I have a hewart packard deskjet 932c printer. The orange light just blinks continuously and it will not print.
I have a scanner 2100Cbut have lost the disc to add it to my new vista laptop. can you help
Posted on May 11, 2008
    Sergeant:
    Champion:
  • 277 Answers
Removed the cartridge and clean the circuit surface with pencil eraser then try to install it again..
Posted on Apr 15, 2008
The Hp deskjet 932c went to the far left position and the light is flashing. That is supposed to mean its out of color ink but its not. I uninstalled the software and reinstalled. It will start to print a...
Follow each of these steps until the problem is resolved:
  • Print a printer self-test by holding the power button down with a pencil and opening and closing the top cover four times.
  • Check the nozzle self-test pattern in the self-test print out. If one or more of the solid rectangular areas are missing, an electrical contact problem may be present
  • Remove and then reinsert the print cartridge(s) into the printer.
  • Print the document.
  • Try printing again. If the problem continues, replace the print cartridges.
Aug 04, 2010 | HP DeskJet 932c InkJet Printer
Color cartridge runs out even though I'm only printing b&w typed scripts. Any way to shut it off? Only have use for color printing once in a blue moon Hewlett Packard HP DeskJet Printer #932C
Even though you print a b/w document... unless you say 'black cartridge only' in your printing preferences, all the colors get used.
Find 'black cartridge only' in your printing preferences, or 'print in greyscale' and then print your document. You must specify this for your printer to know that it must use the black only.
Jul 23, 2010 | HP DeskJet 932c InkJet Printer
Orange ink light blinks. printer will not print.
turn on/off, unplug, plug in, should reset configs.
go to applications folder for your computer, dbl click printer icon for make of printer. check settings. print 'test document and clean cartridge heads', this should ensure proper printing formats.
lastly, go to web site of printer model and check site for trouble shooting if this does not work above. HP has an awesome trouble shooting site
hope this helps and good luck
Apr 29, 2010 | HP DeskJet 932c InkJet Printer
We are in the middle of printing our Tax Return and an orange light keeps blinking on the top of the printer - and it has stopped printing.
Hi and thank you for using fixya:
On this specific printer model this light means that your paper has jammed, you need paper, or your ink is low. Please re-start your computer and printer and try again. If problem persists check ink levels on the printer settings (computer)
Good luck
Apr 13, 2010 | HP DeskJet 932c InkJet Printer
I put in a new black cartridge, but the blinking light (left most) continues to blick and I cannot print. Any suggestions? How do I reset the printer to aknowledge the cartridge?
Try to reset the entire PC and printer then turn it on again and try to delete the files in the printer memory then restart to clean all the files stored in the printer. Try to print it now.
Apr 06, 2010 | HP DeskJet 932c InkJet Printer
Blinking orange light on hp 932c
Solution
  1. Check to ensure that the top access door is firmly closed.
  2. If the light continues to blink, open the top access door. When the top access door is opened, the print cradle moves so the yellow arrow on top of the cradle points to a drawing of a cartridge. Each drawing describes a symptom.
Solution two:
  1. Turn the printer off. Unplug the power cord from the back of the printer. Unplug the power cord from the wall outlet.
  2. Wait 30 seconds. Plug in the power cord to the wall outlet. Plug in the power cord to the back of the printer.
  3. Turn the printer on.
Solution three:
The print cartridge carriage is stuck.
Solution
1. Open the top access door on the printer.
2. Remove the ink cartridges.
3. Turn the printer off, then on again.
4. Replace the ink cartridges.
5. Close the top access door.
Solution Four:
Issue
The 2-Sided Printing Module is installed incorrectly, not at all, or the back access door is unlocked or open.
Solution
1. Turn the knob on the rear access door of the printer counter-clockwise, and remove the door.
2. Insert the module into the back of the printer.
3. If the lights remain on, remove the 2-Sided Printing Module by pressing in the buttons on the ends of the unit.
4. Re-install the 2-Sided Printing Module by pushing the unit back into the printer without pressing the buttons, until it snaps firmly into place.
Jun 17, 2009 | HP DeskJet 932c InkJet Printer
Hp deskjet 932c does not print cartridge light keeps on blinking
First suggestion is to install a new cartridge. The #45 black and #78 color have a small circuit board that registers with the printer. That circuit board may not be doing its job.
Mar 22, 2009 | HP DeskJet 932c InkJet Printer
Document is not printing
Press the feed button. If that doesn't work, turn the printer off, wait a few seconds, and turn it back on again.
Feb 03, 2009 | HP DeskJet 932c InkJet Printer
932C Constant blinking ink light
problem here is the orange light blinking- has ink in the cartridge- stopped printing in the middle of the page
Jul 19, 2008 | HP DeskJet 932c InkJet Printer
55 people viewed this question
jasbo
jasbo
