Question about Sony KP-51WS510 51" Rear Projection HDTV-Ready Television
Dark Picture on Sony KP-51WS510
I have the Sony KP-51WS510 , maybe 5yrs. old. The picture gets dark as it warms up, brightness is cranked all the way up, and the picture (contrast I guess) is all the way down. Cleaned the lenses and mirror for only minor improvement.Could this be something getting hot? Ned
  • 1 more comment
  • Ned22 Apr 16, 2008
    It has a decent picture at start up, but after about 5 minuts it begins to get darker. Mostly the dark scenes tend to loose definition.
    It has a decent picture at start up, but after about 5 minuts it begins to get darker. Mostly the dark scenes tend to loose definition.Convergance is good.
  • Ned22 Apr 17, 2008
    It has 3 lamps. Someone else mentioned something about bad welds,
  • 3,037 Answers
With it being a rear projection TV and being 5 years old, you just need to buy a new lamp and replace the old one.
With a new lamp, it should be like new.
Please let me know how it goes and whether you need any further help.
Thank you for using Fixya and Good Luck fixing the tv.
Posted on Apr 16, 2008
  • Benjamin Patri
    Benjamin Patri Apr 17, 2008
    you can check the solder joints first on the circuit board and surrounding area and see if you find a loose one first if you wish.
  • 813 Answers
Hi firned
there was a setting on tv ckt u have set form the open your tv there was a verible resistor on the tv ckt bord its control birghtness & contrast so u have set it as u needs u have to take ur tv your nearest good raprir man its do it free i m doing here free but i not come there so u take tv with a good riper man
thnx using fixya
Posted on Apr 15, 2008
    Genius:
  • 1,226 Answers
Maybe need sort of ajustment of the projection inside. clean the circuit and resoldered all parts maybe some loss connection in the circuit board. becarefull of high voltage that can hurt you.
may this help, melnavz
  • Emelio Navaja
    Emelio Navaja Apr 17, 2008
    Ned22 ,
    I see loss connection and need to resoldered, still ok, even you rate me "thanks for trying" forget that, Thank you for using fixya.
    melnavz
1. picture is getting darker 2. there is a green outline when the brightness is turned up
Hello ksolovy, i understood your Problem with the Sony KP-53V90 53 in. Rear Projection Television,In fact i encountered already that kind of problem you have it now. Check first the color wheel im sure that the blue section of your color wheel was burned and the blue color turn to dark; That's why you have seen dark picture, Re-place color wheel.
Dec 21, 2010 | Sony KP-53V90 53" Rear Projection...
Dark picture on wega lcd
Yes, if this TV has a bulb it is likely to be the bulb.
I am not familiar with this exact model, but other LCD Projection TV will show dim picture after some time. Expected life of the lamps is about 2yrs. After 2yrs the picture will become dim. After 5yrs I am suprised it is even working.
Dirt doesn't cause this problem unless your are a smoker or have the unit "literally" outside. DO NOT try to clean it or let someone tell you to do it because it will cause more problems than it fixes.
May 07, 2009 | Sony Grand WEGA KF-42SX300 42" LCD TV
Picture get dark than light
On your remote control, press the huge circle, which should be settings or menu, there, go on brightness, put it up to max if u want bright, and low if u don't .If the problem still happens, ask customer service to help, or return it!!
Feb 19, 2009 | Sony BRAVIA KDL-40S2000 40 in. LCD HDTV
Sony KP-51WS510 has a haze or back glow that cant be adjusted
It seems U are having no screen voltage.
U need to get it repaired
Rifaa
Nov 10, 2008 | Sony KP-51WS510 51" Rear Projection...
Sony KP-51WS510 51 in. Dark picture
I finally heard from Sony tech assist. You have a bad high voltage transformer. As the set warms, the high voltage decreases and this is causing the problem. At this point, I would refer service to a local Sony authorized center.
Apr 18, 2008 | Sony KP-51WS510 51" Rear Projection...
Sony KP-51WS510 51 in. Dark Picture
These sets have been known to have loose welds in the picture tubes. Most likely your tubes are showing this problem.
Apr 17, 2008 | Sony KP-51WS510 51" Rear Projection...
Dark picture
sony had a recall on this set see if this is one of yours
http://esupport.sony.com/perl/news-item.pl?news_id=24
Oct 01, 2007 | Sony KP-57HW40 57" Rear Projection...
Picture goes dark
1 your problem is in video section 2 if it is ok then check power supply for any components defective.
Sep 15, 2007 | Sony FD Trinitron WEGA KV-32HS500 32" TV
Sony warms up - picture slowly becomes dark
You are losing screen voltage or whats called the boast voltage most likely. This is probably being caused by a bad capacitor in the sweep power supply. You will need to get a service manual as well as use an ESR type capacitor meter to find the bad capacitor(s). Good Luck
Jun 05, 2007 | Sony KP-46WT510 46" Rear Projection HDTV
Sony KP-51WS510 51" Rear Projection HDTV-Ready Television Logo
130 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
