To boot window xp from usb external hard drive
How to boot from usb external hard disk window xp
  • vas001003 Mar 03, 2009
    i cant boot the damn thing for some reason
  • Anonymous Mar 24, 2014
    windows xp
  • 1,447 Answers
Use the guide in this link
or this forum
pls dnt 4get to rate solution, thanks!!
Posted on Apr 15, 2008
Windows will not start with a Toshiba external hard drive plugged into USB
Computer starts normally in windows with a windows that is installed on a hard disk on that copmuter. In other words - windows is installed on an internal hard disk of a computer A. If you get it out and put in a computer B it wont work.
To have the things work:
1. First should set in BIOS boot up options first boot device CD/DVD, second OTHER/USB/EXTERNAL, third HDD
2. Should boot up from a CD and install windows on an external hard disk (in your case your 3TB Toshiba external HD)
3. Set in BIOS boot up options first boot device OTHER/USB/EXTERNAL, second internal hard disk e.g. HDD0, HDD1
Apr 04, 2014 | Toshiba Canvio Computers & Internet
Cant detect hdd
Hi Martin...
The problem is being caused by the Logical Disk Manager
Administrative service and possibly the logical Disk Manager service
not being started or the services might be disabled. to solve the
problem, click on the "Start" menu, click the "Run" command, and then type
in the box: services.msc , scroll down until you see both the above services.
right click on each of the services about and select properties, on the
general tab, change the startup type to "automatic" and click the start
button under the service status. do this for both of the services, and
that should will fix your problem."
For Windows 2000 and XP:
Right click on My Computer.
Choose Manage (This will open the Computer Management window).
Go to the Storage category and select Disk Management
Right click the new drive (usually listed as Hard Disk 1) and "initialize"
You now have the option to partition and format the drive.
The default settings of Primary Partition and NTFS- Quick Format are recommended for most users.
External hard drive can not be recognized, are more common on computer
failures, what's the reason caused this failure?
1, Setting the CMOS parameters
If you never used the USB external device, there may occur the case:
The system can not detect USB hard drive even if the driver is properly
installed, which was mainly due to the motherboard CMOS default port is closed, if not set to
open state, it naturally Windows can not detect the external hard drive. In order to solve this
problem, we can re-boot into the CMOS settings, and set "Assign IRQ For USB" to "Enable" in
"PNP / PCI CONFIGURATION" column, now the system can be assigned to the USB port available
interrupt address.
2, Power shortage
As the USB drive need to consume some power when it at work, if directly through the USB interface
to take power, the power supply may be not enough. Thus, almost all of the external hard drive
comes with a separate external power supply or a PS2 keyboard to take power transfer interface,
at this time you should connect external power supply or through the transfer cable ps2 connected
to keyboard to ensure that it have provided adequate power to the external hard disk,
recommended that you should ensure the external hard drive have adequate power supply when you
use it, otherwise, the external hard disk is likely to be damaged due to insufficient power
3, USB extension cable fault
USB interface type does not match the external hard disk interface ,this case caused it can not
be used. For example the standard USB interface of the computer configuration is 1.1, while the
external hard drives purchased are USB 2.0, which requires the cable connected computers and
external hard disk must support USB 2.0 standard. Because high-speed mobile device plug in a
low-speed hub, the device may not be properly installed, and some people use external hard disk
while using USB flash drives, For convenience, they directly used USB 1.1 standard cable that
supplied by USB flash drives, as a result, the USB 2.0 standard hard drive not be recognized
correctly. Just replace it by the USB 2.0 standard cable can solve this problem.
4, Windows version is too low
Pre-Windows 98 operating system does not support USB peripherals, so in any case to install the
driver, set the CMOS parameters are unable to make normal use of external hard disk. In this
case, one solution is to upgrade the operating system up to Windows 98, another way is to
Microsoft's official site, download the appropriate patch to make it can identify mobile hard
5, The system is set incorrectly
When installed driver, the external hard disk icon will be seen on the Device Manager for some
Windows 98 users, but the Explorer does not include the corresponding letter identification,
which is improper system settings. In the Device Manager, double-click the Hard Drive icon, and
click the pop-up window in the "Properties" button, and you could see disconnect, could be
deleted, synchronous data transmission and Int 13 unit four options, of which "could be deleted "
is no tick in front of the system, and simply check this option to restart your computer, you can
see in the Explorer, the new external hard disk drive letter.
While the failure of the external hard disk does not recognized are more the reasons, but
generally not the USB interface or external hard disk's own fault, so it requiring us to consider
some more from around the association when exclude it, I believe you can successfully use the
external hard disk.
Hi I had the same problem and solved it like this assuming that you are running windows xp
With your external casing powered-up (it does not get power through USB does it?) and your WinXP
PC running, plug in the USB.
You should hear 'chime', what happens then?
