Agfa SnapScan 1212p Flatbed Scanner
Problem for Agfa SnapScan 1212p Flatbed Scanner
Agfa Snapscan 1212P Problem - Any help?
By Charlie - usenet poster
I've got an Agfa Snapscan 1212P, haven't used it for a few months and
when I tried to scan anything last night it just shows that it's
scanned colour static (loads of dots of colour) and not what it should
be scanning.
I've re-installed the drivers (running 1.0.0.8) and still get the same
problem. I'm using Windows 98.
If anyone's got an idea how to fix it then I'd be grateful as my only
other solution is to rebuild the machine!!
Thanks,
Chris.
Sent via Deja.com http://www.deja.com/
Before you buy.
Solution #1
posted on Aug 10, 2005
Somewhat Helpful)
Perkins
Rank: Apprentice
Rating: 0%, 0 votes
As a start, go to the Agfa Web site, and download and install the latest
version of Scanwise 1.2.0.9
It may help.
Are you running a printer with your scanner off the same parallel port?
If so, this can cause conflicts.
If problem still exists after installing 1.2.0.9 get back to this N/G.
I may be able to help further.
Johnno
Was this helpful?
Yes
No
Solution #2
Not Rated)
Bomber
Rank: Apprentice
Rating: 0%, 0 votes
Hi Johnno,
Thanks for your help - I've de-installed the current Scanwise software
and have installed Version 1.2.0.9 and I'm still getting the same
problems.
I am running the scanner from the same parallel port as the printer -
but the scanner is the primary connection, and the printer has been
working fine.
I'd be interested if you can suggest anything else - I've checked the
BIOS and I don't even have the opportunity to select EPP printing on
the parallel port in the BIOS (in fact there's not much I can change at
all!)
Thanks in advance,
Chris.
In article <3a095 @news.iprimus.com.au>,
Before you buy.
Was this helpful?
Yes
No
Popular Solutions for Agfa SnapScan 1212p Flatbed
Questions and Unsolved Problems for Agfa SnapScan 1212p Flatbed
Do you recommend Agfa SnapScan 1212p Flatbed Scanner?
Answer
Answer
it powers on, adjust s positions and then turns off
Answer
snapscan 1212u It is completely installed and a notice says it is "ready to go" , when I... (More)
Answer
my snap scan 1212 flatbed power will not stay on. I use it a lot over the last two weeks. Now today... (More)
Answer
Is it possible to get this problem solved for free?
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Browse popular Problems
More Common Problems
Most Common Problems for:
For Agfa SnapScan 1212p Flatbed...:
Top Scanner Experts
Rank: Guru Guru
Solutions: 744
Experience: 30 Years of professional repair and design.
Ask Me
Find more Scanner Experts
Top Printer Repair
(800) 836-9287
Celebrating 14 Years Of Outstanding Printer Repair...
Laser Repair 911
(918) 583-5483
Elite printer Services, Inc. is a full service HP...
Elite Printer Services
Chat Now
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
