. wires connected in correct areas, front left, right and center speakers work, subwoofer works. setup for...
So your saying that you have no rear channel. Some recivers use a single stereo output ic for both sides on the rear speakers. you could have a defect with this IC . Anther thing Im sure you check3ed the obvious ie : the switch is on suround sound? If there is a front to rear fader is it in the middle? Good Luck
Jun 04, 2006 | Onkyo TX-SR601 Receiver
Harman Kardon AVR 7000 Logo
186 people viewed this question
Top Harman Kardon Audio Players & Recorders Experts
Brian Sullivan
Brian Sullivan
Carlos L. Burgos
Are you a Harman Kardon Audio Player and Recorder Expert? Answer questions, earn points and help others