If harddisk is recognised here, but does NOT have a drive-letter and cannot be seen in Windows
Explorer, the answer is in Windows Disk Management
Go Administrative Tools > Computer Management > Disk Management. ( on left column)
Maximize this page. Physical Drives appear at the bottom; Logical Drives at the top.
Hopefully your drive will appear at the bottom (physically), you must then 'import' it into the
Windows installation
; Windows will put its 'signature' on the drive and assign it a logical drive letter :^)
you can try to format it here if it is new and has no info on it , check back to My computer and see if present.
Mar 20, 2013 | IBM FRU PN 49P1599 Desktop Motherboard
My Firelite SmartDisk120 works fine on one computer running XP, but on my other computer (XP ME) it only works if I plug it in AFTER windows has launched. If it's already plugged in, my computer screen...
Sounds like your Boot Priority is set to USB first. Go into BIOS and change the Boot Priority to CD/DVD, Hard Disks, then USB and you should be good. It is doing this because it is trying to boot from the USB drive instead of your hard drive. You unplug the external disk and so that takes USB out of the loop, then allowing it to move to the next option which is probably Hard Disks. So get into BIOS, Change Boot Priority, Reboot. You should be good from there!
Mar 16, 2011 | SmartDisk FireLite USBFLB120 120 GB USB...
Transfered XP to internal Sata disk with controller . MOBO A7V8X-X, BIOS version 1014. Disk is recognized during boot. Disconnected all IDE drives. System won't boot from sata disk. Booting from CD results...
get to the bios boot section
( on starting the computer hold down the delete key until the bios screen shows
in that section you will see boot preference
organize the sequence that the unit will boot from save and esc
so sata hard drive =1
external hard dive =3 etc
Sep 11, 2017 | ASUS A7V8X-X (90-M7A690-W0EAY) Motherboard
I installed linux ubuntu remix on my ASUS Eee 1001PXB-BK301 multiboot, then i deleted ubuntu after not using it anymore using windows xp disk mangement and found myself without a mbr with grub saying grub...
What you need is SATA controller drivers to be downloaded while starting windows xp disk or ERD Commander.
Since Asus Eee does not have an internal Floppy Disk Drive (FDD), you need to use an external USB FDD.:
Step one: You would like to connect an external USB FDD.
Step two: copy scsi/sata Hardware Access Layer (HAL) Drivers for you laptop to a floppy disk
Step three: during the XP boot process press F6 and follow the prompts to insert a floppy disk with HAL scsi/sata drivers.
Step four: Finish the boot process and run fix MBR.
There is another easy way:
If you can get a Knoppix USB flash drive, you can boot it up from Knoppix and run the following command in the terminal window: sudo ms-sys -m /dev/sda.
Hope This Helps
Jan 29, 2011 | ASUS Eee PC Netbook
Windows xp will not restart with usb plugged in. I am running windows xp sp2 with a Hitachi 500g external hardrive that is designed to turn on and off with the computer. The same hard drive works fine on a...
Sir, your PC might have been checking for external devices which plugged in to boot from. Thats wrong. So get into the bios of your computer while startup and change the 1st boot device to your computer's hard disk. And its a bad idea, starting your computer with a usb device plugged in.
Jun 29, 2010 | Hitachi 500GB External USB 2.0 Hard Drive
How to boot from external hard disk plsss help
You could setup a dual boot system, this requires a fairly large hard disk and you need installation XP and Vista CDs.
The other option is to install XP only on your hard disk.
Mar 07, 2009 | Dell Studio 15 Laptop
USB booting of external hard disk in HP laptop
You cannot boot Server 2003 from an external USB Hard Drive, it will have to be installed on an internal hard drive.
Dec 05, 2008 | Computers & Internet
Dell Latitude D600 with new Hitachi 30GB Drive Not Recognizing
XP install is not detecting any hard disk.
No jumpers are required for laptops, can only have one hard drive in a laptop.
Check the BIOS for the hard disk configuration, make sure that it is set on Auto (detect).
You may have a faulty hard disk, you can check it by booting up with a floppy DOS boot disk, run fdisk to see if it detects the hard disk, OR connect this hard drive to a USB hard disk adapter and connect it to a working computer's USB port and if it detects it as an external drive the it is OK.
Nov 30, 2008 | Dell Latitude D600 Notebook
XP to Vista
Hello Paulraven,
You can use an external USB DVD ROM drive, put the Vista disk in it and you will be able to install it via USB (once XP is fully Booted).
If you want to Boot to the Vista disk using a USB port, then you should check your Boot Order in your BIOS and make sure that you set it to check CD/DVD drives before the hard drive, then you'll be able to touch any key on reboot to Boot to CD for a few seconds when that option appears on your screen (at the top left of the screen) after a Boot/re Boot with the Vista disk in the USB DVD drive.
I hope this helps, and Good Luck.
Mar 04, 2008 | Microsoft Windows Vista Ultimate Edition
Computers & Internet Logo
1,465 people viewed this question
David Payne
David Payne
