Goodmans GTV30W2LCD Sound with no picture, screen flashes up at switch on then again goes blank.
SWITCH TV ON PRESS REMOTE FROM STANDBY TO ON PICTURE APPEARS THEN FADES AWAY THEN I HAVE NO CONTROL OVER THE REMOTE SWITCH MAINS OFF AND TRY AGAIN I MAY HAVE TO DO THIS FOR 4 OR 5 TIMES BEFORE PITURE REMAINS HELP PLEASE
Posted on Jul 13, 2011
Mine has just done the same thing, i had someone look at it and he said the picture had gone. its not worth repairing it as it cost more than the tv is worth. your better off buying a new tv.sorry.
Posted on Mar 27, 2009
  • herbiebling Mar 27, 2009
    sorry, the picture TUBE had gone.
TV screen is blank but the program is still playing
Check the cables, makes sure all connections are still snug. If your using HDMI, try swapping it out for one you know works. There are a lot of lemons out there.
Feb 24, 2016 | Televison & Video
Philips instruction manual
YOU NEED TO REPLACE BAD CAPS ON MAIN POWER BOARD 4167e67a-4c77-4574-ae00-a26d52afd0ea.jpg
Jul 29, 2014 | Philips 42PF5520 42 in. EDTV-Ready Plasma...
Blank screen but have sound
fault is most likely from your screen inverter. the inverter is in charge of display. There is every tendency that the inverter is defective and needs replacement.
Good luck.
Nov 28, 2012 | Goodmans GTVL19W17HDF 19 in. LCD TV
I cannot tune my goodmans gtvl19w17hd tv
If you have sound, then your tv doesn't need tuning. Shine a bright light onto the screen, can you see a very dim picture? If so, your backlight has stopped working. This is almost always due to the inverters failing and can be repaired.
Jan 26, 2010 | Goodmans GTVL19W17HDF 19 in. LCD TV
Screen goes black but still sound
This is inverter or backlighting problem. Can you try switching it on and off quickly for a couple of times and tell me if these '2 seconds' get any longer'. If picture stays longer and longer before shutting down, one lamp needs replaced-if not, please replace inverter board
Jan 15, 2010 | Goodmans GTVL19W17HDF 19 in. LCD TV
TV SREEN GOES BLANK, BUT AUDIO CONTINUES NORMAL,
Try unplugging for 36 hours. I had the same problem but with no sound and picture
Mar 03, 2009 | Sony KP-53HS10 TV
Switch on, picture for 5 sconds, then go black, sound fine
ime in the same boat man cant get nothing on mine
Jan 25, 2009 | Goodmans W280NS Television
Goodmans 289NS standby light flashing amber no picture or sound
50% trouble of tv is lose connection so, try to re solder it but be care of short circuit
Sep 28, 2008 | Goodmans 289NS 14" TV
I own a goodmans gtv26wlcd and have recently had the problem with the screen going blank, the sound remains but the screen switches off this happens just a few minutes after switching the TV on.
Is this a set sold in the USA? I have never heard of this brand. It sounds as if the back light is shutting off maybe the powe invertors feeding it are breaking down. Or your signal board is going on you. I hope you have aschematic and access to Goodmans parts?
Aug 22, 2008 | Televison & Video
Goodmans flat screen TV.Blank screen
If it is a LCD TV, and there is a faint picture, it is probably the backlight or inverter board (probably the latter). This is a common problem (especially with PC monitors).
Do an internet search for your model and inverter, you may be able to replace it.
Make SURE you REMOVE the power lead before opening the set !!!!
Dec 30, 2007 | NEC PlasmaSync 42MP3 42 in. Television
Televison & Video Logo
138 people viewed this question
Top Televison & Video Experts
