Question about OKI Office Equipment & Supplies
Does anyone know what is 980:fatal error on an OKI C5600 colour laser printer?
If you look on top of the fuser roller(upper orange roller), there is a thermistor (orange rectangle plastic that rides on the roller) you will see four wires going into that housing. Two are for the thermistor and the other two is for the fuse that is built into the housing. You would have to use a soldering iron to melt the plastic that the fuse is sitting in. You would have to figure out what to use as a fast blow fuse.
Okidata makes it difficult to take out the thermistor because the nut is locktite on the screw. Try using the soldering iron to melt it. Just make sure you dont damage the thermistor.
Posted on Jul 03, 2009
  • Troy Brown Jul 10, 2009
    Disregard most of what was said above. I was able to reset my Fatal
    Error 980 code on my C5800. There is only two wires coming from that
    connector and not four at the bottom of the fuser. That is pin 2 and 3.
    4 and 5 is still the fuse but there are no wires there, just the 2
    pins. What you have to do is make a fuse by connecting pin 4 and 5
    together with a piece of wire and break the wire after a few seconds
    after powering up. This will reset the Fuser counter back to 100%. DO
    NOT DO THE NVRAM RESET, THAT WILL ERASE YOUR NETWORK FEATURE. Here is
    the step by step of what I did.
    1)Take out the Fuser and lay the two blue levers flat and remove them.
    2)remove the two silver screws and separate the casing.
    3) Remove the two black screws from the connector at the bottom of the fuser closest to the edge.
    4)Unravel
    and loosen the wires so you can pull that connector out a few inches so
    you can get a couple of wires in there. You will see what you need to
    loosen to get the connector out far enough, really easy.
    5)Insert
    a wire into each of the two holes on the back of that connector. Its
    pretty simple to see where they go, 2 and 3 have wires going in, 4 and
    5 dont which is the fuse. After you get the wires in the 2 holes, check
    for continuity from the end of the wires and the terminals if you can.
    Make sure the wires are long enough to hang out the case. Use the
    thinnest wires you can find.
    6)Run the wires out of the case and
    put the case back together and put the fuser in. Twist the two wires
    together and power up the machine. As soon as you here the first
    motor,which is about 5 seconds, pull the wires apart and BAM, you just
    reset the fuser back to 100% and cleared the "980" Fatal Error. You
    could always put a miniature fastblow fuse in instead of using the
    wires but that would be tedious to me.Good luck
According to the Oki service manual that problem is related to the fuser. The reference is that there's some media stuck in the unit, they recommend replacing the fuser but it's possible just reseating it with power off will allow it to clear the code.
Posted on Apr 21, 2008
I followed the July 10, 2009 instructions made in the comments. After taking it apart, I realized i had some tracing wire in my toolkit, and instead of trying to connect it internally to the connector - I ran them very carefully down the outside and down the flange of the connector. This made it very easy to remove the wires after the fix was done.
Posted on Feb 05, 2010
OKI C330dn Call Service fatal Error:980
That particular error indicates a fuser failure. Try turning off the printer and re-seating the fuser. If this does not clear the message then the fuser needs to be replaced. With such a low number of prints warranty should cover it.
Aug 29, 2014 | Oki Electric Industry C330dn Led Card...
How do I reset fatal error code 980 on a oki c5650
Oki is forcing you to buy a new fuser. If fuser roller, film and thremistors are still in perfect shape, reset is possible with new OEM FB fuse
Jun 18, 2011 | OKI C5650n LED Laser Printer
My printer model is OKI C5600n. On the displey stay message: Call services. 980:Fatal error. Where is a problem ? Whats is possible doing now?
Error 980 means that there is something stuck to the fuser. Check to see if there is something is stuck in the fuser. If you can't clean it out, then you will need to replace it.
Mar 22, 2011 | OKI C5500n Laser Printer
Error message: Service Call 980 - Fatal Error
It means a call to OKI will be necessary. Typically, fatal errors are related to internal ROM, or board components that effect the boot process of the printer. When it can't boot - you get this type of message.
Dec 31, 2010 | OKI Electric Industry B4545 Laser Printer
I have a OKI C6150 got a jam now I have a Fatal #980
Inside fixing unit are also thermoswitch and thermistor wich can burn out, but also the fixing lamp too. You must dissasemble it and by DVM test the circuits, if the circuit is opend on thermistor, that means that he is burnd out.
Jul 08, 2010 | Oki Electric Industry C6150N Laser Printer
I have a Oki b6500. Replaced the fuser. How to reset the message exchange, "Maintenance." Please help!
The following procedure was provided by Oki Tech support when a web search did not provide an answer. Resetting the Fuser After Replacement - When Counter is NOT Reset First print out a MenuMap and note the fuser count, to later verify that the maintenance reset has taken affect. To reset the fuser counter, enter the diagnostics mode and go to Maintenance Mode Step-1 How to enter the maintenance mode. Hold the Menu & Right arrow button while powering on the printer. Hold the buttons down until the op panel displays “Initializing”. The op panel will display “Output Test” Step-2 Press the down arrow three times. The op panel will display “Maintenance Info” Step-3 Press the right arrow. The op panel will display “Reset Maint Reqd Execute” Step-4 Press the select button. A quick flash will come up on the op panel “Resetting Maintenance Reqd”. The op panel will then display “Reset Maint. Reqd. Execute” Step-5 Press the Cancel button to exit the Maintenance Mode and go back to “Online”. This completes the process, please print out the Menu and inspect the Fuser Count it should read ‘0.’
May 19, 2010 | OKI B6500 Led Printer
How do i solve fatal error 980
i got that error on the first day i got my oki c5950 it was a result of a paper jam in the fuser unit, i removed the jamed paper but the error was still there, i contacted oki support and got a detailed explanation on how to fix this error with a patch file, so if u or anyone out there r still having that problem send me a mail on ecks80@hotmail.com and i will forward u the info.
good luck
Sep 14, 2009 | OKI C5500n Laser Printer
Oki c 5600 980 fatal error
The error means that the media is wrapped around the heat roller of the fuser. The only way to reset this error is to replace the fuser unit.
Jul 20, 2009 | OKI C5500n Laser Printer
Fatal error 980 OKI C5500 printer
I had a paper jam and removed the jammed papers. The paper jam cleared and then the Fatal Error 980 appeared. OKI C5500 printer
Mar 15, 2009 | OKI C5100n Laser Printer
OKI C5600 printer is printing Blank pages
you looking at 3 posibles one is the scanner may need to be replace or the low voltage power supply or you looking at a posible drum problem
Nov 22, 2008 | Ricoh Aficio 250 Copier
2,217 people viewed this question
Top OKI Office Equipment & Supplies Experts
Jimbras
Level 1 Expert
Don  Farrell
Don Farrell
mukhtar21 shaikh
mukhtar21 shaikh
Are you an OKI Office Equipment and Supply Expert? Answer questions, earn points and help others
