Question about Nokia 6680 Handheld
Hi nid help
My phone is ok execpt for 1 thing i cant recieve txt messages but the signal is also good u can even recieve call, execpt txt msg
  • 25 Answers
Can u send txt messages?? if u cant, then i guess u should contact your service provider and make sure the SMS center number in use is the right one, provided by your service provider.
if the SMS center number is ok, then try deleting some messages from the phone and set the SMS memory on the memory card and see if that helps..
i think it should do the trick.. cheersz
Posted on May 30, 2008
I cant send txt msg, my service center number is gone, i think i need the service center number? at@t network
Good Morning :
for sending text messages :
1.go to your message settings and check the message center number to see if it is correct
2. call to your network operator customer care
3. request the message center number...
4.note it down
5. go to message settings>message center number
6. insert the number which is noted by you and save it
this solves your messaging problem ...
Good luck
Dec 03, 2012 | Net10 ZTE Merit Z990G Prepaid Cell Phone
Why not sent my txt msg but i recieve txt msg.
check your message center number.... u can ask your friend that using same provider.... ask for his/her message center number and then set your message center number exactly like him/her... that should fix your problem... good luck
Jun 15, 2012 | Sony Ericsson P990i Cell Phone
I cant send sms to any number.
either your service is down or the msg service center number in the options is changed..
Mar 18, 2011 | Chikka Txt Messenger
I can receive txt msg and make and receive calls on my nokia e65 but cannot send txt msg. Why would this be?
hi....
I think when you send text message it says message failed...right..???
This is because there is option in your mobile called as message service centre number.please check weather this number is correct.Call your service provider and you can get this number.
And also there is an option called as reply via same message centre please put this to 'NO'. now you can send messages
To go to this options please check follow these steps....
1.open 'menu'
2.open 'messages'
3.Go to 'message settings'
4.in that open 'text message'
5.there is an option called as 'message centre',please entre your new message centre number and save it. set this as your message centre
6.Check the option 'reply via same centre' and please put it to 'NO'
Thanx
Jul 17, 2010 | Nokia e65 Cellular Phone
SMS
to turn off predictive text go into messages-select- create new -select-message-text message-select then press and hold the * key and you will see in the top right corner it changes from ABC to abc or T9. to send sms messages go to settings -select -application settings-select-message-text message-select-sending options-select- GSM alphabet then maximum then text.
Hope this helps.
Sep 09, 2009 | Samsung J700 Cellular Phone
How come my Nokia 7610 cant send anymore txts and cant recieve any either?? it also cant accept any calls.. and also my phone battery gets drained so easily
Hi!... If the phone has signal an then you can't send and recieve text try to goto> Message> Message settings> Message Center Number or Center number , then compare it with another user with the same network if its the same or else copy his/her Msg Center Number if he' she is able text... And for your battery problem, how long are you using the battery?... If you always leave it overnight charging so it might be damaged or leak,... Try to buy a new battery...
Jun 19, 2009 | Nokia 7610
Cant recieve picture messages
before receiving or sending picture messagers u must activate the MMS settings by requesting ur network provider only then u can send or receive picture msg
if u hav a signal problem nothing can be done
a small suggetion is in stores they sell a external antenna try getting it and fix it
tat helps in signal problem
Jan 17, 2009 | Sony Ericsson W910i Cellular Phone
I CANNOT FINISH TYPING FOR TXT MSG.
reinstall ur mobile software..its a oly thing to solve ur problem
Sep 19, 2008 | Motorola Mobility V190 Cellular Phone
Sending txt message
chk msg centre number,sent msg as text shud b there,msg validity shud be maximum,and reply via same centre shud be no in settings..chk these settings in ur message settings..
Sep 23, 2007 | Nokia N95 Cellular Phone
Phone freezes when trying to type a txt msg
Do you have too many text messages stored on your phone? I had a phone like that, If when I neared the storage limit it would stop allowing any entering of text messages. Just go to the menu button when your in the text message area and press the menu key, scroll down to cleanup messages, select it and delete them all.
Nov 12, 2006 | Motorola Mobility RAZR V3
Nokia 6680 Handheld Logo
111 people viewed this question
Top Nokia Computers & Internet Experts
Computer Links
Gopi Venkatesan
Gopi Venkatesan
Are you a Nokia Computer and Internet Expert? Answer questions, earn points and help others
