Question about NetGear : WG111 54 Mbps Wireless USB 2.0 Adapter, RETAIL (DSNGWG111)
Onnecting Netgear WG111v3
I installed the adapter software it is scanning okay and found my network but it it says it has limited connectivity and I cannot use the internet etc, The router is netgear wireless asdl. The firewall is off on the computer with the adapter in but it just keeps saying limited connectivity, how do I get it to the next stage so it works? I have put the wep pass in and it has found my network okay and has good strength. Any help appreciated/
  • 61 Answers
Make sure that the ariel on both sides is connected fully
Posted on Apr 24, 2008
How do I install my netgear memory stick netgear WG 111 v3 on to windows 7
  1. Install the driver from this page: WG111v3
  2. Follow the installation instructions, which can be found here: http://www.downloads.netgear.com/files/GDC/WG111V3/WG111v3_IG_03Mar08.pdf
Instead of using the CD, use the firmware which can be found on the first web page.
Aug 13, 2014 | Computers & Internet
Tip
How to Install WG111v3 on MAC OS 10.3 , 10.4, 10.5
<p>The below article would illustrate the steps to install the NETGEAR wireless adapter WG111v3 on MAC OS 10.3, 10.4 and 10.5.<br /> <p><br /> <p>Please ensure that you have installed the latest version of driver for the adapter from the below link on your MAC OS computer:<br /> <p><br /> <p><a href="http://kb.netgear.com/app/answers/detail/a_id/2640">http://kb.netgear.com/app/answers/detail/a_id/2640</a><br /> <p><br /> <p>After the installation of the driver please perform the below task:<br /> <p><br /> <p>1. Plug in the adapter.<br /> <p>2. Double click on the NETGEAR WLAN Client Utility in the desktop.<br /> <p>3. On the NETGEAR WLAN Client utility select the Available Network tab which will detect the wireless network, select your network and click Connect.<br /> <p>4. If you are connecting to a secured wireless network then you will be prompted for a Wireless Network Security Properties menu.<br /> <p>5. Type the network key WEP/WPA security and click OK.<br /> <p>6. Click on Link Status which shows the connection as connected.<br /> <p>7. Check for the IP address by clicking on the Apple icon and select System Preference.<br /> <p>8. Click on Networks and check the IP address.<br /> <p><br /> <p>You should have succesfully established the wireless network on your MAC.
on Mar 24, 2011 | Computers & Internet
Where can i download the installation cd for netgear wg111v3
Here is the solution for your netgear wg111v3 wireless usb adapter,
click the link for download driver for netgear wg111v3 wireless usb adapter
Download Link
please let me know if problem solved or not.
Thank you for using fixya.
Regards
Manish
Jun 06, 2010 | NetGear : WG111 54 Mbps Wireless USB 2.0...
My Netgear WG111v3 cannot connect to internet
You need to do some wireless setting on router,
Please follow steps to fix your issue
1.Please changed network (SSID)name of router
2.Reinstall adapter driver
If you follow above steps defenately your issue would be resolved
Apr 26, 2010 | NetGear : WG111 54 Mbps Wireless USB 2.0...
Netgear WG111v3 adapter keeps stopping
Please do not use the USB Extension cable that came with the adapter and instead connect the adapter directly to the computer on USB port. You may try connecting it to a diffrent USB port. Otherwise, please update the drivers for the adapter from the below link:
http://kb.netgear.com/app/answers/detail/a_id/12962
Hope this helps you to resolve the issue. Let me know if you need any further assistance.
Regards
Anand
Apr 11, 2010 | NetGear : WG111 54 Mbps Wireless USB 2.0...
Cannot connect to my wireless router
You can download driver for windows-7 compatible
(download and install in computer)
If your issue not resolve please revert back to us for further
Thanks for using Fixya
Apr 09, 2010 | NetGear : WG111 54 Mbps Wireless USB 2.0...
I installed the software for a netgear WG111v3 and it hangs
redo the driver first remove the program and restart the pc then start again this normaly helps in 90%of cases hope this helps you
Mar 17, 2010 | NetGear WG111 802.11g/b Wireless Adapter
Netgear wg111v3 adapter quit working with an error message
Go to the Netgear website, and download the newest software update. I was running 1.4 from the provided CD and got this message. I completely uninstalled 1.4 and installed 2.0.0 and it works like a treat now. All you need is the updated software.
Dec 29, 2009 | NetGear : WG111 54 Mbps Wireless USB 2.0...
Wireless network adapter not working
I've had a similar problem with a USB wireless adapter working ok for over a year and it recently stopped connecting because it would keep scanning different channels every 30 seconds or so.
The solution that worked for me was to change the default radio channel on the access point (for my netgear router I did this by logging on to 192.168.1.1 and changing the settings in there).
Changing the channel from the default 11 to (lucky) 7 did the trick. The router notes say that changing channels may help if another access point is interfering with the signal, and my issue only cropped up when some new neighbors moved in so my best guess is they were also using channel 11. Hope this helps.
Apr 24, 2009 | NetGear WG111T 108 Mbps 802.11g Wireless...
Installation not installating!
Did you try this ?? there is a self help page on the Netgear Web site for the WG111V3
http://kbserver.netgear.com/kb_web_files/N101741.asp
Hope this helps
Dec 23, 2008 | NetGear : WG111 54 Mbps Wireless USB 2.0...
NetGear : WG111 54 Mbps Wireless USB 2.0 Adapter, RETAIL (DSNGWG111) Logo
366 people viewed this question
Top NetGear Computers & Internet Experts
Prashant M
Prashant M
Are you a NetGear Computer and Internet Expert? Answer questions, earn points and help others
