According to this page, you can usually fix this 4 blink diagnosed problem by changing the air filter or tightening wiring (which it has a cautionary warning about tightening such too much) and checking the flue for blockage. The furnace has activated the primary open limit circuit.
Poor air flow in the Goodman caused by blockages can result in the tripping of the rollover switches which would cause it to blow cold air. That is a safety measure. You don't want gas furnaces burning with insufficient air. Think carbon monoxide. Besides the air filter, the flame sensor or the burner could be dirty. The idea of trying to DYI that cleaning job is rather off putting. I hope changing the filter would work.
I trust it is not a fuse in the pilot flame sensor circuit blown. A repairman has the voltage testers for checking the electronics involved.
I can empathize with this. My furnace, another brand, went out recently. The repair man didn't know why it went out but simply adjusted a handle controlling gas flow to a position slightly different from what was recommended and it worked. All for $200.
The model number you listed is for the outside unit which does not have a filter. The indoor part of this system (the furnace or air handler) is what has the air filter. The size varies because the installer usually makes a bracket to hold the filter when the furnace is installed. Need to locate the filter and replace it with the same one. Size should be marked on the old filter.
You unit is under locked out mode due fail on start up. Get sand paper clean out the flame sensor, and jump the 2 wires that go to the pressure switch as soon as the inducer came on. Doing this the flame should stay on until it meet set temp at thermostat . If it does what said your pressure switch need replacement . Good luck and keep me up to date .
it could be condensation. or poor seal at roof. probably the seal at roof. also check the larger copper line is it sealed good? if any spot is not this will cause leaking when in cooling mode. maybe dripping from line onto vent.
On the bottom of the indoor unit should be a cover or tray. Sometimes a large grill inside the house, close to the unit is where they are placed. Good luck
sounds like the fan switch in the furnace is coming on and off. This is common for Goodman. or could be the heat anticipator on the t-stat. While there are several reasons this happens these are the most common.
