Sandrew can give me the codes in inserting an audio in java programming
    Legend:
    An expert who has written 200 answers of more than 400 characters.
  • 359 Answers
Posted on Apr 21, 2008
Source code for Hough Circle Detection on BufferedImage in java
That sounds a lot like homework so I am not surprised that you didn't get a response.
Did you pass the course?
Jul 30, 2012 | Sun Java Programming Language (cdj-275)
How to pprogram a java language
download java compiler from http://www.oracle.com/technetwork/java/javase/downloads/index.html
Go where you install your java, default Path is "C:\Program Files\Java"
in Java Folder open folder jdk then open bin copy its directory located at the address bar then
Right Click My Comuter > left click Properties > Advance > Environment Variables > on System Variables find Path then click it then click Edit
insert a semicolon " ; " on the end of the textbox (if already have don't add semicolon) then paste the directory you copy...
you can now create your Java Code....
to Compile and Run it...
open command promt ( to open click start > run > type cmd )
go to directory where you save your java code..
(ex. if your Directory is "D:\Java Folder" then type "cd.." press Enter repeat "cd.." until "C:\>" is remaining then type "D:" press enter then type "cd Java Folder" then press Enter type "javac (name of your javacode).java " Press Enter (if there is an error correct your java code) if no type "java (name of your javacode)" there you can run your Java Code
Aug 04, 2011 | Microsoft Windows XP Professional for PC
Why showing fatal errors during uninstalling java
go into Control Panel\Add/Remove Programs and scroll down to remove Java from my system. I click remove and it comes up with the window "Add or Remove Programs: Are you sure you want to remove Java(TM) 6 Update 13 from your computer".
I click yes and it says "Preparing to remove"
then configuring java.. and then come up with the window:"Fatal Error During Installation"
I've tried enabling logging.. it didn't work.. so that's all the info I can give, I have two HD's mounted.. if that helps.. I don't know. I tried using the install again.. it didn't work believe it or not s9.gif. Anyway please help
Mar 13, 2010 | ArcMedia JavaScript Source Code 3000 Pro...
Fatal error during java installation uninstall
go into Control PanelAdd/Remove Programs and scroll down to remove Java from my system. I click remove and it comes up with the window "Add or Remove Programs: Are you sure you want to remove Java(TM) 6 Update 13 from your computer".
Jul 01, 2009 | ArcMedia JavaScript Source Code 3000 Pro...
Source code in java that display bio data
program that display first name and second name
Jun 18, 2009 | Sun Java Programming Language (cdj-275)
Can anyone tell how run java program in cmd prompt???
You need to type:
If it's a program.class
java program
or of it's a program.jar
java -jar program.jar
regards
Apr 03, 2009 | Sun Java Programming Language (cdj-275)
Mysql database tables+find new inserted or update row using java
After you add the new record into table A, you can use the LAST_INSERT_ID() function to retrieve the value of the auto_increment PK field. Look here for more information on this function: http://dev.mysql.com/doc/refman/5.0/en/information-functions.html
Mar 02, 2009 | Sun Java Programming Language (cdj-275)
Error to compile java program
The main cause of this error is you havent set the environment variables correctly, you can do it as follows
Right click on "My Computers" select properties the click "Environment variables" then under "User variables for pcname"
select new and add the following paths
1)var name:path
var value:C:\Java\jdk1.5\bin
2)var name:classpath
var value:C:\YourJavaCodeDirName
click ok and its done
Feb 28, 2009 | Sun Java Programming Language (cdj-275)
What is the difference between Java editor and Java software?
java editor is a text editor which probably understands java language synthax and can automatically call java to compile your code.
Java software is a program written in Java programming language which is interpreted/executed by JVM(JAva virtual machine) on a target computer.
Your question is a rough equivalent to : What is a difference between typewriter and a recipe book written in English language
Jan 21, 2009 | Microsoft Windows Vista Ultimate Edition
Java programming
I ll give you some reference book names for core java they are the best,
1)Head First Java by Kathy Sierra & Bert Bates
2)SCJP 5.0 by Kathy Sierra & Bert Bates
the first one is the best for the beginners read it before you go for any other
good luck
Aug 14, 2008 | Sun Java Programming Language (cdj-275)
Computers & Internet Logo
47 people viewed this question
David Payne
David Payne
