Question about Gateway FPD2485W Television
Gateway FPD2485W how do I replace the LCD
Hi, Usually don't have much problem working on these types of things, but I am having trouble getting into this monitor without hurting it. I know somebody out there knows where the internal clips are, and the release points. I just cant find the right combo. Please help if you can. Thanks..... Also if you have any pointers on replacing the LCD once I have it open feel free to pass them on. Thanks again.
  • MTHADDOCK Apr 15, 2008
    Hi Jerry, I have bought three of them on ebay. One of them has all the right working parts to fix the other two, but I am having trouble getting into it. I have removed the three visible screws at the bottom. There are two what appear to be power buttons next to where the other screws are. They may not even be power buttons, ? they may just cover 2 more screws and it will easily open. But they don't wont to pop out and if I use any more force it will brake it. I guess I will know then, but after years of taking computers and laptops apart I know it is probably a clip or hidden screw or someone saying don't worry just pop those buttons out of there and get on with it. So if you have any ideas ? Thanks in advance. Mike
  • Anonymous Mar 14, 2009
    my lcd is doing the lines thing, do i need to replace it or should i just buy a new one, replace the lcd i mean?
    Genius:
  • Gateway Master
  • 1,689 Answers
For most models, replacing an LCD panel is very close to the cost of a complete new monitor.
Jerry G.
Posted on Apr 15, 2008
Find driver for Gateway FPD2485W TFT LCD Monitor
If it is still supported you should be able to find it on there support page. http://us.gateway.com/gw/en/US/content/drivers-downloads
Sep 13, 2014 | Computers & Internet
FIND SOFTWARE FOR GATEWAY FPD2485W TFT LCD Monitor
That model should be plug and play with windows, no disk should be needed. Just plug the monitor in and turn on the PC, it should show "New hardware detected" and load right up.
May 07, 2012 | Gateway Computers & Internet
My Gateway FPD2485W Television will not turn on. Please help!
Check the power supply main AC fuse, caps. It can also be that it is in shutdown mode if it senses shorted circuits such as the backlights inverter board.
Parts:
http://www.shopjimmy.com/catalogsearch/result/?q=Gateway+FPD2485W+
If you are going to DIY and have proper tools, electronics knowledge, and know safety precaution then please read on:
Basic LCD monitor and TV troubleshooting guide:
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
http://www.fixya.com/support/r6150077-basic_lcd_monitors_troubleshooting
http://www.fixya.com/support/r7406380-tv_training_manuals
Failed TV and Monitors: http://s807.photobucket.com/albums/yy352/budm
Learn about bad caps: http://en.wikipedia.org/wiki/Capacitor_plague
Parts: www.shopjimmy.com
Capacitors kit: http://lcdalternatives.auctivacommerce.com/Default.aspx he can make you a set of caps.
Or www.digikey.com, just make sure to use caps with low ESR, 105c, high ripple current and long life rating such as PANASONIC FM or FC series.
Please post back what you find.
Please leave rating if it helps.
Jan 17, 2011 | Gateway FPD2485W Television
I have a gateway FPD2485W tft lcd monitor and i start my monitor and after it shows gateway it then goes black. How can this be fixed
bonannorl, Maybe it can be fixed. You did not give any history of unit. Only "now" stuff. Is unit covered by Gateway warranty? How old is unit? Date of manufacture? Did unit work fine connected to your pc and this black or black n blank screen thing suddenly happen? Is screen also BLANK? Have you swapped-in old monitor to prove PC is OK? Your CCFL back-lit lcd monitor no different than any other brand in it's basic design and operation. Get into my fixya profile and read some of my testimonials and solutions to black or black n blank screen problems to help in your decision to DIY fix or contract out needed repair work. Most likely 2485w has problem with it's internal "switch-mode-power-supply"/"ccfl inverter supply"!! Let me know more info about unit.
12fixlouie on fixya.
Mar 09, 2010 | Gateway Computers & Internet
I have gateway FPD2485w have take to repair they telling me that main circuit board is bad very cost prohibit to fix. if the monitor turn off it will not come back on wait for some times it will...
what they told you is correct, the power board is failing. but the board can be repaired most often verry easily it is a common problem with gateway. i have repaired several of the 21" gateway monitors. I would be glad to do the repair for you.for a small fee.
Dec 05, 2009 | Gateway FPD2275W LCD Monitor
Need to remove the outer cover on a Gateway
If you get power to the controls and you don’t have the startup sound or see the gateway logo when you plug it in, the main board may be bad.
If your picture was pinkish or dark at the top or bottom when it was working then you may have 1 or more of the bulbs failing.
If you have the startup sound and see the gateway logo and the screen just flashes and the power buttons stay lit, then it sounds like probably the inverter may have went.
Take the screws out of the bottom rear edge (these hold the front trim), and the 4 big black ones at the middle of the back that hold the stand bracket.
The trim then unsnaps. {Be aware of the small ribbon to the power button board on the right edge}Start at the bottom and release the trim (pulling up the trim on the screen side usually starts it off), then work your way up each side bottom to top ((a pocket knife or thin putty knife even a credit card, will help release the catches as you work your way up)
Then unsnap the top edge (rocking it while lifting helps)
Disconnect the ribbon at the power button board, (Tiny latch lifts up on a hinge and ribbon slides out)
Once trim is off, remove the 4 corner screws that hold the screen in. Then the screen will lift out with all the guts. You may have to pry up on a corner with a screw driver to get it started.
The inverter is under the medium size metal case.
The power board and main board are under the large cover.
You’ll then have to remove a bunch of screws including the usb board ones and unplug the bulbs and wire to the screen
then the power board and control board is under the center area under the metal cover
Shout if you need more info.
If you email me a good picture of the board , I may be able to get a better idea if it is the inverter from a visual.
Thanks Fran
Oct 09, 2009 | Gateway FPD2485W Television
Hi, how do I connect this monitor (Gateway FPD2485W) to my RG6 wire? I wanna watch TV on it. Thanks!
Use an RG6 adaptor to and install it to your RG6 wire. Then, plug it at the back of your monitor.
Sep 21, 2009 | Gateway FPD2485W Television
I have not worked on this model of set. I was thinking along the same lines as you are. I do remember some monitors having hidden tabs under the edge of the cabinet. I had to use a very thin blade to reach the tabs. It was something like a remote control where you have to find the tabs to open it.
Jerry G.
Apr 15, 2008 | Gateway FPD2485W Television
Gateway fpd2485w lcd shows video then cuts off
I'm pretty sure the inverter board is bad. you have to replace it if you can or you can let someone else do it. you should find some on ebay for about $80 (not too bad compared to the cost of the monitor: over $200). but its up to you. But first, you should find out if you are still under warranty. good luck. please rate!!
Mar 22, 2008 | Gateway FPD2485W Television
Gateway FPD2485W
i had same problem main board had a bad 3.2 volt regulator
number on regulator was 1117 3.2 there were 2 of them and 1 on the usb hub board so i un soldered the one from the usb and replace the one on the mother board. must be very carefull with ribbon going to front bezel controls easily torn
Jan 20, 2008 | Gateway FPD2485W Television
Gateway FPD2485W Television Logo
321 people viewed this question
Top Gateway Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Gateway Televison and Video Expert? Answer questions, earn points and help others
