Question about Intel D865GBF Motherboard
Problem in sound drive
Hellow
i have a problem in the audio drive , after i formated the hard drive the audio drive is not recogized then i install the audio drive from the net but still not take it , the driver is AUD_ALL32_5.12.1.5240.PV
I use win-XP
please tell me what can i do to install the audio driver
thanks allot
Hi. i have a problem is not install audio driver. anything one have a audio driver software about main intel d945gcll please post to my email is ngoxuansonmn@yahoo.com. thank you.
Posted on Jun 10, 2009
    President:
  • 2,351 Answers
Rather than using the normal fashion to install you're audio driver software, show windows the way through device manager.
Right click once on My Computer & left click Properties. Click the hardware tab & click on the device manager button. Scroll down to & left click the plus + sign next to Sound, audio and game controller. Right click once on the yellow ! point & left click on update driver. Click No in the next window & click the next button. Click Install from a list or specific loacation than click the next button. In the next window click on the green check mark next to, Search removable media (this will remove the green check mark), than click the Browse button. Use the dropdown menu to open the folder where you downloaded the sound driver software. No need to click on the setup.exe. Just pick the correct driver folder for you're operating system. Than click Ok. When finished restart you're PC. Test you're sound.
You may have this link but I'll list it anyways.
http://downloadcenter.intel.com/filter_results.aspx?strTypes=all&ProductID=948&OSFullName=Windows*+XP+Professional&lang=eng&strOSs=44&submit=Go%21
If this install should fail, double check you're bios setting. Make sure the audio is enabled. If everything is correct than you're intergrated sound chip may be defective. The only other option would be to add a PCI sound card.
Good Luck!
If you still need help drop me a post.
Mike
Posted on Apr 18, 2008
Audio service refuses to start
The obvious, is it muted? NO. Disable device in Device Manager, enable device, no change, uninstall audio device, reboot, I don't know your OS, your OS should automaticly ID the audio an add driver. If it does not go to Acer website a download audio driver for your OS. Install manually. You stated,"after installing a hard drive I had from another laptop" . The Harddrive you installed, did you format it and install into this laptop and clone the drive? I am a bit confused by the statment, "after installing a hard drive I had from another laptop"?
Nov 07, 2012 | Acer Aspire One D257 Netbook
Hellow my internal desktop seagate 160 7200 is
use partition magic to delete all patrition and recreate new empty ones
Oct 14, 2009 | Seagate (AU-80GBSATAHD) 160 GB SATA Hard...
I can't hear the sound after formatting the computer
Hi dear,
1- You have formated the the hard disc and install OS again.
Therefore
you have to install AUDIO (sound) driver.
you can use audio driver disk or motherboard disk which was come with motherboard.
or you can install sound driver from the internet.
Thanks
Veeru
May 07, 2009 | Compaq Audio card Sound Card
BAD DIRECTSOUND DRIVER ERROR CODE 88780078
  • hellow sir ,
  • i have suggested you please install the sound driver again
  • and than cannot solve this problem them install your system windows ok thanking you
Apr 29, 2009 | Creative Labs Sound Blaster Live! 5.1...
Hellow
which pc do you have?
Mar 22, 2009 | Computers & Internet
No Audio Support in S5000PSL
HELLOW MY COMP IS NT INSTALLED DESKTOP BOARD D945GCLF IS THAT .
Feb 21, 2009 | Intel S5000PSL DP LGA771 MAX-32GB CPNT45NM...
Audio for VIA VT1617A dound card does not work
please install the driver it is available at www.driverguide.com or at the company`s website
Aug 14, 2008 | Edirol UA-4FX External Sound System
Foxconn sound card drivers
same problem
I formatted my hard drive and reinstall windows xp but no sound comes from speakers I tried to install audio drivers from the motherboard CD "foxconn" but PCI driver can not be installed what should i do?
Apr 07, 2008 | Intel Frontier Design Dakota 24-Bit PCI...
Slave Drive not recog in my computer but it is disk management with no drive letter
A quick thing to try Is
remove the 80gb from ide cable and power plug and set the 20gb back as master.
boot into windows from 20gb 1 time ,
then shut down hook the 20gb as a slave and the 80 back up as master
Allow windows to find new hardware , "watch closely down by clock ". It will tell you when windows has finished and will say you might need to reboot before new hardware will work properly
After rebooting Both should show inside My computer
Good Luck I hope this helps
Nov 14, 2007 | Quantum Fireball Lct20 (QML20000LD-A) 20...
Intel D865GBF Motherboard Logo
192 people viewed this question
Top Intel Computers & Internet Experts
Tony
Alun Cox
David
David
Are you an Intel Computer and Internet Expert? Answer questions, earn points and help others
