Question about Symbol MC3000 Portable Terminal
Connection to network
The scanner will not connect to our network.
It has been working alright until now, any solutions??
Henrik
Connect Symbol MC3190 to internet?
Drowin-
Please contact Motorola Solutions ( portal motorolasolutions com )
Mark
Motorola Mobility Support
Sep 02, 2014 | Motorola Symbol Computers & Internet
Epson scanner cannot communicate
My solution was that Epson Scan was set to connect via network instead of local. (All was working fine, then it quit-something changed this setting) Try this, go to start, choose all programs, choose Epson folder, choose Epson Scan, choose Epson Scan Setting. In the pop up box set the connection to local or network, whichever is appropriate. Close the window and open photoshop and all works fine. It could be that your problem is the opposite of mine- I try switching this to the other setting even if the change is wrong, then switch it back to see if that works too.
Good Luck.
Jan 05, 2013 | Epson WorkForce WF-7520 Wide Format...
I have a scanner Canon MP270. I have used it successfully before. Now I get a message on screen: Cannot communicate with screen. Cable my be disconnected or scanner may be turned off'. I have chec
First, please check all USB cable connections, unplug and re-plug the cable both at computer side-port and printer side-port.. Then,check if USB cable is good. If you are sure that's all alright so the logic board of the printer may be faulty. Overall this is about connection problem. Good luck.
More solution about printer at:Printer Clinic
OR
Download Service Manual
Sep 23, 2012 | Canon Pixma MP270 All-in-One InkJet...
I am having problems making my scanner work - I can't scan a document from the printer/scanner/fax/copier to my laptop
How is the all-in-one connected to your computer? What OS are you using? Did you install the full software, basic drivers or the OS drivers? Are you starting your scan from the computer or the buttons on the all-in-one? Is this a newly installed printer or one that has been used several times with this computer?
The Photosmart C7180 can be used with a USB connection, wired ethernet network, wireless network, bluetooth or PictBridge. For a Mac OS, only the USB connection will work.
If you need the drivers, see http://h10025.www1.hp.com/ewfrf/wc/softwareCategory?cc=us&dlc=en&lc=en&product=1153754& and select your OS.
If you connected the all-in-one to the computer via a USB connection before installing the software, you may have an OS driver that does not include the scanner driver. Disconnect the USB cable then uninstall the driver. Then install the HP driver. If you do not install the full software, you will not be able to use the buttons on the scanner to launch a scan. You'll have to start the scan from the computer.
If you have the full software, the HP Solution Center is installed. This includes a monitoring program that should run when you start your computer. This listens for the press of a button on the scanner and launches the appropriate part of the HP software. However, you need to set the button destinations in this software first. I recommend manually scanning at least once to set the appropriate resolution and destination folder for your scans. Then in the Solution Center, click Settings, Scan Settings, Button Settings and then Front Panel Scan Buttons. Set these based on your default settings.
If this all-in-one has been working previously, check your connection. Scanning requires bi-directional communication with the computer and can fail even when the printer works. Try a new USB cable and a different port, if you are using that connection. If you are on a network connection, check that the firewall isn't blocking communication. (Temporarily disable the firewall to check.) In Windows, check the Devices and Printers (Win7's name) control panel and check if the scanner is a listed device. Right click on it and check the properties and status. (All-in-ones are often listed twice - as a printer and as a scanner.) HP offers a diagnostic program, http://h10025.www1.hp.com/ewfrf/wc/doclink?lc=en&cc=us&product=1153754&tmp_docname=c02114802 , to check for issues with the scanner.
Try manually scanning with another program than the HP software. Windows includes some options that will acquire scans. XP, Vista and Win7 all include Paint (File > Import from Camera or Scanner > New Scan). Windows7 (and some versions of Vista) include Windows Fax and Scan (click New Scan). If you have the Microsoft Live software, you also have Windows Photo Gallery (works like Paint).
If you are connect the all-in-one to a USB print server, the scanner probably won't work. Try a different type of connection.
If you are using the all-in-one on a network, make sure that the network is up and the printer has an IP address. I've seen routers lose their connection for various reasons. (Rebooting both the modem and router sometimes cures the problem.)
Please add more information on your specific scanner problem and I'll try to provide specific suggestions.
I hope this helps.
Apr 09, 2012 | HP Office Equipment & Supplies
No connection on internet
Check if the internet Cable At back of the Computer is properly connected.
Repair the Internet connection..
Click Start Then Control panel After that
Click 'Network and Internet Connection' Then 'Click Network Connections',
Double 'Click on Local Area Connection' Hit Support Then Click Repair.
If the Solution Wont work.
Call Your Internet Service Provider (ISP).
>>>>"M.J Trusedell"
Aug 18, 2011 | Computers & Internet
Gateway purchased new 3/2010 has been connecting flawlessly to wireless internet until a few weeks ago. Solution had been to click on Open Network and Sharing Center, click on Troubleshoot problems, click...
Are you connecting to your own wireless router? If yes, have you changed anything in its configuration, or inadvertently reset it? If you're connecting to someone else's router (neighbor, etc.) it could be that they have locked you out. Does the wireless network show as secured? This sounds more like a security issue than hardware or driver.
Jan 06, 2011 | Gateway Computers & Internet
I usually connect to my neighbor's wireless internet. We have had no problems until this morning when the connection to the internet just dropped and stopped working. I have the Linksys WUSB54GSC and it...
Usually such problems occur when the administrator to the internet service decides to block a particular user from accessing the internet or sets a password for users on the internet. The best bet is to contact your neighbour as he will be the best person to tell you what happened.
Hope this solution has been helpful?
Sep 23, 2010 | Linksys WUSB54GSC Compact Wireless-G USB...
Stopped to connect to wi fi
there may be two reasons they are 1) wifi is disabled on your computer to enable it go to run --> and type in services.msc and click on ok scrool down and check for "wireless zero configuration"and click on restart the service 2) You might be disable the wifi on your mechine.
Mar 18, 2010 | Trendware TEW-424UB (0710931502572)...
When I try to open the Scanner software the following comes up... Error = 4 Could not confirm scanner connection.Please check scanner connection. When I try to open the easyscan Utility I get the following...
Minolta's crummy software is notorious for this. Most people can't get it to work even by removing and reinstalling the driver software. The best solution is to use a third-party driver software called VueScan. You can download a trial version for free to see if it works before you commit to buying it. If this doesn't solve it, you most likely have some sort of hardware problem.
http://www.hamrick.com
Jul 19, 2009 | Minolta Dimage Scan Elite 5400 Film...
Archos 605 usb connection problem
its possible you could have picked up a virus that is making unauthorized changes to your pc. happened to me. had to reboot pc to original factory settings.
Jan 27, 2008 | Archos 605 WiFi Digital Media Player
Symbol MC3000 Portable Terminal Logo
125 people viewed this question
Top Symbol Computers & Internet Experts
Gareth Cockram
Gareth Cockram
Greg Cann
Greg Cann
Michael
Are you a Symbol Computer and Internet Expert? Answer questions, earn points and help others
