Question about Fuji FinePix A500 Digital Camera
I have a focus error that comes up everytime i turn my camera on. it wont let me take any pictures. I have same problem.
  • swtsnugg Aug 05, 2008
    camera wont take pictures
    One Above All:
    The expert with highest point at the last day of the past 12 weeks.
    Top Expert:
  • Fuji Master
  • 102,366 Answers
  • 65 Answers
SOURCE: Need Fuji FinePix A500 Software
Go to their website, Its a whole lot easier just to get a external card reader or use one thats built in your pc if you have one...
Posted on May 28, 2008
SOURCE: fuji finepix a400 focus error
Hi
I have the same camera and have devised this solution. Remove batteries, leave for about 10 mins then replace batteries ( make sure they are in good condition, Cover the aperture whilst switching it on and it should work - mine did on the 2nd attempt.
Good Luck
Posted on Aug 14, 2008
SOURCE: hi, the zoom wont retract and it says focus error
It won't focus because ya lens is out of focus due to it being stuck had same prob wig my Sony worked out cheaper to buy a new camera than have it fixed.very fiddley to repair hope if bin some help
Posted on Nov 23, 2009
fathitkf
  • 1871 Answers
SOURCE: Fuji FinePix S8000fd Digital Camera I have
Hello :
Lens error is the most common failure in digital cameras . it seems The internal coupling of the zoom lens is somewhat fragile, and a slight tap at the wrong time can mess up the system . or it could have been something as small as a bump while it was being carried in your pocket or even the sand or something like it can cause this problem . Anyway the problem is that you'll have to pay for repairs on it since technically it's not a camera error but something that manufacturers say it happened during usage. I recommend you to contact the manufacturer to see if they'll cover the repair, or to determine how much they'll charge for the repair. Who knows, you might get lucky . Some owners seem to have been able to solve the problem with a gentle bump to the side of the camera, or some gentle twisting on the lens itself. I don't necessarily recommend that- or, at least I would call Fuji first and see what they have to say about cost of repairs. Once you do get it fixed, put the camera in Playback mode before you switch it off so that the problem doesn't happen again.
PLEASE DON'T FORGET TO RATE !
good luck
Posted on Apr 11, 2010
lock123
  • 6831 Answers
SOURCE: my FUJI FINEPIX S5700 Digital Camera keeps saying
Hello
The problem is that the lens has become stuck in the barrel. There are some DIY solutions you could try, but the probability is that you will have to get it fixed by a professional.
Use these at own risk as it may further damage the camera.
Firstly , try connecting your ac adapter or usb cable.
Try holding the shutter button while switching on the camera.
Look at the lens , and if some of the lens 'circles' is misaligned or not concentric then try wiggling it (while holding camera lens down).
Try gently pushing or pulling the lens when it extends but this is risky as it may cause the lens barrel to slip out of its guidance system.
Another way to do this is to place the camera lens down on a hard surface and then power it up. Be sure to use a soft cloth or something similar as to not scratch your lens or casing. Let the lens push the camera up and down a few times and sometimes the little resistance provided by the camera is enough to get things going again.
Try hitting your camera near the lens on the body with the soft tissue on the palm of your hand.
Other than that , I would take the camera to a repair center for a evaluation to see if it would cost more to repair than to replace the camera.
If it is still under warranty I would suggest you take it in before trying any of these steps and remove any off-brand batteries or accessories as some stores are really fussy about warranty repairs on camera's with non-brand accessories.
You can also have a look at THIS link.
Hope the advise is useful. please do not hesitate to let me know if you need any further assistance.
Regards
Andrea
Posted on Sep 30, 2010
Focus error on camera wont take pictures wont put
Lens errors are fairly common. Usually it's sand or grit interfering with the lens extension mechanism. Or the camera's been dropped with the lens extended. Or the camera has been powered on, but the lens had been blocked preventing its extension. Or the battery ran down with the lens extended ... Unfortunately, many cameras that fall prey to this can only be corrected by professional repair. But, here are some things that you can do that may correct it. They only seem to work for less than 40% of the lens errors, but if the camera is out of warranty, they're worth a try.
Feb 12, 2010 | Fuji FinePix A500 Digital Camera
Hi, the zoom wont retract and it says focus error
Nov 23, 2009 | Fuji FinePix A500 Digital Camera
Fuji a500 give "focus error" message and won't shoot pictures
I am sorry to say that this design of lens is the worst i've seen from Fuji.
Focus error relates to the mechanism right at the front of the lens. The motor and drive gear are in the end piece of the lens, as opposed to other cameras that have the focus mechanism in the back of the lens and is easily access able once inside the camera.
Does the lens stick? or buzz on power up? If you tap gently, with your finger nail, on the actual lens on power up ( you may have to do this several times) you may find the lens comes out ok and no error msg is displayed (until you try zooming).This will probably be because something is jamming the gears or the tiny tension spring used on the gears has come off. I have tried to clear several A500's with this problem with limited success.
Jun 23, 2009 | Fuji FinePix A500 Digital Camera
Focus error message camera wontwork
I found this site to solve this problem. I got as far as tapping the lens, while turning it off. That worked but I still could not take pictures, so, I got the idea to put slight pressure on the lens when turning the camera on and was delighted to see that the error message was gone. Then, reluctantly, I snapped a picture...It worked. Hope this helps u 2..
Mar 29, 2009 | Fuji FinePix A500 Digital Camera
Fuji finepix a510
Check out this link: www.digitalcamera-hq.com/digital-cameras/fuji-finepix-z1_question.html?qid=4289
After the basics, try dropping the camera on a carpeted area from about 2-3 feet. It worked for my Fuji A500 and 90% of the responders on the link. Everything on the web said it would cost ~$100 to fix. I was in the process of researching new cameras to buy and had nothing to lose by dropping it on the floor.
The error may be caused by debris in the zoom mechanism preventing it from working. Dropping the camera loosens the debris and voila!
Jun 18, 2008 | Fuji FinePix A500 Digital Camera
FinePix A500 Fuji camera "focus error"
After the basics, try dropping the camera on a carpeted area from about 2-3 feet. It worked for my Fuji Finepix A500 and 90% of the responders on the link. Everything on the web said it would cost ~$100 to fix. I was in the process of researching new cameras to buy and had nothing to lose by dropping it on the floor.
May 24, 2008 | Fuji FinePix A500 Digital Camera
Focus error
May 13, 2008 | Fuji FinePix A500 Digital Camera
Repair
i have a focus error that comes up everytime i turn my camera on. it wont let me take any pictures
Jan 29, 2008 | Fuji FinePix A500 Digital Camera
Blurry Pics
I have a similar problem try keeping the camera still at shooting a picture
Dec 28, 2007 | Fuji FinePix A500 Digital Camera
Fuji FinePix A500 Digital Camera Logo
56 people viewed this question
Top Fuji Cameras Experts
Greg Cann
Greg Cann
Are you a Fuji Camera Expert? Answer questions, earn points and help others
