Question about SanDisk Sansa m230 MP3 Player
To view playlist on computer screen for downloading
The Sansa m230 is connected into the computer and it won't reveal the playlist on the computer screen for deleting and downloading music.
  • Anonymous Apr 20, 2008
    I have plugged in the device into the computer, and then the device willl pop up but not all my songs that i have on the mp3 player will pop up and the ones that dont come up are the ones that i would like to delete.
  • doaney Apr 20, 2008
    i have already plugged the device into the computer and the screen pops up but only has some of my music on it and the ones i want to delete are not popping up???
Hbed57
Posted on Apr 18, 2008
How do I put music onto a sansa sandisk m240?
your mp3 should have come with a software cd. I had a sense mp3 and had to load program to my pc to add music.
Dec 27, 2014 | SanDisk Sansa m240 MP3 Player
My Sansa e280 is not downloading my playlists from Windows Media. I have tried dragging and dropping the playlists from my computer music folder to the Sansa folder and it still will not write to the mp3...
The Sansa e280 can be operated in 2 ways of USB connection modes: MSC or MTP.
In MSC mode, viewing the player as a removable disk, the "copy
and paste" or "drag and drop" method will work.
In MSC mode always through the "safely remove hardware" icon, click to remove the player's disk before taking out the USB cable.
In MTP mode, operating the player in software like Windows Media Player: under Library or Sync,
first create a playlist
next sync the playlist.
In MTP mode, follow up the warning or text in the software that gives permission when to disconnect the player.
Apr 11, 2010 | SanDisk Sansa E280 MP3 Player
Player won't work with vista? can i download software to make it compatible with vista?
When you're able to view the menus of the player, look in the manual on page 30 = page 31 of the pdf file for the USB connection mode on your player:
Settings
USB > Auto Detect
> MSC
M200 series manual in pdf format:
http://mp3support.sandisk.com/downloads/um/sansa-m200-um.pdf
With Windows Media Player 11 under Vista, the player should be
recognized as a media device in this Microsoft Media Player. Transfers can be made in MTP mode (Media Transfer Protocol) using WMP 11: USB mode should be in Auto Detect.
In Autodetect mode files on the player can also be viewed in the Explorer mode under My Computer, seeing the player as an external flash drive.
In WMP11 use Library and Sync mode for creating playlists and synchronizing music. More about how to use WMP11, see the help items in the player (click on e.g. Library or Sync etc.) or go to the Microsoft site:
http://www.microsoft.com/windows/windowsmedia/player/11/using.mspx
When USB mode is set to MSC mode (Mass Storage Class) the player can only be viewed in the Explorer under My Computer.
More online support for the Sandisk M230 under M200 series players.
Main main support link:
http://kb.sandisk.com/app/answers/detail/a_id/4487#m200
Update page for the players' firmware using the Sansa Firmware Updater:
http://kb.sandisk.com/app/answers/detail/a_id/1107/kw/updater/p/555%2C662%2C670%2C677/r_id/101834
Help links for the M200 series are also available on Sansa Forums:
http://forums.sandisk.com/sansa/board?board.id=m200
When needing more help from this side, don't hesitate to post another comment in this question.
Mar 22, 2010 | SanDisk Sansa m230 MP3 Player
How can I immediately down load music playlists from my windows media? Thanks
1 Connect the MP 3 player to the computer with the cable provided with MP 3 2 Run the widow media player programme 3 Switch on the MP 3 player 4 On the main screen you will if the device is connected or not. Once connected create a playlist by selecting songs from the library. 5 Drag all the songs thus included in the playlist to the right column where it is shown 'drag items here' 6 After completing the action of dragging click on 'start syn' at the bottom of the right column The synchronization will start till it appears that action has been completed.
Dec 22, 2009 | SanDisk Sansa m230 MP3 Player
How to download songs
1. Are you using Windows Media Player 11 ?
2. Can you see the Sansa e250 connected in the sync mode ?
If no: install and update WMP11
If yes:
3. Make "new playlist" in the <Library> or <Sync> mode
of WMP 11; screen left side.
3.1 Save "new playlist" in WMP11; screen right side.
4. Put in <Sync> mode your playlist under the player: The player
should be connected showing in WMP11. Start synchronizing.
Leave the player connected until <Sync> is ready.
Support for Sansa e250:
http://www.sansa.com/sites/default/files/downloads/e200_userguide_en.pdf
Aug 29, 2009 | SanDisk Sansa e250 MP3 Player
I can't delete songs from my Mp3.
I had the same problem.
On the MP3, go setting and then to USB.
There are two options: Auto Detect or MSC. One will be checked showing the current connection type. Select the other one and connect the Sansa to your computer.
For some reason, the Sansa doesn't recognize files loaded in MSC if you're connected in Auto mode and vis versa.
In MSC mode, it will show up as a devise with a drive letter. In Auto mode, there's no drive letter; it shows up as a removable devise.
Also note, you can only add Playlists in the Auto mode. MSC mode does not recognize Playlists or if it does, I haven't figured out how to do it
Dec 08, 2008 | SanDisk Sansa m230 MP3 Player
Pissed
First of all - this player sucks.
Sansa does not really support it anymore.
You can go to SanDisk's website, and look at their tech forums for this series, but no one has come up with an easy solution that works 100% of the time.
In general terms, you have the switch your device mode from mtp or msd to auto to display the missing folders. Personally, I'ma little sleptical that you will ever be happy with this POS player.
Aug 30, 2008 | SanDisk Sansa m230 MP3 Player
Drivers for the Sansa m230 mp3 player
Drviers are available from Sandisk's website
May 23, 2008 | SanDisk Sansa m230 MP3 Player
Won't delete songs
You should be able to modify and delete playlists/songs by connecting the player to your computer and accessing the files by going into my computer and selecting the player drive.
May 20, 2008 | SanDisk Sansa m230 MP3 Player
Playlists
please be more especific
because there is more than one way
Dec 23, 2007 | SanDisk Sansa m230 MP3 Player
SanDisk Sansa m230 MP3 Player Logo
54 people viewed this question
Top SanDisk Audio Players & Recorders Experts
Gyula Lacz
Computer Repairing
Computer Repairing
Are you a SanDisk Audio Player and Recorder Expert? Answer questions, earn points and help others
