Transceivers
Problem for Transceivers
Generic problem for all Transceivers
Power connection for L365 Fish finder
By darol on Apr 15, 2008
Hi
When I examine the end of the 2 pin power connect I have 3 wires exiting the cable sheath a red, a black, and a bare cable (with no colour plastic cover)? what do I connect the bare cable to, assuming I connect red to live (positive terminal black to earth neg terminal)? Do I solder the black and bare together? or does the bare line go onto something else?
thanks darol
Best Solution
posted on May 09, 2008
Very Helpful)
Rubec
Rank: Wiz
Rating: 91%, 38 votes
Fuses and Breakers
Attach the red or positive wire to a 5 amp circuit breaker. If the unit is connected directly to the boat’s battery, include a 2 amp in-line fuse. (In-line fuses are available at most marine supply stores.) The power cable includes a smaller "shield" wire. Connect this to a good ground.
Extending the Power Cable
If you need to extend the power wiring by more than 10 feet, use a larger wire size. This will allow the wires to deliver the correct voltage in spite of the longer wire distance. For runs of 20 to 35 feet, use #14 AWG cable. If you extend the power wiring, be sure all electrical connections are solid and durable. Soldering is the best way to make these connections. Insulate all connections using heat-shrink tubing or electrical tape. You may also use crimp connectors or a terminal strip, but be sure to use good-quality marine-grade parts.
Was this helpful?
Yes
No
Popular Solutions for Transceivers
Questions and Unsolved Problems for Transceivers
Answer
sir i want all the material data about Base Transceiver Station (BTS) Installation, Commissioning,... (More)
Answer
when someone calls me or i call someone, i cannot hear them, they can hear me, i have to put in on... (More)
Answer
my sony ericsson w300i phone isautomatic locked and i could not remember my un locking code i nedd... (More)
Answer
When I tried to charge it led did not light up & battery did not charge, but system turn on
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Browse popular Problems
More Common Problems
Most Common Problems for:
For Transceivers:
Top Transceiver Experts
Rank: Guru Guru
Solutions: 3587
Experience: Semi retired, was network administrator, proficient with hardware, software, networks, CAD systems
Ask Me
Find more Transceiver Experts
Top Computer & Laptop Repair
(952) 890-7770
Zkarlo.com provides discount and used laptop parts...
Zkarlo.com
(877) 729-0812
We connect to your computer over the Internet to...
Remote Repair
Chat Now
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
