Question about Baby Gear
Cigarette burn in car seat
I have a small cigarette burn in my front car seat. How do I repair the fabric?
  • darlex319 Apr 05, 2009
    i have a small cigar burn in cloth seat of car. Can i repair this myself
FixinFax
  • 3085 Answers
SOURCE: i have a cigarette hole in my car seat i wonted to
Find some excess cloth underneath of one of the seats
Chop up the fabric with scissors
Put some white glue in the hole
Sprinkle the chopped up cloth onto the white glue.
Posted on Nov 16, 2009
Gps system says being activated but does not come on
1: if you navigate electricity, (with the navigation buttons backlight and the light is on) appears black screen, this is front-facing screen navigation motherboard diodes burn big thermal power flows through the electric circuit breakers in the situation you find the location of the installation let him to give you do after 2: if you don't electricity, navigation, unable to boot, you can see if your cigarette lighter and electricity, if not, congratulations you, your dashboard below there is a small resistance wire burned, to let him help you where you press the navigation in a, this can only show you the navigation of the voltage is not stable. 3: if you navigate difference, can't boot, cigarette lighter is normal, you remove the navigation, navigation and power cord with a plastic plug head, take out to see so you can take off) and see the inside of the resistance wire is disconnected, if there is change a good, if not, then you take the past to let him give you repair.auto diagnostic tool
Mar 14, 2013 | Chrysler Cars & Trucks
Cigarette burn on chair
honestly nothing can be done to fix that
Jan 07, 2011 | Ford Escape Cars & Trucks
I need to remove my headrest to change my seatbelt guide ; i can t get headrest to come off. Thank you
Pull the seat fabric down in front to expose the plastic piece that the headrest bar inserts through. You will see a small wire clip inserted through plastic. Remove it by prying with small flat head screwdriver. Repeat on other side. Headrest will then slide out.
Jul 02, 2010 | 1997 Chevrolet Cavalier
I need to clean the seat cushion but cant remove it
there are small white plastic hooks all around the fabric you need to pull them out to release the fabric
Feb 22, 2010 | Evenflo Triumph Advance LX Convertible Car...
I have a remote car starter, but find that the car does not heat up enough to clear the frost sometimes. I thought of adding a small electric heater that plugs into the cigarette lighter, but in my car (a...
do you have your heater controls set to defrost and the fan on high when you park the car,that way when you use your remote it is already set up.Your scooter though,I guess if it was me,I would run wires up to the front seat so I could plug it in the cigarette lighter while I was driving to charge up.
Jan 11, 2010 | 2004 Jeep Liberty
I have a cigarette burn in my cloth car seat how do i fix it or do you know somebody that does?
un fortunately a burn cannot be "fixed" because the fibers of the cloth have actually been melted. there are a few gimmiky kits out there that supply you with a kind of color matched putty wich makes the burn less noticable. also you could cover it with seat covers or try a locay upholstry shop. They might be able to take the cloth off the seat, cut out the burned area, and apply a patch.
Nov 18, 2009 | 2007 Chrysler Sebring Sedan
I have a cigarette hole in my car seat i wonted to no if there is anyway to fix it or do i need to reupholster it. It a fabric seat on a toyota corona
Nov 16, 2009 | Baby Gear
Cigarette burn in cloth car seat how do I fix this
An auto detailer might be of great help here. They also might be able to refer you to someone. There are upholstery repair kits available to do it yourself for around $10. Always Brilliant.com has one for $8.99.
Sep 16, 2009 | 2006 Ford Explorer
Just bought jane powertwin oro and having trouble putting car seat on front, the existing seat when i fold it down to accomodate car seat seems too bulky, what is the correct way of doing this? thanks :)
Although I have not heard of the Oro, I can advise that with the Powertwin the best thing to do is to remove the front seat fabric, leaving just the frame of the seat on the chassis, move this forward and hey presto!
I hope this helps. (Just don't loose the seat fabric!)
Jul 21, 2009 | Baby Gear
Baby Gear Logo
1,860 people viewed this question
Top Baby Gear Experts
Jennifer Rock
Jennifer Rock
Iron
Iron
Are you a Baby Gear Expert? Answer questions, earn points and help others
