Question about Toshiba gigabeat MES60VK Digital Media Player
My toshiba MES60VK wont turn ON
The gigabeat was playing normally then suddenly turned off and stopped working. Ive tried to turn it back on but nothing happens. I've flipped the battery switch but there is no response. When i plug it in with the AC adapter nothing happens just a blank screen same for USB plugged in. It seems like it is permanently turned off and wont turn back on. Any solutions to this problem. What should i do?
Anyone been able to solve this issue. My Toshiba Gigabeat started doing this yesterday. Any Help!!!
Posted on Sep 11, 2008
I have a mes 60 gb Gigabeat and I've had the same problem. There is a very small slide switch on the bottom if the gigabeat. Use a pen or the end of a paper clip to slide it to the left (off) wait a few seconds and slide it back to the right (on). It should allow you to turn it back on with the power button. You may have to repeat the procedure leaving it off a little longer each time.
Posted on Jul 17, 2008
I am having the exact same problem with my Mp3 player. I have the same model as u. i believe it is the model and there is no wa of fixing it. Your best bet would be exchanging it for a new one or buying a totally different Mp3.
Posted on Jun 16, 2008
I am having the same issues, any luck finding a solution?
Posted on Jun 13, 2008
Transfer files from gigabeat to ipod
try uploading them to your "realplayer",Windows Media Player,ETC, then once they are "loaded" into your Play list, you can,Burn,Rip,Share,and download to almost anything
Jul 03, 2009 | Toshiba gigabeat MES60VK Digital Media...
I would like to copy or remove music files from gigabeat to my pc.
plug in the ipod, go to my computer and double click your ipod icon, go ta music, and then copy and paste what you want to " my music"
May 29, 2009 | Toshiba gigabeat MES60VK Digital Media...
Gigabeat MES60VK - Error # 5
It just went off and when it was turned on the screen says 5 in a yellow triangle (Error 5?) Contact Manufacturer for repair. Toshiba could not help.
Did anybody found a solution to this problem yet? is it worthy to try to repeir it? please let me know moisilayo2002@yahoo.com. I really appreciate it. Thanks!
Nov 08, 2008 | Toshiba gigabeat MES60VK Digital Media...
MES60VK Gigabeat - Dead
There is a switch on the bottom left side of the dock connector of the player. Flick the switch to the right and it should work. The switch is the battery cutoff switch. It is there so it will charge only. I have no idea why Toshiba though this was a good idea, but they put it there.
USB Connection Problem
I have the same problem. If you have a large library try letting it stay hooked up for a long time. It seems like it is taking inventory of device then it should work after a while. Sometimes this works. Sometimes I have to unplug then try again in a few minutes.
Aug 31, 2008 | Toshiba gigabeat MES60VK Digital Media...
Battery is dead
Identical problem - working only with power cord.
Wont power on battery or usb cable.
I actually opened player and check every single option.
(I am experienced electronic - tech.)
Result: battery is fully charged (768 mA/ 3.97V on bench)
Battery switch on bottom fully functional. (switching on/off 3.97V
comming from battery)
USB supply 5.0 V in perfect order.
Conclusion:
There is no "EASY" fix for this problem.
It is either problem with firmware (low possibility)
or semiconductor on logic board (practically not fixable on DIY basis)
I bought my Gigabeat 60Gb for $ 70.00 used on Ebay so
I will live with this problem.
Feb 04, 2008 | Toshiba gigabeat MES60VK Digital Media...
Doesn't work without cord! Battery switch is not responding at all.
There's a "hidden" switch on the lower part that makes it not use the battery. You can switch it with a pencil or pen.
Jan 05, 2008 | Toshiba gigabeat MES60VK Digital Media...
Toshiba gigabeat MES60VK (60 GB) stopped working
There is a little battery cut of switch at the bottom of the device. You can unbend a paper clip and switch it off. Then switch it back on after a few seconds. Plug it back into the usb cable to charge it. It should work ok now.
Dec 26, 2007 | Toshiba gigabeat MES60VK Digital Media...
Toshiba Gigabeat MES60V will not hold charge
I am trying to register an Adobe program on my computer and I can't because the program says my serial number is invalid. It seems like there are many people with this problem.
Nov 14, 2007 | Toshiba gigabeat MES60VK Digital Media...
Toshiba gigabeat MES60VK Digital Media Player Logo
128 people viewed this question
Top Toshiba Audio Players & Recorders Experts
Electro Med Services...
 Grubhead
Grubhead
Are you a Toshiba Audio Player and Recorder Expert? Answer questions, earn points and help others
