I have Windows Vista and had my Lexmart all in oneworking with it. When I tried to put the scanner part in my computer says my printer spooler isn't working. I've tried to restart the printer spooler but an error box comes up. I can't get it started now.
  • 176 Answers
Maybe there is a problem in the scanner driver they use the same spooler. Try to uninstall the printer and scanner driver. Re install first the scanner before the printer
Posted on Apr 15, 2008
I have installed the lexmarkx1100 printer and the computer tells me it was succesful, but wheb I go to use it a message says that the local print spooler is not running. What do I do I tried to instal
Rebooting the PC will restart the Print Spooler service, if this isn't an option go to:
Start>Control Panel>Administrative Tools>Services find Print Spooler in the list and right click and select Stop then right clikc and select Start
Feb 08, 2012 | Lexmark All-in-One Printer, Scanner &...
I have this problem on my Canon MP210 Scanner that doesn't work! I even re-installed the driver, but nothing worked but the copier works. That mean that the hardware works correctly.
First try a different data cable and a different port. If you use a USB hub or print server, try a direct connection. Check that a known working device can connect to the computer. Check the device manager and power saving settings. What message do you see in the Devices and Printers window (Printers and Faxes for Win XP) for the MP210? What error messages do you for printing and scanning?
For Windows 7, Start > Control Panel > Hardware and Sound > Device Manager. Look for a triangle with a yellow exclamation point or a red x at the bottom of the list at Universal Serial Bus Controllers. You can try updating the drivers for the USB controller or uninstalling them and then rebooting the machine. (The computer should find and install new drivers automatically. However, you should also check in Windows Update for them (check for new updates - optional and important).) With some computers this could be the result of static at the USB ports. Disconnect all of the external devices and the power cord (computer and the outlet). For a laptop, also remove the battery. Then press and hold the power button for 30 seconds. Then put the battery back in (if applicable) and reconnect all of your cables.
For the power savings settings, again for Windows 7, right click on the desktop (anywhere there are no icons or running programs). Select Personalize. Then click on Screen Saver then choose Change Plan Settings. Next click on Change Plan Settings (for the active plan). Then click on Advanced Plan Settings. Scroll down to USB selective suspend.
Did you install the Canon driver, full software or the OS driver? Can you print any documents? (Sometimes the scanner will not respond but the printer still works.) If you have documents in the print spooler, you may need to stop and restart the spooler. (One way to do this is to launch the Command Prompt window (run as administrator for Vista or Windows 7). Start > All Programs > Accessories > right click on Command Prompt and choose Run As Administrator. Type "net stop spooler" without the quotes followed by enter. On the next line, type "net start spooler" again without the quotes and press enter. Now restart the computer.
If the printer works, but the scan buttons do not. If you connected the USB cable before installing the Canon driver, you have a generic driver that may not run the scanner. Uninstall the driver, unplug the data cable and then reboot the computer. Then install the full featured software (if available) from Canon . Next try to scan from the computer. You need to set up the full software with destinations for the scanner buttons and the monitoring program must be running. (If you use the basic driver, the scan buttons will not work. In Windows XP, Vista or 7, you can acquire scans with Paint. File > Import from Camera or Scanner > New Scan. Vista comes with Photo Gallery that can also do this (it can be downloaded for XP and Win7). Vista and Windows 7 also include Windows Fax and Scan to acquire scans.
If the unit still fails to work at the current computer, try connecting it to another (with known working USB ports). If it still fails, then the USB port has failed in the all-in-one. This could be another static issue. With the printer on, unplug the cables (data and power from the printer, outlet and the computer). Press and hold the power button for 30 seconds to a minute. If this doesn't help, if the printer is under warranty ask Canon to repair it.
I hope this helps.
Cindy Wellls
Apr 24, 2011 | Computers & Internet
I am running vista ultimate 32-bit but i often received this error message:".....the local print spooler is not running...." when attempting to install a remote oki B4400 printer. Why is that?
Print spooler is printer service if this service is not running, it might not allow you to add or see any printer drivers
Try enabling print spooler service. Follow the instructions
Click on Start->Search->type "services.msc" hit enter. Service windows will open up, on the right side pane search for "Print Spooler"
-> double click to open service and select start type as "Automatic"
click on apply and click on "Start" botton to start the service.
Now try to install the drivers
Snapshot for more information.
Hope this helps
May 21, 2010 | Computers & Internet
My lexmart want work with my vista
go to and in the search box type in "6170" and click on the search button.
It will bring you to the page for you lexmark x6170 printer. scroll down and in the drivers and downloads section click on windows vista.
Then on the next page in the recommended downloads area click on the tab that says windows vista. There will be a name of the file you have to download. Click on the download button and let the file download.
Once the download is done, double click on the filename which should be cjrx6100en.exe. Let it run and it should install the software and have your computer recognize the printer.
Hope this helps.
Feb 10, 2009 | Lexmark C533DN InkJet Printer
Installing lexmart x4270 all in one printer to my new windows vis
Go here, and type Lexmark X4270 into the model box.
Then download the Vista driver.
Chris (ziraffa)
Jan 11, 2009 | Lexmark X4270 All-In-One InkJet Printer
Cannot connect my printer to my computer
This came right off of the lexmart site
Attention Windows Vista Users: Attention Windows Vista Users
If you have installed your printer on your PC using an original Lexmark Driver CD that came with your product and you are experiencing problems when printing, you may have installed the Windows XP driver.
Follow these steps to resolve:
· Disconnect your USB cable from your printer.
· Uninstall all Lexmark printer drivers on your PC.
· Download the correct Vista driver for your model.
· Install the driver on your PC.
Important - Do not reconnect the USB cable until the install software prompts the question of how the printer is connected.
Nov 16, 2008 | Lexmark X3470 All-In-One InkJet Printer
My computer to except Lexmart X4270 Software Plus It says spooler not working
you may have a bad disk--go to look for drivers and downloads then-- driver finder. you should be able to get the right download.
Oct 03, 2008 | Lexmark X4270 All-In-One InkJet Printer
Error 1068 on vista print spooler stopped
Please follow the below given steps to remove the dependencies.
1.Click start icon.
2.Click on All Programs.
3.Click on Accessories.
4.Click Run.
5.Type cmd and hit enter.
To remove this dependency all you have to do is open the command prompt and type in the following command:
Please type Sc*config*spooler*depend=*rpcss (put spaces where the (*)’s are.
When you hit enter you will get this message:
Sc config spooler depend= rpcss [SC] ChangeServiceConfig SUCCESS
Now please restart the computer and try to install the printer.
Aug 08, 2008 | Lexmark X4270 All-In-One InkJet Printer
80 people viewed this question
