Expert
- Posted on Jun 24, 2010
Re: The water is going out by the inlet soap fitting, and...
You will find that the non return valve as stuck inside your pump.If you follow the pipe back to the pump you will find a non return valve which is a ball and spring. Please remove this and replace if required.
this should then stop the water and soap returning back.
