Question about RCA D61W20 61" Rear Projection Television
RCA Projection screen tv, model #D61W20B
I can see all menu features and run through all of them, picture seems fine with all menu items. With every thing else though I have no picture just a light blueish grey screen, the sound is fine, I have tried all inputs front and back including s-video cable. Sound is all I get
    Genius:
  • 2,920 Answers
Your cameras may have gone bad
Posted on Sep 03, 2008
I have an RCA projection TV, model D52W19B. The TV powers on ok, stays on, and audio is normal. I don't get a picture. If I press the menu button, the menu will appear on the screen normally.
my guess is you either have a satellite or cable box try unplugging the system cable or satellite and set for 5 minutes and then plug them back and and restart the unit up and see if it comes back the gemstar module would some times lock up causing this problem . and please let me know if that get's you working or if there is more trouble shooting to be done
Nov 03, 2014 | RCA Televison & Video
No picture but have sound
no video output seems the video output part is faulty ask for tech to have a look
Jul 11, 2013 | RCA P61939 61" Rear Projection Television
Screen only shows red and green
i have 61" rca model # D61W20B
the pic was working fine then all of a sudden
got blurry
Feb 23, 2011 | RCA D52W20 52" Rear Projection HDTV-Ready...
Tv out of foucs
These procedures are from the owners manual, go into menu and then picture quality and then: Convergence The Convergence feature lets you adjust the TV’s three tubes. When the TV tubes’ images are precisely aligned, they create the color images you see on the screen. Over time, the picture can drift out of alignment (this is normal). If your picture seems fuzzy or has a yellow tint, using Convergence could correct this misalignment. Only one convergence is needed for all inputs, regardless of the signal format. Note: Make sure the TV has been on for at least 30 minutes (TV needs to warm up for best results) before starting Auto Converge or Red/Blue Centering. When you select the Convergence feature, a submenu appears with three options: Auto Converge Automatically aligns the projection lenses to self-correct color images. You’ll see flashing squares of color dance across the screen (this is normal). Note: After performing auto convergence, use the Blue Centering and Red Centering menus to fine tune convergence in the center of the screen, if necessary. Blue Centering Aligns the blue and green images to fine-tune the picture. Red Centering Aligns the red and green images to fine-tune the picture. Note: The ability to change channels is disabled when adjusting the convergence options. The TV must be tuned to a usable signal to converge the picture.
Apr 23, 2010 | RCA HD52W58 52" TV
TV does not turn on model RCA D61W20B
first check all fuses they are small, square ,RED and can be confused with the square small caps. the sizzling is prob. the flyback transformer (what the h.v. wires from each tube plugs into) if you are only getting green then tv shuts down or is dead now. i would replace any bad fuses and replace the flyback transformer. also make sure you do a very good visual inspection of all the boards.
Jun 21, 2009 | RCA D61W20 61" Rear Projection Television
FL231 Fuse Post
the fl231 problem is unique to the rca itc222 chasis the model mm52100 is not this chasis. wackey? describe the picture. You may have a solder problem or a compnent overheating.
Jan 14, 2009 | RCA MM52110 52" Rear Projection HDTV-Ready...
Rca 52 in rear projection... start up menu always on
The setup menu will repeat until it is completed and/or something is hooked up.
On my TV it kept reoccurring until I connected up the wire from the roof antenna, even though I had cable already installed.
Check your manual for setup instructions or if you do not have one, Google the make, model number and "owners manual" to see one online.
Hope this helps. :)
Mar 31, 2008 | Televison & Video
Projects picture bigger than screen..
This must be a duplicate, and since I'm not sure which one you'll be checking back with: Go into the menu and select picture settings and then advanced picture settings. I'm not sure on that model that you can manually change the aspect ratio from zoom to 16:9 or 4:3 ect... But select Auto Format and the TV will pre-select the correct format for viewing..... Any questions just let me know. Bill
Jun 11, 2007 | RCA D52W20 52" Rear Projection HDTV-Ready...
Menu (SCREEN) #4 Adjusting projection is gone
you have a convergence problem and this can only be serviced by a tech with the know how to service the rca projections sets as there are many alignments in this set and some are manual driven but mosrt are on screen driven. You need the know how to get into the service mode. Sorry my friend but my recomendations would be to send this set out for service.
Jun 08, 2006 | RCA P56812BL 56" Rear Projection...
RCA D61W20 61" Rear Projection Television Logo
389 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
