Question about Samsung SCX 4521F All-In-One Laser Printer
GRINDING NOISE or PAPER JAM
My Samsung SCX-4521F is making a terrible grinding noise everytime I power it up or run a print/copy through it (It still print/copies but with a lot of noise).
If I pull the paper tray out there is a black toggle/finger that I can press and the machine goes through as if the paper tray was there (including the grinding noise).
The black toggle/finger is to the left of a "black rubber thing", which is positioned dead center inside the paper feed cavity. This "black rubber thing" has one white wheels on each side of it.
Now if I press the "black rubber thing" it clicks up, and then when I got to press the black toggle/finger there is no more grinding noise :-)
... but then I load the paper tray back, run a copy and the print now displays a "PAPER JAM 0" error.
I hope my not very technical description explains my issue (either grinding noise and print OR no noise and no print plus a paper jam :-)
Please help before I unleash my ninja fury on the "black rubber thing"
  • Anonymous Mar 19, 2014
    grinding noise after changing print cartridge
Lub rails front and back. Make sure ribbon isnt seized.
MarkR
Posted on Oct 30, 2012
    Problem Solver:
  • 10 Answers
If you are not a technical person best thing to do is to show it to an expert. grinding noise means some part in the machine is running with the friction. and might brake something or scratch something. Find out persons who work on photocopiers in your area either samsung or Xerox. as this model comes with both the companies and Xerox people are generly better than samsung people.
Posted on Jun 07, 2008
  • rohit Sharma Aug 20, 2013
    check the paper path tray for any particals .... I found Screw in it for the same problem... sory for my english
Copier will not copy feed paper oeven try-justs makes agrinding noise
Dear
Pl. do test as per following.
1- empty paper tray.
2- pull the toner cart. and close the door.
3- power ON the printer. Listen the sound of initial motor run,
(If smooth not grinding noise, check the toner cart OPC drum for jam. If yes check the fusser drive gear and fusser gear and assembly)
If all are ok.
4- Check the paper pick up roller shaft, (sometimes it takes a bunch of paper and jammed if you forcible pull the bunch in reverse direction the shaft may gets bend cause the grinding noise during paper pickup. in that case you have to replace the paper pickup shaft.
Thanks.
Mar 10, 2015 | Samsung SCX 4521F All-In-One Laser Printer
Cannot print 4521f
cartridge inserted poriton ( fuser unit bottom portion ) you can see a small "L" shadped liver fixed with a screw, removed that from there and try with new cartridge.
Jan 15, 2014 | Samsung SCX 4521F All-In-One Laser Printer
Samsung SCX-4521F says it is printing but does not print. It wil copy.
Dear try to use other usb port. Try to use maintenance feature use it. If problem not resolved,replace main PBA of printer.
Thanks.
Nov 24, 2011 | Samsung SCX 4521F All-In-One Laser Printer
Hello... I have a Samsung SCX-4521F Laser Multifunction Machine Print/Copy/Fax/Scan but when i turn on power button...only ear some bip's. Front panel shows nothing.nothing works. Help me please.
This is a sympton that a key may be stuck down. Usually the lcd is not affected but I feel sure you have a stuck button somewhere on the operation panel.
May 26, 2011 | Samsung SCX 4521F All-In-One Laser Printer
When Copying or printing the paper does not feed
open the front cover pull out the cartridge and you see paper feed roller it is rubber. Clean paper feed roller with cloth and water or alcohol.
Jan 24, 2011 | Samsung SCX 4521F All-In-One Laser Printer
Hi I have a Samsung scx-4521F I am trying to send and receive Fax over IP now I know that I have to change the Baud rate to the lower one. but How can I do that? other than changing Baud rate what do I...
I have a samsung scx-4521f i am trying to copy some document but i cannot copy clean. my printer was copy in document black line or black paper ground what do i need to clean copy ? please help me.
Sep 18, 2010 | Samsung SCX 4521F All-In-One Laser Printer
Fax Machine Samsung Model SCX-4521F
Kindly update me Is it printing/Copying working properly.
This issue with printing part. Kindly clear memory. Check Cartridges.
Sep 04, 2008 | Samsung SCX 4521F All-In-One Laser Printer
Can't scan and copy from computer
Why can't you use a regular USB printer cable instead? Those conversion cables are not the most reliable or compatible solutions.
Feb 01, 2008 | Samsung SCX 4521F All-In-One Laser Printer
Samsung SCX-4521F All-In-One
If the lines only appear when using the top feeder, then theres probably white-out or something on the thin strip (called a slit glass) of glass on the left of the large glass.
If it appears when you put a document on the large glass, then it is another problem.
Jan 11, 2008 | Samsung SCX 4521F All-In-One Laser Printer
Samsung SCX 4521F All-In-One Laser Printer Logo
1,685 people viewed this question
Top Samsung Office Equipment & Supplies Experts
mukhtar21 shaikh
mukhtar21 shaikh
HEMANT GROVER
Victorman
Victorman
Are you a Samsung Office Equipment and Supply Expert? Answer questions, earn points and help others
