Question about BenQ FP731 17" LCD Monitor
LCD Screen problem
Hi, I have an lcd screen which is palying up. When you switch it on it satrts up and the normal no signal notice appears for approx 1 second. If I then plug in the RGB into my laptop the laptop desk top appear on the screen for approx 1 second then disappears. The same thing with a desktop. Whenever I plug in a RGB the screen gets the siognal for approx 1 second then the screen goes black again. (please note: If I leave the LCD switched on and keep pulling RGB in and out of laptop everytime cable is attached the screen comes on for approx 1 sec the black again)
  • 472 Answers
You have a failed inverter circuit. This is a very common fault with BenQ and other LCD monitors. I have seen more FP737 and FP731's and all their cousins in the last 2 years then I care to count.
You will be best to take it to a TV technician and have them do the repair. There are ways to fix it yourself, but the chances of success are not great without a decent amount of electronic knowledge.
Call several places and get approx quotes based on the inverter fault. A lot of TV techs will not work on LCD monitors and is another good reason to call around first.
One final thing, check the manufacture date on the back of the monitor, these normally come with a 3 year warranty and it will be either expired now, or very close to it. If it is still under warranty, then contact BenQ near you to facilitate the repairs.
BenQ support webpage.
Posted on Apr 15, 2008
White line running through cente of screen
Hi there, If the line appears already from when you switch on your Laptop then it means your LCD/Screen is busy breaking. The white line is normally caused due to loose contacts inside screen and cannot really be repaired.
regards
Jul 29, 2011 | Advent Computers & Internet
Toshiba flat screen problem
If you wish to get some details; visit the site linked here. Pull up older posts.
Line faults & possible causes to LCD & Plasma screen are given with illustrations. You can get an idea about the fault to an extent. Faults to all LCD & Plasma screen are similar, irrespective of its brand and screen size.
Aug 15, 2017 | Toshiba Televison & Video
My SOny Bravia 40 inch LCD TV has a vertical line
It could be 1 of 4 things:
1. One of the ribbon cables has worked itself loose (Simple Fix)
2. One of the assembly boards maybe faulty
3. The driver board which feeds the panel maybe faulty
4. The panel is faulty
The driver board in the UK costs approx £70 and approx £35-70 to fit it if this is the fault.
All other parts are between £80-160 and approx £35-70 to fit it if this is the fault.
The panel will cost approx 50-75% of what the TV was worth when you bought it - "Repair versus Replacement"
Thanks
Oct 01, 2009 | Sony BRAVIA KDL-40S2010 40 in. LCD...
Flashing screen when i first turn on my SamsungSyncMaster 2232 bw
I had a similar problem with my LCD computer screen. I took it apart and noticed a capacitor that was raised up on the flat end and appeared to be leaking a substance. Replaced it with a similar capacitor and works fine, for three years now.
Jul 05, 2017 | Samsung SyncMaster 2233BW 22" LCD Monitor
Turning the power on causes the screen to display ENVISION for approx. 1sec.and it goes out and stays out. Switching a display signal on through an A-B switch gives approx. a 1sec. display time that does...
Your power supply has burnt out which unfortunately is extremely common in new devices. I do agree that it may be worth fixing if it is only couple years old.
Jun 11, 2009 | Envision EN-7220 17" Flat Panel LCD...
White screen appears, Screen turns fuzzy intermittently
To determine if the video card is faulty or the LCD screen, connect an external monitor to the laptop. Power up the monitor first and then the laptop. The video will automatically switch to the monitor. If you see a normal Windows image the the video card os OK.
The next thing is to reseat the video cable and if this doesn't fix the problem then the fault is the LCD screen.
May 23, 2009 | Acer Aspire 2930-4661 Notebook
Lcd screen- bright is low
Sometimes there is a switch on the laptop on the keyboard bezel, up by the screen. Check to see if it's stuck down somehow. That switch cuts power to the inverter.
Also, when you first turn on the computer, do you hear a very faint hissing noise? If so, you may have a short in your LCD. Replacing the LCD would be the next step in this case.
Jan 24, 2009 | Acer Aspire 1690 Notebook
Shadows on screen
Try moving a medium powered magnet (not one for picking up heavy objects and not a refrigerator holding one) over the distorted area. If that doesn't work, try a more powerful one. This worked for my Toshiba LCD. Good luck!
Jan 04, 2009 | Sylvania 6626LCT 26 in. LCD Television
Intermittent Defect on LCD TV
If new, you should not remove anything, just send back to store or Manufacturer
Mar 13, 2008 | Philips Magnavox 27MS343S 27" TV
LCD screen black, no viewed image displayed.
Internal video out connection may be bad, try using the provided cable to connect to TV and disconnecting to see if it returns to normal.
Apr 30, 2007 | Ricoh Caplio GX Digital Camera
BenQ FP731 17" LCD Monitor Logo
319 people viewed this question
Top BenQ Computers & Internet Experts
JP Services
JP Services
Tony
Tommmix
Level 1 Expert
Are you a BenQ Computer and Internet Expert? Answer questions, earn points and help others
