Question about GE JASHO97985 Mouse
Wireless logitech mouse does not work
How do I open the mouse to change the battery.
PICKWORTH
    Genius:
  • GE Master
  • 1,689 Answers
Going from memory, I think you have to remove the small rubber pads on the underside. On some types, you would also have to remove the model label on the underside. This should expose the screws to take it apart.
The cordless mouse uses Lithium chargeable batteries. Don't put standard type non chargeable batteries inside.
You may find the cost of the proper batteries to come close to the replacement value of the mouse.
Jerry G.
Posted on Apr 15, 2008
Clicking issues on logitech wireless mouse
  • 1 Use the mouse on the same side of the computer where the Logitech USB transmitter is attached so there is a clear signal between the transmitter and the mouse.
  • 2 Check the USB transmitter that comes with the Logitech mouse to be sure it is correctly plugged into the computer. The red LED should be illuminated on the transmitter if it is connected properly. If not, the signal cannot reach the wireless mouse.
  • 3 Turn the mouse upside down to check the on/off switch. Be sure it is switched on.
  • 4 Check the battery compartment by sliding the top housing off the mouse to confirm the rechargeable batteries are installed correctly.
  • 5 Charge the batteries if the mouse LED does not illuminate. The charger cord plugs into the front end of the mouse and the other end connects to a free USB port on the computer.
  • 6 Clean the desk surface or other flat area if the mouse is not tracking. The problem could be dirt or grease interfering with the tracking ability of the device.
  • 7 Open the Logitech software called SetPoint, which manages the mouse, to troubleshoot button functions. Open the program by double-clicking SetPoint from the list of software on the computer, then click "Mouse Settings." Click the "My Mouse" tab and check (or uncheck) all the task boxes that are desired for operating different mouse functions, then click "Apply" and "OK."
  • Mar 17, 2012 | Logitech Cordless Mouse
    How do you open the wireless mouse for the MK320 so I can change the battery??
    To change the batteries in your Logitech MK320 desktop keyboard and wireless mouse, simply turn the mouse over. Move the on/off switch to the off position. Press the battery button and slide off the cover. Insert the batteries negative side first. Replace cover. Turn mouse on.
    For a detailed visual diagram, click here:Logitech MK320 Suppport
    Apr 04, 2011 | Computers & Internet
    How do you change the battery in the Mouse
    model no. all the wireless mouses have battery partition at downside. check it
    Mar 08, 2011 | Logitech Cordless Mouse
    How do I change the battery in a logitech wireless battery. I can't seem to figure out how to open it to even see what kind of battery is needed.
    For changing the batteries of logitech wireless.I guess a video tutorial will help you out rather than written instructions. Watch it to lean how to replace battery of the logitech cordless mouse ( Logitech MX 1000 Model). If you are having a different model please specify the details of your model.
    Mar 02, 2011 | Logitech Cordless Mouse
    Logitech mouse frozen up we changed batterys in
    If the mouse is freezing up though the batteries are fully charged, here's what you need to do:
    1. Try to use different batteries just to make sure that it's not a power issue.
    2. Connect the wireless USB dongle into different USB ports of the computer.
    3. Try to connect the USB dongle in different computer and try to use the mouse (to make sure that it's not a computer issue).
    4. Make sure that there's no cordless phone, cell phone and other wireless devices that might interfere the wireless signal.
    The Logitech wireless mouse is running on 2.4MHz frequency, same frequency as the other wireless devices. Any wireless device might cause the mouse to freeze.
    If same problem occur, then it's a hardware problem. Contact Logitech and RMA the mouse.
    Thank you and good luck!
    Apr 18, 2010 | Logitech Cordless Mouse
    I have a Logitech wireless mouse and it is not working with my laptop after about 6 months... the batteries have been changed
    After replacing the new battery with new one have you press connect button from the mouse side and the receiver side also. It is necessary to sync with the sensor the after replacing the battery
    Hope this helps. Please rate my response.
    Thanks.
    Have a good day.
    Mar 02, 2010 | Logitech Cordless Mouse
    Wireless EX110 Logitech mouse not connecting.
    Try the mouse on a different computer. If it can't work on there then you may have a defective mouse. Contact logitech about warranty info.
    Feb 01, 2010 | Logitech EX110 Mouse
    My battery is down wireless mouse. Does it also
    Battery compartment on the bottom of the mouse and beneath the keyboard.
    Dec 17, 2009 | Logitech Wireless Access Duo Optical...
    My Logitech LX5 wireless optical mouse has never worked properly
    hi im josh in cebu phils.may i help you? Friend try my gathered solutions. This problem has a simple solution—replace your batteries! Low batteries in a wireless device will cause all sorts of problems. In a mouse, this typically means that the cursor slows down, jerks around, or seems to hit an invisible wall. Fresh batteries should fix things right up.
    If new batteries don't fix the problem, you have some sort of wireless interference. Try moving the wireless receiver to a new position—preferably away from other wireless devices (wireless network adapters/base stations, cordless phones, baby monitors, and the like). If interference continues, see if you can change transmitting/receiving channels on one of the devices, or consider turning off the interfering device while you're computing. Good luck friend hope i helped you.
    Mar 04, 2009 | Logitech LX5 Cordless Optical Mouse
    Went onto laptop today and mouse is working - don't know why !
    Sep 10, 2008 | Logitech Cordless Mouse
    GE JASHO97985 Mouse Logo
    823 people viewed this question
    Top GE Computers & Internet Experts
    micky dee
    mukhtar21 shaikh
    mukhtar21 shaikh
    Ricky Ostrom
    Ricky Ostrom
    Are you a GE Computer and Internet Expert? Answer questions, earn points and help others
