Hoover vision hd 1400 washing machine not draining. Drum does spin. Time saver button flashing but not activated and if pressed does nothing.
  • 5 more comments
  • kells11 Aug 14, 2008
    stops in cycle, and will not drain, flashes on timesaver, repair men been out 3 times and they havent got a clue, really fed up now.
  • DougieB Jan 04, 2009
    Drum will not empty. Time Saver and speed flash intermittently. Remove back cover, removed pump (2 inlets, one outlet). Some coins in trap, but not significant. Removed pump and dismantled. Pump looks healthy (only 18 months old). No damage to blades due to coins. Thinking problem may be on 2nd pump that connects to this one. Other option is blockage in pipes.
  • Anonymous Mar 25, 2009
    Time saver button flashing intermittently. Machine will not start. Filter clear.
  • maria murphy Mar 31, 2009
    wont drain, no blockage visible, washes continually timer saver light flashes everything stops working
  • Anonymous Apr 14, 2009
    Starts wshing, then stops. Timer light flashes s odes 1200 spin spped (not doing 12oo spin wash). Problem was intermittent, but now seems to be happening on every wash. Was coping by switching it off then setting it to rinse, but it's now happening on the rinse cycle as well. So far it still spins and drins ok but I suspect it's only a matter if time.
  • Anonymous Mar 21, 2014
    the 15 min ,time saver, sensitive care and stain blaster flashing
  • Anonymous Mar 23, 2014
    Vision hd
I had the same problem. The machine would wash but not drain and the time savers button would blink. Turned out to an eye from a teddy blocking the pipe that enters the drain. I hope this helps.
Posted on Mar 16, 2009
I had the same problem, I called a free quote engineer who said it was the panel, £80 for the part + fitting. My dad then sent his mate round (20 years experience), found a magnet loose on the motor, fixed it no problem for a small fee ( a lot less than Hoover charge, and a lot less than the needless new panel). My advice is to get somebody out on a no call-out charge and mention this to them.
Posted on Apr 19, 2009
Got machine replaced after 4 engineers had no idea of the problem, received the more up to date model, after a stern letter to Hoover, the replacement runs like a dream no probs ever since.
Posted on Mar 17, 2009
Hoover vision hd
the bearing are gone
Jan 18, 2014 | Washing Machines
Hoover vision hd 8kg door security button flashing
i now have same problem- did you get a solution?
Feb 17, 2012 | Hoover Washing Machines
VHD 814 Hoover Vision HD wash stops and timer saver light flashes. Does not wash properly and have to select spin manually. Any answers?
this happens with mine too....
Any solution would be very welcome. The machine seems to have a mind of it's own.
Dec 21, 2010 | Hoover H160E Front Load Washer
Hi i was wondering if you help.my hoover hd vision
my hover washer dryer 1200 spin will not spin water comes into the drum and will not spin
May 12, 2010 | Hoover H160E Front Load Washer
Hoover vision HD 1400 AAA 8kg washing machine - wont start & four flashing lights on timer delay ?????? any advice pls
can I have the instruction how to use for HOOVER vision HD 1400 AA+A. I lost the manual
Feb 01, 2010 | Washing Machines
The water does not get pumped out of the machine
The filter is to be found at the bottom front left of washer behind a removeable plastic trim, if you can see a screw in the filter cover, undo this, and turn filter anticlockwise to remove.
If no filter at front, then remove rear panel of washer, and remove large black hose fastened to drum, check for blockage here, and check the pump at the same time.
Thanks
.Please rate my solution;
Nov 08, 2009 | Hoover AAA160 Front Load Washer
My hoover washing machine 1400 spin 8kg hd vision hd
It appears your timer/main controller has failed in this instance.
For replacement parts - head on over to PartSelect.com or RepairClinic.com and enter in your full model number for a full parts listing.
I recommend both sites because ...
FixYa has no affiliation with either site - I have been using and recommending them for years - trouble free.
PartSelect has a great schematic database for locating the part on your unit and great "testimonials" for each part that often times includes HOW-TO information.
RepairClinic has pictures of each part they sell and also a great how-to and troubleshooting for basic repairs.
If your unit has never been serviced - there should still be an original service manual enclosed in plastic taped to the inside of the shell.
In the service manual are Error codes, maintenance procedures, and troubleshooting steps you can follow.
Anything too complicated or beyond your scope should be handled by a professional.
If you think you want to tackle the repair - and have gotten stuck on a step - reply to your question and I will be glad to help you out.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question!!!
Mar 02, 2009 | Washing Machines
Water wont drain from Machine or go onto spin cycle
either the level control switch has become blocked or faulty or the drain pump has become stuck.
disconnect from the mains and gain access to the rear look for a circular unit with two or three electrical connections and a plastic tube. this is the level control.follow the tube to its start and you will find a plastic connection that goes into the wash drum, remove the plastic tube from the switch end and blow into it. if there is no restistance then the system is OK at the drum end. next reconnect the tube to the switch and remove the opposite end, very gently blow down the tube and you should hear the switch operate. Test wether the switch is working by putting a meter across the switch and blow into the tube. if all of this is OK then the drain pump is at fault. locate the drain pump. it is connected to the outlet tube, try turning by hand. if it does not rotate smoothly remove the clips holding the pump body together and clear the obstruction.
Dec 27, 2008 | Hotpoint Aquarius WF210 Front Load Washer
Hi On my washer when I press the start button when allready in opperation all the lkights flash and it stops as this second press of the button pauses the machine and need the start button to be pressed again to restart the machine
Hope that is cleas and helps
Angela
Jun 22, 2008 | Hoover H130E Front Load Washer
Washing Machines Logo
3,167 people viewed this question
Top Washing Machines Experts
