I have recently obtained a Tedelex TE-8200 HD receiver for a Philips 36 PW 9525 100HZ Dolby 3D Real Flat Match Line TV. The picture when showing action such as sport jumps. I believe that the problem is called "judder". Is there a solution?
  • 813 Answers
I think ur in your tv has a york -problem so u need to go with a good tv technision he will rpair it
thnx using fixya
Posted on Apr 15, 2008
UNABLE TO POWER UP
Check for a bad fuse inside the receiver.
Jun 20, 2015 | Yamaha AVENTAGE RX-A1030 3D A/V Receiver -...
How do I get audio from tv to receiver?
There should be audio output's on your TV and cable box. There are usually multiple options on most newer model a/v equipment. If u check the manual look for the page showing you about the various connections on the back, you're lookin for anything to do with audio output, there are many different types optical, digital, and analog. Again depending on your specific equipment there's almost always at least one way you can connect them
Feb 15, 2015 | Pioneer HTP-071 5.1 3D Home Theater System...
How do I install my Philips BDP2100 Blu-ray player
Why do you want to install the blu ray player you Xbox one can play blu Rays I would bother connecting the blu ray player at all
Nov 22, 2014 | Philips BDP2100 Blu-ray Disc Player -...
How to unlock regional code of philips HTB3510 3d blueray player?
Check current region code
Open the Philips HOME Screen
Type on your remote: 8520
This will display all of the current settings for your player.
Example: Region_Code: DVD(2) BD(B)Change region code
Turn on player with no disk inserted
Press "Open/Close" on the remote control until the tray is open
Press 8689310 - 0 means all region
Press 8689311 - 1 means region 1,
Press 8689312 - 2 means region 2,
Press 8689313 - 3 means region 3,
Press 8689314 - 4 means region 4,
Press 8689315 - 5 means region 5,
Press 8689316 - 6 means region 6.
Now the front Buttons might not work!
Go to SETUP and click on RESET FACTORY SETTINGS
Wait until the player restarts and now you can play all DVD regions
Oct 08, 2014 | Philips HTB3510 5.1 3D Home Theater System...
How should I connect my denon avr 1906 to my 32" ES6300 Series 6 SMART 3D Full HD LED TV Model numberUE32ES6300U in order to get dolby digital from the tv's tuner please?
Use an optical cable.
Be aware though. Your TV has a DVB-T tuner. It picks up the Freeview standard definition (SD) channels, but not the Freeview HD ones. Dolby Digital sound only comes from the Freeview HD channels.
Your TV will pass Dolby Digital from any source connected to a HDMI port to the Optical Out. It will also pass DTS. But the internal Freeview DVB-T tuner doesn't generate Dolby Digital, just stereo and stereo with Dolby Surround encoding where you use ProLogic II for decoding.
Sep 08, 2014 | Denon AVR-1906 Receiver
How can enable 3d on philips led 40pfl8605h?
Do you have the PTA02 accessory for the TV? This is a USB 3D transmitter and comes with 2 pairs of Active 3D glasses. The screen of the 40PFL8605H is not a 3D TV by itself.
Once you have the accessory plugged in, you may need to wait for the software to be installed on your TV before you can watch 3D content. See the manual for the TV for more information: http://download.p4c.philips.com/files/4/40pfl8605h_12/40pfl8605h_12_dfu_eng.pdf . This is on page 73 of the PDF.
I hope this helps. If you have the 3D accessory plugged in, try turning off the TV and turning it back on if the software did not install properly. The final thing to check is the "codecs" for your 3D movies on the USB stick. Make sure that they are compatible with the TV.
Apr 19, 2013 | Philips Televison & Video
I con not get the surround sound to work. It only goes into stero mode with the same sound from all the speakers
The AVR-1911 is an A/V receiver with HDMI version 1.4a that can be connected to TVs and other devices that support 3D video such as Blu-ray disc players, game consoles, and set-top boxes. This receiver supports not only Dolby TrueHD, DTS-HD Master Audio and other HD Audio formats but also Dolby Pro Logic IIz for enhanced vertical and horizontal spatial performance at the front, the essence of 3D acoustics complementing the excitement of 3D video. The AVR-1911 comes with numerous other features such as 1080p up-conversion to give you a sharp, high-definition picture from DVD and other standard video sources, and a Glow-key remote control unit that is easy to use in the dark, to maximise your home theatre experience. Check if the RCA connector is properly connected.. Sometimes the problem is in the CD or DVD itself. Try to go to www.denon.com. ty
Jun 23, 2011 | Denon AVR-1911 Receiver
Shows no picture but has sound its a tedelex 42 inch
if you had no prior ideas about plazma tv . then call to some experienced person so that he can help you. oterwise take to the repair center .
Dec 07, 2009 | Philips 42HF7444T 42 in. Plasma TV
Trying to find a port for sound input on Philips DVI LCD TV.
If it is two-channel sound, the 'line' inputs should be color-coded as red (right) and white (left).
Feb 22, 2009 | Philips 23PF5320 23 in. HD-Ready LCD...
Televison & Video Logo
89 people viewed this question
Top Televison & Video Experts
