Question about Motorola Mobility RAZR V3i Cellular Phone
Bluetooth I have V3i model in that I am facing the slow bluetooth problem i.e. receiving & sending data are quite slow. Please solve my problem
  • Anonymous Jun 09, 2008
    just how do i send and receive pictures from my razr v3i?
  • 70 Answers
It depends on the cell phone to u sending or recieving...see if u r sending to an nokia phone..the nokia phone is slow in recieving...but ur phone cant force it take data fastly...so it happens...as i've seen v3i to v3i its fast...even stil its an prob restart once n use...
ne other prob's do tell me..N plz do rate me
cya
Posted on Apr 15, 2008
How to on or off bluetooth on w508i. even how to change setting of bluetooth
Hi, To set up Bluetooth on your phone
1. Go to Menu, select Connect or Connections or Connectivity:
Note! If the above steps do not work, please consult the user manual.
2. Bluetooth - Select On to enable Bluetooth.
3. My telephone's visibility - Select Shown to all if you want your device to be found by other Bluetooth devices. If you
select Hidden, your device cannot be found by other devices.
4. My Bluetooth name - Define a name for your device. After you have activated your Bluetooth service and changed
My phone's visibility to Shown to all, your phone and this name can be seen by other Bluetooth device users.
Sending data via Bluetooth
If your phone supports the Bluetooth 1.1 specification or earlier, you can only have one Bluetooth connection running
on your phone at any one time.
1. Select or open the file you wish to send. For example, to send a photo to another device, open the Gallery
application.
2. Select the file you wish to send, then select Options > Send > via Bluetooth.
3. The phone starts to search for devices within range.
Devices using Bluetooth technology that are within range will appear on the display. You should see a device icon,
the device's name, the device type, or a short name. (A paired device is one where a Bluetooth connection already
exists between your phone and the other device.)
• To interrupt the search, press Stop. The device list freezes and you can start to form a connection to one of the
devices already found.
If you have searched for devices earlier, a list of the devices that were found previously is shown first. To start a new
search, select More devices. If you switch off the phone, the list of devices is cleared and the device search needs to
be started again before sending data.
4. Scroll to the device you want to connect with and press Select. The item you are sending is copied to Outbox and
the note Connecting is shown.
5. Pairing (if this is not required by the other device, proceed to step 6.)
• If the other device requires pairing before data can be transmitted, a tone sounds and you are asked to enter a
passcode. • Create your own passcode (1-16 characters long, numeric) and agree with the owner of the other device
to use the same code. This passcode is used only once and you do not have to memorise it. • After pairing, the
device is saved to the Paired devices view.
6. When the connection has been successfully established, the note Sending data is shown. Data received via
Bluetooth can be found in the Inbox folder in Messaging. Tip: Pairing is a means of authentication. The users of the
devices using Bluetooth technology should agree together what the passcode is, and use the same passcode for
both devices in order to pair them. Devices that do not have a user interface have a preset passcode.
Checking the status of the Bluetooth connection
• When the Bluetooth icon is shown in standby mode, Bluetooth is active.
• When the Bluetooth icon is blinking, your phone is trying to connect to the other device. • When the Bluetooth icon is
shown continuously, the Bluetooth connection is active.
Receiving data via Bluetooth
When you receive data via Bluetooth, a message alert tone is played and you are asked if you want to accept the
message. If you accept, the item is placed in the Inbox folder in Messaging.
Disconnecting Bluetooth
A Bluetooth connection is disconnected automatically after sending or receiving data.
Hope it helps .
Fill free to pass your comment.
Thanks for using fixya...
Jan 08, 2011 | Sony Ericsson W508i Cell Phone
I am having problems getting pictures send to my Blackberry 9000 via Bluetooth from Nokia and other phone devices. Even though the device is paired with my Blackberry sending pictures fails (with error...
hey hi...may b i can solve ur problm...
1st open d media application,then lighlight the picture folder by putting the cursor on it.next click on the menu of the picture folder.....there u will find a option "receive through bluetooth".click on that.ucan receive ur files nw.
(Note:-u mst 1st swith on ur bluetooth and must have paired wid the device 4rm which u wish to receive data)
only after clicking on the "receive through bluetooth" the data must b send 2 the blackberry.....
hope u got it....
u can contect me at zeebonbarua@gmail.com 4 quarries..
gud luck
Aug 03, 2010 | RIM BlackBerry Bold 9000 Smartphone
Blackberry curve 8520 unable to receive files transfered from other Mobile device through bluetooth. But able to transfer data to other mobiles through blue tooth
My Blackberry curve 8520 can send data via bluetooth but it unable to receive data from another bluetooth enabled device. please send me solution.
Jun 17, 2010 | RIM Holster For BlackBerry Curve 8520
Bluetooth wont work i cant receive data from other mobiles
soln 1 have u checked tryin to transfer data of pretty small sizes like an image? soln 2 1. On the receiving device, go to media, select what you'll be receiving (photos, ringtone, etc), press menu, then select receive using bluetooth.
2. On the sending device, send using bluetooth...
MUST BE DONE IN THAT ORDER!
soln3 Go to Applications, then choose Files. Then hit the menu button and scroll to Receive Using Bluetooth. Then on your computer choose the file you want to send and tell the computer to Send To Bluetooth device. It works! Halleluiah!
Jun 15, 2010 | RIM Blackberry 8110 Cellular Phone
Bluetooth problem
Can you send data to through bluetooth to another devices/phones? If so please check your bluetooth settings, go to bluetooth - setting - visibility - on - ok- this will solve your problem, or if this isn't the problem, check your availability memory and the default memory reception destination (phone memory or memory card). good luck and please remember to rate me..
May 04, 2010 | Nokia N95 Cellular Phone
Blooth reciving problem
check your phone memory it might be full delete unwanted item from it then save your data in memory card and use memory card as storage device save less amount of data in phone memory...
Nov 24, 2009 | Samsung SGH-J600 Cellular Phone
Bluetooth problem
your bluetooth connectivity was set to "hidden to others". to be able to receive, you must turn it on and select the option "show to all".
It is advisable that you always turn your bluetooth off or hidden mode to prevent infection by mobile viruses due to bluetooth jacking.
hope I helped you solve your problem.
regards,
-engrkoiled-
Mar 31, 2009 | Nokia 3110 Cellular Phone
Connecting phone to pc
connecting you phone to your pc is quite easy to do.
all you have to have is:
pc with bluetooth capability( dongle)
celphone with bluetooth enabled
whenever your bluetooth dongle is attached to your pc, specially under windows XP, it is automatically configured to locate/find other bluetooth enabled devices under its radius.
when your phone is detected, you are asked to enter a pin to either receive data or send data to your pc.
having a bluetooth software will also lessen your frustration as bluetooth software have instructions or walkthroughs on how to do this.
cheers
Mar 23, 2008 | Cell Phones
Bluetooth failure
pleace select your bluetooth in your menu and you see bluetooth turn on for fuw minits or scoend set it for long time then start file copy
Jul 19, 2007 | Motorola Mobility RAZR V3i Cellular Phone
Motorola Mobility RAZR V3i Cellular Phone Logo
46 people viewed this question
Top Motorola Mobility Cell Phones Experts
Virgil Wolter
Level 1 Expert
vince
Rami Obeid
Level 1 Expert
Are you a Motorola Mobility Cell Phone Expert? Answer questions, earn points and help others
