Back to:
Tags:
Panasonic Panafax UF-885 Plain Paper Laser Fax
Panasonic Panafax UF-885 - Heavy lined marks down...
posted by Almandine on Apr 15, 2008
Recently our fax machine has started scanning and sending documents with heavy lined marks down the left hand side of the page. I have cleaned out the whole scanning area, that I can reach, and still the same problem.
I presumed that it was just dirt that I could not reach, but here's the catch: It does not print/scan/send this mark all the time I just managed to do a copy on the machine with marks, then straight after did a copy with no marks?
Can someone please explain to me how this makes sense!
I have the same problem.
This Problem has been added to the Share Your Expertise Page under "My Work Queue".
Solution #1
posted on May 27, 2008
Not Rated (0)
Logjam
Rank:Wiz Wiz
Rating: 82%, 95 votes
First print a report to see if the lines appear without using the scanner. If this is the case clean the charge wire. If you pin it down to the scanner, it is probably a poor solder joint on the cis unit. Take it out and run a hot soldering iron over all the joints on the reverse side of the cis.
Was this solution helpful? Show your Appreciation by rating it:
Thank You!
Was the solution helpful?
Show your appreciation by commenting on Panasonic Panafax UF-885 - Heavy lined marks down side of paper:
I don't want to Accept this solution
Can you Help with these Fax Machines problems?
Fax Machines
recently received a Brother intellifax1800c and i needto...
Fax Machines
Canon fax/scan/copy Model F 146502 - super G3. There was a...
Fax Machines
Casio fx-260 solar calculator: (1) How to put in COMP...
Fax Machines
I have an L4 error code on a Sharp SF 2027 can you tell me...
Fax Machines
I have a canon c6870 copier/fax. I have loaded the...
Loading problems.
Repair Service
Find Fax Machine Repairman Near You:
Browse the Repair Directory
Repairman, Get Listed FREE
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
