Question about Denon AVR-2400 Receiver
No sound my Denon AVR2400 is almost 10 year old now and it was perfectly fine untill yesterday. When I turn on the power, everything is find except no sound....When I turn up the volume to max. you can barely hear the sound. Does this mean I need a new receiver? Can I fix it? Please help!
  • Jason Oberbillig Jan 18, 2009
    I'm having a similar problem.  The receiver gets stuck on the DAT/TAPE setting.  It'll switch over to 6CH EXT IN to play DVDs but if any other setting is tried it automatically switches back to DAT/TAPE.  It'll remain like this for a couple weeks or months, then act normally for a couple weeks or months.  Any advice?
  • COgal May 11, 2010
    I'm having issues with a AVR-2400 also. Do you have a manual for it?
    Sergeant:
    Champion:
  • 341 Answers
1. check if the amp is in PROTECTION mode (might be a bad speaker or shorted output)
2. check the 'MUTE' switch
3. try to use the FM/AM mode to isolate an input source. If there is sound then check input source.
4. ...still no sound have a techinician check it.
Posted on Sep 24, 2008
Ge spacemaker microwave JVM1650 won't heat
sounds like possible magnatron or diode thats the case its not worth repairing. but if your handy then google model nuber and get the part be extreamly careful because of the power capacitor holds extream volts. turn off and allow to sit 15min before working on
Oct 23, 2012 | GE Spacemaker JVM1640SJ Microwave Oven
Whirlpool MH3184XP Microwave Turns On, Heats, but sounds like fans not working. 4 years old, fans worked fine until they seem not as loud anymore. The magnetron is working fine as it heats (did the 1 cup...
Suggest you pull the plug out, remove outer cover and place a cup of water into the micro. Set power to minimum then switch on and take note if the fan works or not. If not, switch off immediately and have it replaced(magnatron will burn out if left to run without fan.)
Sep 18, 2010 | Whirlpool MH3184XP Microwave Oven
My very old Denon AV Receiver (DRA-55V) works fine except that one of the channels sounds 'gated' or thuddy and staticy...music is heard (in all sets of speakers and headphones) but quality in one channel...
check your speaker A - B channel push-button switchces. They tend to get worn and contacts internally corroded after all these years <!-- from fixya rte -->
Feb 21, 2010 | Denon AVR-587
My garmin nuvi 205 no longer has voice but it still beeps when I use the touch screen so the speaker works. What could be the problem? It is a year old and worked until yesterday. Everything else is fine.
sounds like the driver for the speaker circuit is defective, call Garmin, since it is only one year old they may repair it for free to protect there good name, I assume u don't have the speaker turned off, this can be checked by going into the tool symbol and selecting sound volume.
Nov 27, 2009 | Garmin nuvi 255W GPS Receiver
Denon AVR 2308 ci. No sound when using TV (Niece changed setting
there should be a way to change a setting between.....analog, coaxial, optical 1 and optical 2..if everything is connected through rca jacks try analog
Nov 03, 2009 | Denon AVR-2308CI
Denon avr-1907 sound from TV stopped working
Help with hooking PS3 to a Denon Receiver. It worked before, but I had to move everything to a different location and when I hooked it back up the PS3 has sound but no picture. I have it hooked directly to the receiver with and HDMI cable (the receiver is hooked up to our cable box which is directly hooked to the tv via HDMI cable).
Jan 03, 2009 | Denon AVR-1907 Receiver
Power/Startup Fail
There may be problem with some wire connections or RAM is loose in the slot. insure that RAM is perfectly tight in the slots.
Jan 03, 2009 | Computers & Internet
Denon avr 2802 can't get subwoofer to work all else fine
in the Denon setup under speaker configuration set the sub to LFE+Main
Jan 02, 2009 | Denon AVR-2802
Kef theatre system kt100
I had this problem a few years back.
It's not a physical problem, it sounds like a bad relay, but a few other things were fixed when I sent it in for repair
It's not a simple fix, the amplifier in the subwoofer will need to be fixed by a knowledgable technician who has access to a schematic
Aug 05, 2008 | Audio Players & Recorders
Unit does not work
open microve cover find magnetron crimp connections to magnetron
Feb 12, 2007 | Emerson MW8108P Microwave Oven
278 people viewed this question
Top Denon Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Denon Audio Player and Recorder Expert? Answer questions, earn points and help others
