Question about BenQ FP71G 17" LCD Monitor
Screen has power but is black
Hi, if i press the power button to turn on the screen, for a split second the benq symble appears, then black. I have pulled apart the screen. it seems there are 3 faulty parts,printed beside these parts on the circuit board are the folowing C826, Q805, and PF801. I have taken the board to a local electronis shop and they don't have these parts, where can i get them and will they fix my problem once they are replaced. Thank you
  • 1 more comment
  • louie75 Apr 15, 2008
    where can i get a LCD inverter board from? for my FP71G BenQ 17"moitor.
  • Troffaes Guido
    Troffaes Guido Jul 21, 2008
    Hi ,
    After quiet some looking I found this site ,describing the same symptom that I have .Meaning when I switch on the power I see the Benq symbol appearing for less then a second ,then the screen goes black.I switched to another computer and laptop ( specifying an external screen) , I swapped the signal cable.. no succes.
    When opening the case I don't see any transistor,diode or resistor that looks burned nor any capacity that is leaking or whatever . (Yet I don't have any measurement tool )
    Any suggestion how I can continue my "fault isolation" please ?
    Can anybody provide me the address where I possibly could order a new power board or convertor board for this TFT ?
    Many thanks in advance !
    Guido
  • Peter Thompson
    Peter Thompson May 11, 2010
    I will put this in a request form just so Eagle gets full credit where it is due.
    You will have to send an email to BenQ in your country and request the part. They will in turn reply with a yes we can, or try this place instead response.
    visit www.benq.com and goto the support section for the correct contact info.
  • 4,889 Answers
Looks like many faukty parts on the inverter board.. replacing will not be of much help as it will soon start get troublesome once again. I would suggest that replacing the LCD inverter board is a smarter solution. Hope this helps!
Good Luck!
Posted on Apr 15, 2008
I have two issues with the pb8220 1. How do you reset the bulb hrs when a new bulb is installed? 2. Projects for about 10 seconds then goes black. The red bulb light comes on when the screen goes...
Reset the lamp hours as follows.
Press the Exit button on the projector for 3 seconds to display the total used lamp time. Press the MENU button on the projector during the lamp hour message. An adjustment message will appear. Press left or right arrow to reset lamp hours or press EXIT to leave.
sonsunny
Jul 09, 2011 | BenQ PE5120 Multimedia Projector
Hi there. I've got a benq mp721 which i've just changed the lamp on. the problem is: how do i reset the lamp timer?
Turn On projector, press EXIT and Up Arrow buttons on projector for 5-6 seconds, lamp hours display will appear, press Auto on projector or its remote to reset lamp hours to zero, wait 5-6 seconds to display will get disappear itself.
Thanks.
Jan 20, 2011 | BenQ MP721 DLP Projector
It won't start it just has apple on screen
hi
try to reset your phone
To reset i Phone, press and hold the Sleep/Wake button and the Home button at the same time for at least 10 seconds. During this time, a red "power off" slider may appear and the screen may go black, but do not release Sleep/Wake and Home buttons until the Apple logo appears.
If i Phone won't turn on, or the display freezes or doesn't respond
  1. Press and hold the Home button for at least six seconds, until the application you were using quits.
  2. If that doesn't work, turn i Phone off and turn it on again. Press and hold the Sleep/Wake button on top of i Phone for a 10 seconds until a red slider appears, and then slide the slider. Then press and hold the Sleep/Wake button until the Apple logo appears.
  3. If that doesn't work, reset i Phone. Press and hold the Sleep/Wake button and the Home button at the same time for at least ten seconds, until the Apple logo appears
More resets:
Try This:
1. Remove Sim Card
2. Hold in 'Home' button and 'On/Off' button together until Apple logo appears
3. Replace Sim Card
4. Hold in 'Home' button and 'On/Off' button together until normal phone screen appears.
Also, Try this:
1.) Shut down the i Phone 3G.
2.) Start up i Tunes
3.) Hold down HOME button on the i Phone 3G
4.) While keeping the HOME button depressed, plug in the Sync cable
5.) A message will pop up to ask if you want to reset.
6.) Just click YES and the reset process should start.
if this was helpful kindly vote for this answer..
thank you
Dec 22, 2010 | Apple iPhone 3GS Black (16 GB)
I have connected my Toshiba laptop to a benq PB6210 beamer but cannot get presentation on the screen. I need help
1) Turn off the BenQ power, before connecting your VGA cable to the Toshiba laptop.
2) Once your laptop recognises the BenQ unit, you then need to tell your laptop to send an output signal to the BenQ - you do this by pressing your 'screen output' button (this is usually one of the function keys and you may need to hold the key for 1sec). The output function key can choose either single VGA output, or both laptop screen + VGA output.
"If this has helped you, please rate this solution"
Dec 01, 2009 | BenQ PB6100 Multimedia Projector
Dell E172FPb monitor black screen green flashing power button
We have a dis-assebly and repair guide posted on our web site at:
www.ccl-la.com/monitor_repair.htm
The problem is usually the driver transistors, our guide shows where they are and what to replace to get your monitor back running again.
I hope this helps, If so please rate my solution.
Buddy
Corporate Computer
www.ccl-la.com
Jul 30, 2009 | Dell E152FP 15" Flat Panel LCD Monitor
Benq FP92G Display couple of seconds then blank. LED still green.
budged electrolytic capacitor nearby high voltage transformer. 220microcarad/25Volts. apply fresh solder and re-connect lamps.
Jun 01, 2009 | BenQ FP92G+S (Black,Sylver) (Silver,...
Pt-52lcx65-k
Turn power on.
Press and hold the volume down button on the TV.
Press and hold the "split" button on the original remote.
Hold both for for over 5 seconds in power condition.
Counter will reset and lamp indicator will go out.
Dec 05, 2008 | Panasonic PT-52LCX65 44" HDTV
Black screen
How old is the computer? Make sure that the power light comes onto the monitor when you plug it in, should be orange and then turn green when video card syncs with it when PC is turned on. If you are getting black screen when PC is powered on:
1. Bad video card
2. Bad video cable
3. Bad monitor
1Solution: Try using a different monitor attached to this same PC and see if it works. If it does, then its the monitor, its cable, or its power supply. If it doesn't work, then its the video card or the video cable coming from monitor.
Nov 24, 2007 | Daewoo L700C 17" Flat Panel LCD Monitor
Blank scren, led stays green for only one second
Explicit enough to see that's this a a repair shop job. That also probably means a replacement- cost of which will not be much more than repair prices. One thing how ever- the power supply[which would appear to be the problem] is this built into the screen [that is does the screen have mains power direct? Or is it powered from an external 'Power Brick' If it is of the Power Brick type - then a new power supply is the answer - get on of the stabilized universal type with a fistful of connectors and a voltage selector switch.
May 24, 2007 | BenQ FP737S-D 17" LCD Monitor
Screen turns black
problem with the inverter chek it
Mar 18, 2007 | Daewoo L700C 17" Flat Panel LCD Monitor
BenQ FP71G 17" LCD Monitor Logo
215 people viewed this question
Top BenQ Computers & Internet Experts
JP Services
JP Services
Tony
Tommmix
Level 1 Expert
Are you a BenQ Computer and Internet Expert? Answer questions, earn points and help others
