Question about Aastra Telecom Meridian 6320 Corded Phone (M6320)
M6320, call alerts
My telephone lights up as it is ringing, yet makes no sound. I tried changing the alert volume, but it still doesn't work. How do I fix it?
My iPhone SE stopped making sound when ringing, it only vibrates. I have checked all settings/side button, all correct.All other alerts-text, etc.-still work with sound alerts. Anyone know how to fix?
One thing to check is the ringer volume - by default you can change the ringer volume using the volume controls on the side of the phone even when the phone is locked - this often means that it can get pressed in your pocket to zero volume, which is very annoying. Try pressing the volume up button from the home screen while not playing any music and see if it goes up. You can set the volume in the settings and even tell the buttons to only change music volume, which is what I do.
Jan 24, 2017 | Apple iPhone Cell Phones
How do i get sound to work for recieving text messages
Depends on the phone, but on iPhone there is a very small lever on the top left edge above the volume UP button.
You should also check Settings - Sounds - Text Messages
COMMENT below my name with make and model.
Aug 02, 2016 | Cell Phones
No sound coming form the phone at all, it is only vibrating, i have changed the profile on it to outdoor and made sure the phone is not on vibrate in any way. You help would be much obliged. Jordan
Select the profile you want to use,then select 'customise' select 'ok' at the bottom of your screen, select volume on the new display page to verify your volume level, select back to previous page, then select 'alert type', now you can make selection of how you want your phone to alert you of an incomming call. i.e. Ring; Vibration Only;Vibration and Ring; or Vibration then Ring.
Sep 13, 2011 | Cell Phones
My samsung monte slide makes a beep when i send a text, how do i stop this from happening
Choose settings for profiles info.png 1 Find "Profiles"
  • Press Menu.
  • Scroll to Settings and press the Navigation key.
  • Scroll to Profiles and press the Navigation key.
2 Select profile
  • Highlight the required profile and press Options.
  • Scroll to Edit and press the Navigation key.
3 info.png Select settings for incoming calls
  • Highlight one of the following options:
  • Call alert type, go to 3a.
  • Call ringtone, go to 3b.
  • Message alert type, go to 3c.
  • Message alert tone, go to 3d.
  • Keypad tone, go to 3e.
  • Volume, go to 3f.
  • Press the Navigation key.
3a "Call alert type"
  • Highlight the required incoming call alert and press the Navigation key.
3b "Call ringtone"
  • Highlight one of the following folders:
  • Default melodies
  • Sounds
  • Music
  • If you select Default melodies:
  • Highlight the required ring tone and press the Navigation key.
  • If you select Sounds or Music:
  • If required, highlight a folder and press the Navigation key.
  • Highlight the required ring tone and press Select.
3c "Message alert type"
  • Highlight the required message alert and press the Navigation key.
3d "Message alert tone"
  • Highlight the required message tone and press the Navigation key.
3e "Keypad tone"
  • Highlight Mute or the required key sound and press the Navigation key.
3f "Volume"
  • Highlight the required category and press Navigation key right or Navigation key left to select the required volume.
  • Press the Navigation key to save.
4 Exit
  • Press Disconnect to return to stand-by mode.
Jun 25, 2011 | Cell Phones
How do I adjust the volume,too LOUD?
Hello jinniq51,
i have some tips on how to do it hope it helps :D
Settings
In this menu, you can adjust various phone
settings. To reset some menu settings to their
default values, select Restore factory set.
Tone settings
Select Menu > Settings > Tone settings and from the available
options:
Ringing tone-To set the tone for incoming calls
Ringing volume-To set the volume level for the ringing and
message alert tones. If you set Ringing volume to be level 2 or
above, your phone rings with the ringing volume ascending
from level 1 to the level you have set when there is an
incoming call.
Vibrating alert-To set the phone to vibrate when you receive a
call or a text message
Message alert tone-To set the tone to sound when you receive
a text message
Warning tones-To set the phone to sound tones, for example,
when the battery is running out of power
Apr 15, 2011 | Nokia 1600 Cellular Phone
Not working ringer
menu
2 settings
3 tones
incoming call alert (set to ringing)
ringing tone ( pick your ring tone)
ringing volume (set to level 5 loudest)
vibrating alert (on)
message alert tone (pick tone)
instant message alert tone (standard)
keypad tones (on)
warning tones (on) this is for the alarm and ringtone this is where your problem is so double check these settings ok
alert for (all calls)
Jul 03, 2009 | Nokia 3100
Change SMS Alert on Motorola W375
It took me a while to find this.
Settings / Ring Style / scroll down to Detail & press the left soft-key to CHANGE. In this menu you can adjust default ring volume, and select different sounds for calls, texts, voicemail, alarms and also adjust key volume.
If you are clever enough to make your own mp3 ringtones (they need to be tiny files to fit on this phone's tiny 500kb memory) you can even select these as your call or text alert.
Apr 18, 2008 | Motorola Mobility W375 Cellular Phone
Ringer doesnt work Nokia 3120
hi follow these instructions
1 menu
2 settings
3 tones
keypad tones (on)
once you have done them settings try your phone and see if it works if not then follow these instructions
1. menu
2 settings
3. profiles
4 general then personalise
the set like this
Incoming call alert (ringing)
ringing tone (choose ringtone)
ringing volume (level 5 )
message alert tone (choose tone)
Keypad tones (on)
warning tones (on)
once you have changed the last setting press back then select activate your phone should be now be working if not let me know ok
Mar 21, 2008 | Nokia 3100
Message alert volume
It seems to be a problem on all these Sony Ericsson phones.
You can make it louder by going to setting/profiles and select an outdoor profile.
Also choose a sound that is very audible, you'll have to download one. I recommend: Zedge, http://www.zedge.net/
and a bonus, http://www.ownskin.com/
Dec 19, 2007 | Sony Ericsson K800i Cellular Phone
Aastra Telecom Meridian 6320 Corded Phone (M6320) Logo
Top Aastra Telecom Lands Phones Experts
Illimar Saatvali
Illimar Saatvali
Jose Ma DM.
Jose Ma DM.
Michel Laprise Sr
Are you an Aastra Telecom Lands Phone Expert? Answer questions, earn points and help others
